tbi turbo
Old Jan 22, 2004 | 10:21 AM
25thanniversary's Avatar
Car: 92 rs
Engine: 305tbi
Transmission: 4l60e
tbi turbo
anyone have any tbi turbo pics? comments?
Old Jan 22, 2004 | 12:17 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
it would look the same as a turbo system with a carb. except with a slightly different fuel system and engine management system.
Old Jan 22, 2004 | 08:47 PM
jon_volk's Avatar
speaking of tbi turbo....i was bored at work and got thinking. Import guys have been using aditional injector setups right before the throttle body w/ turbo setups for years with good results. What about using a 749 ecm to control the tbi unit under boost and program one or two of the unused injector outputs to control auxillary (sp?) injectors under boost?..or even use a megasquirt diy ecm to control it? I mean my TBI has been firing up instantly in the recent single digit temps we've been having. Also being able to use an adapter plate for the tbi to use any 4bbl intake i would think this could make an affordable injection setup that would probably be slightly more driveable than a home built blow through carb.
Any thoughts?
.02
Old Jan 22, 2004 | 10:38 PM
mw66nova's Avatar
Engine: 7.0L
i've been thinking a very similiar deal lately, except with a 144 blower with a tbi ontop. all very feasible, just gotta do it.
Old Jan 22, 2004 | 11:00 PM
jon_volk's Avatar
im just wondering what there would be in power diff between a twin turbo blow through 650 holley dp and say a 454 tbi unit w/ one or two additional inj. before the throttle body. i guess no ones really tried it yet.
Old Jan 26, 2004 | 10:35 AM
Car: 92 rs
Engine: 305tbi
Transmission: 4l60e
i wanted to use two mitushibi turbos im going to fabricate the manifolds any one think of any problems i might run in to?
Old Jan 26, 2004 | 12:18 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
use this as a guideline for fueling etc
https://www.thirdgen.org/techbb2/sho...&highlight=TBI
Old Jan 26, 2004 | 03:06 PM
jon_volk's Avatar
how much boost do you want to run? I wanted a lil more info just to satisfy my curisosity and emailed ATI for a part number on their tbi bonnet. .....heres their reply.
"If you are going with low boost ( less then 9psi ) that bonnet will work
perfect. Though if you are going for more then 9psi you will want to go
with something other then that, due to flow reasons. The part number is
AM010A-1 $195 retail.
ATI"
Old Jan 26, 2004 | 06:45 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
ATI"
yep pretty much, that about covers it. low boost only...
BTW nobody buys anything retail as listed by ATI.
If you decide to go with a ATI instead of a turbo. Find a nice dealer. tell him what you want to do, tell him to order the kit from them with the FMU for a third gen but with the FMU ratio for a TBI truck (with a 305?) ask them to add the bonnet and an extra 90 degtree bend, tell them to keep the TPI throttle body inlet tube. and finish it up on your own with a locally sourced piece of pipe or two.
92firebirdguy
Sep 1, 2016 07:53 AM
New2Chevy
Sep 28, 2015 12:35 AM
Glowsock
Sep 11, 2015 11:09 PM
92rsvortec350
Sep 10, 2015 10:54 AM
Wylecoyote08
Sep 8, 2015 08:26 AM
