Unknown RPO Codes
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Unknown RPO Codes
My car is an '86 Camaro IROC Z28. The car had the LB9 305TPI engine, 700R4, and 3.23:1 rear stock. The car was well optioned with t-tops, AC, cruise, power windows & locks, and the roof console. I verfied all of this information with the RPO codes and the decoder on this site. The problem is that there were a few RPOs that couldn't be found by the database. The codes are as follows:
B2G, D6F, E7Z, GC5, & GC6
Also, the code C48 comes up with the response "???"
Any help that anyone can provided would be greatly appriciated.
B2L is the IROC-Z code, not B2G. I could not find B2G in any of my doco. E7Z is a vehicle speed sensor delete. The car has an electronic speedo, so all mechanical related speedo parts are marked as deleted. D6F is another speedo related item (gear). I can't find GC5 or GC6, but I would think they are suspension related due to where they are located in the rpo list.
B2L will only be found on that years IROC-Z. I screwed up. B4Z is the IROC-Z package while B2L is the 350 and all associated items with it. I knew that answer but wasn't thinking!!
I made a mistake on the C48. It should really be a C4B code.
My RPO code B47 came up with the IROC package. It wouldn't sprise me if the B2G refered to equipment specifically for the IROC Z28 package, since there were IROCs built that were not Z28s and Z28s built that were not IROCS. The B2G code may have been how they distinguished them.
E7Z couldn't refer to an electronic speedo, because my car didn't have one. It had a cable driven speedo. I agree that it does refer to the speedo though, because I also have the RPOs E5Z and E9Z.
D6F may be the speedo gear, this would make sense. Can anyone confirm this?
I don't think the GC5 and GC6 codes are suspension related, because typically F RPOs are reserved for suspension stuff from my experience (and I could be wrong).
Thanks for all the help guys! Keep it coming, especially if the new information I added helps any.
Originally posted by TKOPerformance
...E7Z couldn't refer to an electronic speedo, because my car didn't have one. It had a cable driven speedo. I agree that it does refer to the speedo though, because I also have the RPOs E5Z and E9Z...
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Car: 1989 Iroc-Z
Engine: 5.7L TPI
It means that there is no VSS on the transmission and there is no VSS buffer box on your car. Take a look behind your instrument cluster and you will find a small yellow unit there attached to the area around the tach. That is the VSS for cars with cable driven speedos and the RPO codes E5Z, E7Z, & E9Z. My car has those 3 RPO codes and it is cable driven and I don't have a VSS on the transmission.
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Here are a couple more of the missing codes
D6F = Speedo Driven Gear
C48 = Heater Delete
GC5 = Right Rear Fender Height Adjustment
GC6 = Left Rear Fender Height Adjustment
B2G = Components Of Iroc-Z Package
C48 = Heater Delete
Car: 1991 T-Top RS
Originally posted by cdartz
To my knowledge, from 86 - 87 if you had code B4Z (IROC) then it was mandatory that you also had code Z28. Therefore 85 to 87 IROCs are also Z28s. However, you could have a Z28 that was not an IROC.
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Originally posted by JohnnyIROC-Z
You are correct. All IROC's were IROC-Z(28's) But not all Z28's were IROC's since IROC wasn't introduced til 87 (Some argue late 86) but Z28's were much earlier than that.
Gotta back up Trickster, since I own an '86 IROC Z28.
Car: 84Z & Porsche
Engine: 427sbc - 471 - 850 Demon Claw
Transmission: Bowtie stage II TH700R4 - 10" 3000
Axle/Gears: 9 Bolt w/ 3:45's
Unknown RPO Codes
I have been doing some research into the RPO Codes for my Z-28 this past month. I have found most of them, but I still cannot decode three: TT5, Z06 (Maybe zo6) and 17D. This was a special order car (Customer Order) with some different things, Recaro Seats etc. These codes have me very puzzled, and can't seem to find them in any decoder or on any searches here...Thanks, Ed.
Car: 1989 Iroc-Z
Engine: 5.7L TPI
RPO code TT5 = Headlights, Halogen 2
RPO code 17D = Trim Combination, Cloth, Medium Gray.
You might want to check that Z06 RPO code, everything I have found for that RPO pertains to Corvettes. On them it is a classification package about like the Z28 or Iroc on the camaros.
Car: 84Z & Porsche
Unknown RPO Codes
The TT5 and the 17D Codes sound correct , but there is definitely a RPO Code of Z06 listed on the lid of the console. The original Vin is printed with it so I'm sure it is the correct RPO Code sheet for this car. How could an RPO Code for a Vett get on a Camaro? It's right between the Y06 and the Z28 Codes. This was a customer order car, is it possible to order a Corvette option on a Camaro?...Thanks, Ed.
Car: 1989 Iroc-Z
Engine: 5.7L TPI
The Z06 was a special performance package for the corvettes and included a L84 375 horsepower engine, better brakes and several other goodies. You did say it was a special order car.
Car: 84Z & Porsche
Unknown RPO Codes
Well that would have been great to have the 375hp motor...the RPO Code for this engine is LG4, which is the motor that is still in the car.
RPO Codes as follows:
Made in: United States
Manufacturer: General Motors
Make: Chevrolet
Restraint System: Manual belts
Carline Series: Sport Coupe, Z28
Body Type: 2 door coupe
Engine Code: 305 ci V8 LG4 (1982-1984)
2 is the CHECK DIGIT.
Model Year: 1984
Assembly Plant: Van Nuys
Production Sequence: 172331
AF9 : SEAT, FRT BKT, PASS DRIVER, RECL, OUTSIDE VENDOR
AU3 : LOCK CONTROL, SIDE DR, ELEC
A01 : WINDOW, TINTED, ALL SHADED, W/S
A31 : WINDOW, POWER OPERATED, SIDE
A90 : LOCK CONTROL, RR COMPT LID, REM CONT ELEC RELEASE
BS1 : INSULATION, ACOUSTICAL PKG
B18 : ORNAMENTATION, INTR, DELUX
B34 : COVERING, FRT FLOOR MATS CARPETED INSERT
B35 : COVERING, REAR, FLOOR MATS CARPETED INSERT
B48 : TRIM EQUIPMENT, LUGGAGE COMPARTMENT
B84 : ORNAMENTATION, EXTR MLDG, B0DY SIDE
B9K : ORNAMENTATION, B/S MLDG, REAPPLY TO RR DOORS ONLY
B91 : ORNAMENTATION, EXTR MLDG DR EDGE GUARD, COLORED
B94 : ORNAMENTATION, EXTR EMBLEM, BODY, VAR I
B97 : ORNAMENTATION, EXTR MLDG, LOWER ACCENT
CC1 : ROOF HATCH, REMOVABLE PANELS, GLASS
CD4 : WIPER SYSTEM WINDSHIELD, PULSE
C49 : DEFOGGER, RR WINDOW, ELECTRIC
C60 : HVAC SYSTEM, AIR CONDITIONER FRT MAN CONTROLS
DG7 : MIRROR 0/S, LH & RH, REM CONT, ELEC, PAINTED
DK6 : CONSOLE ROOF, INTERIOR
D03 : PAINT, PROCESS, WATER BASE
D1U : GEAR, SPEEDO DRIVEN
D34 : MIRROR, VISOR VANITY
D42 : SHADE, RR COMPT SECURITY
D80 : SPOILER, RR END PNL
D88 : DECAL, STRIPE, SPORT
E52 : DOOR RR, 83 INCH, WRAP AROUND
E9Z : SPEEDOMETER KEY (DELETE)
GU5 : AXLE REAR, 3.23 RATIO
J50 : BRAKE SYSTEM, POWER
K19 : REACTOR SYSTEM, AIR INJECTION
K34 : CRUISE CONTROL, AUT0MATIC, ELECTRONIC
K64 : GENERATOR, 78 AMP
LG4 : ENGINE, GAS, 8 CYL, 5.0L, 4BBL
MD8 : TRANSMISSION, AUTO 4 SPD, THM 700 R4
MXO : MERCHANDISED, TRANS, AUTO PROVISIONS, O/D
NA5 : EMISSION SYSTEM, FEDERAL, TIER O
NB1 : EMISSION SYSTEM, CLOSED LOOP
NK3 : STEERING WHEEL, SPORT, SOFT RIM, SIMULATED LEATHER
N33 : STEERING COLUMN, TILT TYPE
N90 : WHEEL, 15 X 7,ALUMINUM CAST,4.75 INCH BOLT CIRCLE
QYH : TIRE ALL, P215/65R15/N WOL R/PE ST TL HWY
TR9 : LAMP, GROUP
TT5 : Halogen Lights 2
T63 : ALARM, HEADLAMPS ON WARNING SYSTEM
T93 : LAMP, TAIL & STOP, SPECIAL
UA1 : BATTERY, HEAVY DUTY
UE8 : CLOCK, ELECTRIC, DIGITAL
UP8 : STEREO RADIO INSTALLMENT PROVISIONS
UU6 : RADIO, AM/FM STEREO, SEEK/SCAN AUTO REV CASS
U05 : HORN, DUAL
U21 : CLUSTER, INST, OIL, COOL TEMP, VOLTS, TACH
U25 : LAMP, INTR, RR COMPT, COURTESY
U26 : LAMP, INTR, ENG COMPT, COURTESY
U29 : LAMP, INTR I/P, COURTESY
U75 : ANTENNA, POWER, RADIO
U79 : SPEAKER SYSTEM, 4, DUAL FRT COAX, DUAL EXT RGE PKG
VAN : ASSEMBLY PLANT, VAN NUYS, CA
VK3 : LICENSE PLATE, FRT MOUNTING PKG
V73 : ANTENNA, FIXED
YE2 : CONVENIENCE PKG, DECOR LEVEL #2, LOW TRIM
YS1 : SEAT,RR CUST
YT1 : BUILD UP DR & QTR
YT2 : BUILD UP DR & QTR, CUSTOM
YT9 : OPTION PACKAGE, FISHER FURNISHED PARTS
Y06 : RING GEAR, 9.50 IN., SAGINAW, (S.P 0.)
Z28 : MERCHANDISED PKG, SPECIAL PERFORMANCE
Unable to locate code ZO6 in our database
1AZ : Order Modification, Orders Sold (or: CUSTOMER ORDERED VEHICLE)
16P : WHEEL COLOR, BRT WHITE (91)
17D : Trim Combination, Cloth, Medium Gray.
17I : INTERIOR TRIM , CHARCOAL (91)
179 : SEAT BELT, COLOR CHARCOAL (91)
19L : SECONDARY COLOR, EXTERIOR, LAMP BLACK (91)
19U : PRIMARY COLOR, EXTERIOR, LAMP BLACK (91)
6ZX : SPRING, COMPUTER SELECTED, FRONT, LEFT HAND
7ZX : SPRING, COMPUTER SELECTED, FRONT, RIGHT HAND
74A : STRIPE COLOR, ACCENT, TWO TONE, BLACK/RED (91)
8NL : COMPUTER SELECTED REAR LEFTHAND SPRING
9NL : SPRING, COMPUTER SELECTED, REAR, RIGHT HAND
Make: Chevrolet
Model Year: 1984
TR9 : LAMP, GROUP
U05 : HORN, DUAL
YS1 : SEAT,RR CUST
Car: 1989 Iroc-Z
Engine: 5.7L TPI
BTW, your car is only a 2 door. Therefore your RPO code of E52 for the 83 inch right rear door wrap around is not correct. It should be an RPO code of E5Z which is for the Speedometer Key Adaptor delete.
Car: 84Z & Porsche
known Rpo Codes
There the codes are much clearer now, and complete...Correct power antenna and the Red and Charcoal Interior...Funny thing though, the car has the code for the Quartz Clock, but the clock was never installed. The electrical wiring is there for it, and the hole through to the interior of the console box for the wind stem is punched. Seems as if the clock was to be installed but someone left it out, or over looked it 's installation maybe. Curious history...Thanks, Ed.
Here's a little Z06 history:
RPO Z06 has been used by Chevrolet on the Corvette since sometime in the early 60s. It originally coresponded to a factory built race car package which included a larger gas tank, stiffer suspension, improved brakes, deleted heater, manual everything, and a 327 making about 360hp coupled to a close ratio Muncie 4-speed.
Over the years the Z06 package has been re-used by Chevrolet in an attempt to market on the mythos of this original car. The newer Z06s have certainly been faster, better handling cars than their contemporary brethren, but not quite the ***** to the wall street legal race car that the original Z06 was.
The Z06 in the C5 packs an LS6 (gen III small block architecture) that produces around 400hp. The car is also lighter than a standard Corvette, and available only in a hardtop.
Rumor has it that the next Z06 in the C6 Corvette (set to debut in about a year) will make around 450-475hp, and that the car will be one of the lightest Corvettes in recent history. Magnesium suspension crossmembers, titanium exhaust, and thinner window glass all contribute, as do carbon fiber body panels in place of fiberglass. It looks like GM has finally decided to try and cook some snake for dinner!
Car: 84Z & Porsche
RPO Codes
Wow, now that's going to be quite a Corvette. Yep, cooked snakes and munched GT-40's. ...but at what price tag?? GM/Chevrolet is doing wonderful things with their Crate Motors also. Almost like an aftermarket speed shop. Thanks for all, ED.
The word on the street is that the new Z06 will carry a price tag in the mid 50s, about where it is now. The base model C6s will still be in the low 40s well optioned. Now that's bang for your buck!
Car: Old man car till I get another 3rd Gen
Engine: at least it's a V8
Transmission: Wrong wheel drive. Makes no difference to me.
Car: 85 IROC-Z Z-28, BLUE & SILVER
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
good site for rpo codes:
http://www.angelfire.com/ny2/96transam/rpocodes.html
http://www.chevy-camaro.com/
I thought he had an 87.
