I wonder what a Wonder bar is...
Old Feb 1, 2004 | 07:52 PM
MYBLUZ's Avatar
Car: 1991 Z28 1LE A.K.A The blue rocket
Engine: Blown 383
Transmission: Full manual 700R4
Just looking around at some threads and came across a few pics of a Wonder bar and I'm not sure of its purpose. Is it basiclly like a strut tower brace, so the front end is stiffer when the steering is turned, so the front doesnt push against itself?
Old Feb 1, 2004 | 08:11 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
exactly, its a stb for underneath. it connects the front of the sub frame. it also helps prevent stress cracks caused by the steering box
Old Feb 2, 2004 | 12:25 PM
MYBLUZ's Avatar
Engine: Blown 383
And some cars came from the factory that way? Which cars? My car is a 1LE Z28 and it doesnt have one. Anyway that was what I was assuming so, thanks for the info.
Old Feb 2, 2004 | 03:35 PM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
All Irocs, and 91-92 Z28's
Old Feb 3, 2004 | 02:12 PM
MYBLUZ's Avatar
Engine: Blown 383
well I guess GM forgot mine.
Old Feb 3, 2004 | 02:37 PM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
Thats strange, most people with 91-92 z28's have them. Maybie a previous owner removed it to put on another car.
Old Feb 3, 2004 | 03:51 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
didnt come factory on any non IROCs is the general consensus.....
athough some people do say theirs came with it, the number is low enough that someone could have just put it on before them.
Old Feb 3, 2004 | 04:39 PM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
Maybie a few of them got the wonderbars to get rid of the leftover stock?
Old Feb 3, 2004 | 05:18 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
as far as i know, only irocs got them. my car has the 36/24 sway bars, but i didnt have one stock but its a bird so who knows
Old Feb 3, 2004 | 06:29 PM
Kontrax's Avatar
Car: 86 Camaro
Engine: L98 350 bore .060 out, Carb power
Transmission: slusher 700 beatbox
ive had 2 irocs and they didnt come with one. ive owned 6 thirdgens and none ever came with one... so i went out and bought one
Old Feb 5, 2004 | 02:33 PM
MYBLUZ's Avatar
Engine: Blown 383
I bought my 91 Z from the original owner. He wouldnt have taken ANYTHING off the car, extremely ****. The question is are they even worth it? My car is in excellent shape, and there is no sloppyness in the front. As far as having one to prevent the unibody from cracking aroung the steering box, is it common on F-bodys to crack there? News to me if it is. Although my car was starting to crack on the top of the pass. door, on the top corner where the roof meets the window sill. The car is in the paint shop and has been fixed. But it makes me nervous to think it cracks there possibly
Old Feb 5, 2004 | 03:52 PM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
For the $20 or so they cost it certainly isn't going to hurt anything. I didn't notice much of a differance when I put mine on, but someone people say they noticed a differance. Then again my shocks struts and springs are shot so nothing short of replacing those parts is going to help the handling much.
Old Feb 5, 2004 | 09:31 PM
Kontrax's Avatar
Car: 86 Camaro
try adding the wonderbar and the strut tower brace and drive around for a year. then take them off, im sure you will say your front end is sloppy. you just used to not having them
Old Feb 6, 2004 | 06:43 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Here's what one looks like.
When I added it to this car, it noticeably tightened it up. It didn't affect the steering per se, it more affected the general feel of "togetherness" in the front end of the car. When the car hits a bump especially while turning, it feels much more solid and rigid now.
I would really like to get a strut tower brace, but there are very few sources for one that will fit my car (HO); some one of htese days I'll maybe get motivated and do something about it.
Old Feb 6, 2004 | 03:32 PM
Kontrax's Avatar
Car: 86 Camaro
fit your car? you carbed? edlebrock is the only company out that makes one to fit carbed or tbi cars. they go for 129 outta jegs. i bought one myself and never used it because i got a blower.
Old Feb 6, 2004 | 03:40 PM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
Want to sell it?
Old Feb 6, 2004 | 05:46 PM
MYBLUZ's Avatar
Engine: Blown 383
Why couldnt I just weld in a piece of tubing? Why does it need to bolt up if I never plan on changing it. And I know what most of you are going to say, what if you need to remove it later. When I say weld it I dont mean weld the crap out of it, you wouldnt need that much weld to make it hold, something that you could get to with a cutoff wheel and get it out in a few min.??
Old Feb 6, 2004 | 05:59 PM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
Why not just spend the $20 and get the wonderbar.
I don't see where you could weld it to without welding the swaybar as well.
Old Feb 6, 2004 | 06:15 PM
Kontrax's Avatar
Car: 86 Camaro
well if you dont weld it in good its going to break from the stress when turning. plus, what happens if you need to pull the motor? cant just keep cutting and welding it back togeather, get sloppy after a while. just buy one, thay are in expensive and very effective.
will i sell it? sure i guess, i took it out of the box, laied it over my motor to see the fit, then put it back in to box and forgot about it. PM me and we'll talk.
EDIT: ohhh i thought you were talking about welding in the strt tower brace... you really cant weld it in since it sits up under the sway bar. and you really cant weld it to the frame since the steering box is in the way. i still think youd get stress cracks in the weld also.
Old Feb 6, 2004 | 06:32 PM
MYBLUZ's Avatar
Engine: Blown 383
Just $20 huh, I am more inclined than the next guy to just build everthing myself, because I'm a fabricator, well I used to be. If its 20 bucks I guess I'll buy one. As far as control arms, STB, panhards, and torgue arms go, I'll make my own. Its not that I'm cheap,nothing but the best for my Z, its that I like to build it myself if possible. Makes the mod more worthwhile to me if I can make it,and or install it myself.
Old Feb 6, 2004 | 06:35 PM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
Well if you insist on making your own wonderbar you could make your own bolt on and probably make it stronger than the factory one.
Old Feb 6, 2004 | 06:52 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The Edelbrock one doesn't fit the HO air cleaner, which will stay on my car, period.
A guy on these boards, seems like his userID was MRZ28HO, used to make them, that would fit. His userID would be a clue to why he made them that way. I don't know if he's still making them or not.
The factory wonderbar (what's in my pic) bolts on under the sway bar brackets. Piece of cake to install. I don't think I'd want anything stouter than it though; seems like the less weight I could hang out there right on the absolute nose of the car, the better off I'd be.
Old Feb 6, 2004 | 09:20 PM
MikeS's Avatar
A little ways up, somebody asked if cracking around the steering box is a common problem...
I can't say if it is common or not, but I have experienced a fairly severe case of it. That was in my previous 84. While the steering wheel was being turned, you could watch the steering box and frame area surrounding it flex and move. That's why the wonderbar was the first thing I added to my latest car. So, maybe not a common problem, but it does happen.
Old Feb 8, 2004 | 11:06 AM
Pat Hall's Avatar
If your car gets cracks in the roof, you need to fab yourself up a set of subframe connectors for it. Those cracks are usually caused by a good, torquey motor twisting the unibody. My buddy has a 90 Iroc hardtop with the 350 and his has the same cracks in the roof on both sides.
Old Feb 8, 2004 | 04:43 PM
Kontrax's Avatar
Car: 86 Camaro
[QUOTE]Originally posted by Pat Hall
If your car gets cracks in the roof, you need to fab yourself up a set of subframe connectors for it. Those cracks are usually caused by a good, torquey motor twisting the unibody. My buddy has a 90 Iroc hardtop with the 350 and his has the same cracks in the roof on both sides. [/QUOTE
i dont think ive ever seen a v8 fbody without the cracks on the roof
Old Feb 9, 2004 | 10:16 AM
Pat Hall's Avatar
i dont think ive ever seen a v8 fbody without the cracks on the roof [/B][/QUOTE] Really? I guess my car would blow your mind then. It's a V8 and doesn't have any cracks in the roof at all. Of course it's also a T-top car.
Old Feb 9, 2004 | 10:31 AM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
Strange, I have yet to see an Fbody with cracks in the roof
Old Feb 9, 2004 | 12:11 PM
MYBLUZ's Avatar
Engine: Blown 383
My car had on small crack starting, about a 1/4 long, and its not a T-top car. Here is a list of stuff I'm planning on fabing as soon as it gets out of the paint shop ( Dirty little F-ckers keyed the wing, and typical GM paint flake on the roof). SFC, Wonder Bar, STB( will have to design something to get around the HSR) Contol arms, torque arm, panhard bar. With exception of the torque arm, it will be cake. Now that I think about it, that saves my alot of $, more to spend on going fast.
Old Feb 9, 2004 | 12:50 PM
Pat Hall's Avatar
Believe me, I wish I would've paid more attention in metal shop when I was in school. Fabbing all that stuff up yourself should save you quite a bit of cash!
Old Feb 9, 2004 | 08:05 PM
Kontrax's Avatar
Car: 86 Camaro
prob would blow my mind. is it a 350? my gta was a 305 with a stick and the cracks were huge, my irocs were both 350s and had big cracks on them as well.
Old Feb 11, 2004 | 05:16 AM
86WS6_T/A's Avatar
Car: 2003 Mach 1
my friends 86 bird had the stress cracks in the roof. And his was a 2.8... lol
Old Feb 11, 2004 | 10:35 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
at is a incorrect statement MAC sells a STB that fits a TBI or Carbed F-Body.i paid alittel less than $90 for mine.
click here
price has gone up alittle since 2000
Old Feb 11, 2004 | 12:22 PM
MNformula350's Avatar
I had a 87 hardtop Firebird 2.8 auto same thing.
none on my Formula or Iroc but those are both t-tops
Old Feb 11, 2004 | 06:08 PM
Kontrax's Avatar
Car: 86 Camaro
click here
well excuse me, just going by what super chevy mag said
Old Feb 12, 2004 | 11:01 PM
fisherbody86's Avatar
Car: 92 Z28 heritage
Engine: 5.0 TPI
as far as the cracks in the roof issue goes, here is what I had on my thirdgens.
86 TA, 305 5 speed=when I bought it, no cracks.
kicked its a*s for 3 years, developed cracks
89 IROC, 350 auto=when i bought it, it had cracks
never drove it, had frame damage
92 Z28, 305 5 speed= when I bought it, no cracks
in the process of kicking its a*s right now
will report back when crack develop
My conclusion: you kick a third gen's a*s, the roof will develop cracks.
Old Feb 13, 2004 | 06:16 AM
91banditt2's Avatar
Engine: 5.7 HSR
wow that made sound like a real *******
sorry that wasn't pointed at you it's just hear alot of people complain about their limited choices for STB for TBI and carb.this STB from MAD will also fit a TPI car.
Old Feb 15, 2004 | 01:43 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
My car has cracks in the paint on the roof... mainly directly behind the T-bar on the roof. My HO motor started it while the old owner had it I guess, and my 350 made it worse, lol.
Time for SFCs i guess.
Old Feb 15, 2004 | 01:57 PM
Camaro_nut's Avatar
So the crack on my T top roof ( P/S top corner) is from
the motor? I have an LHO motor(140hp). I don't think
that was from the massive torque of the motor, but I also
have a lot less roof than a hardtop IROC. I think Camaros/
Firebirds in general just flex a lot to cause cracks in the
roof area. So, yes it does make sense to correct the
factory problem by adding SFCs.
Old Feb 15, 2004 | 01:59 PM
Camaro_nut's Avatar
I got the same issue. I had put in SFCs. Seems no worse
now in that area. Glad I added them in before I drop in my
GMPP 350.
Old Feb 19, 2004 | 09:19 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
I've just put the TDS Steering Brace on sale for $42 (normally $50). Available only in gloss black powder-coat at this special price. Here is a link to the TDS Steering Brace GP.
Lon Salgren
Top-Down Solutions
__________________
90 RS Convertible
88 Iroc-Z Resto-Project car
Owner: Top-Down Solutions
web site: www.Top-DownSolutions.com
Old Feb 19, 2004 | 01:42 PM
Frains90RS's Avatar
Car: 1990 Camaro RS
Engine: LO3: 305 TBI
Axle/Gears: 1997 Trans Am rear w/ posi -3.23
Lon Salgren
Top-Down Solutions
Looks like the high popularity of the wonderbar has increased the optional finishes. I guess I can no longer say my black bar was a "special order."
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
