Fabbing motor mount brackets
Old Feb 16, 2004 | 07:10 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
I have made mock ups of the motor mount brackets I need (going from the block to mounts). I belive that 1.8" steel should be strong enough, as it was the same thickness used in the 2.8 brackets. Do y'all think this will strong enough for the 3800, or beef it up some? Pics as son as I find the links to them.
Also, what are going rates to have these fabbed up?
Old Feb 17, 2004 | 04:53 AM
ede's Avatar
ede
.125 is pleanty strong
Old Feb 26, 2004 | 09:11 AM
Engine: 5.7 / 7.4
having brakcets made, should be done friday or saterday. I'll post pics for everyone. Gona be most likely the 1/8" thick metal w/possible double thickness in areas for strength.
Old Feb 29, 2004 | 08:33 AM
Engine: 5.7 / 7.4
Got the brackets, $80 & worth it.
Drivers side
Pass side
yeaf, not painted yet, but made sure they'll fit block & mounts. Then gonna prime & paint.
Old Feb 29, 2004 | 09:18 AM
ede's Avatar
ede
why did you have to get a set made? wouldn't factory piece work?
Old Feb 29, 2004 | 11:26 AM
Engine: 5.7 / 7.4
The 2.8 brackets used on the 3.4 weren't wide enough & of a stamped one peice design. As far as the 4th gen brackets, .....well.....
slight size difference
ZMWojnar
Brakes
May 12, 2019 10:43 PM
E Rod
Aug 28, 2015 05:17 AM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
