83 Stock Headers?
Old Feb 26, 2004 | 07:20 AM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
83 Stock Headers?
Are these stock headers for an 83 LG4?
Old Feb 26, 2004 | 07:34 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Those aren't headers, they are manifolds. None of these cars came with anything even dimly resembling headers.
Those do look rather like LG4 ones, with their miniscule outlets.
Old Feb 26, 2004 | 07:37 AM
conlinj's Avatar
what are the numbers on them? easiest way to tell
Old Feb 26, 2004 | 11:05 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
I'm not sure they're "stock".
The driver's side A.I.R. valve points to the rear. Stock LG4 would point to the front, if '83's are like my '86's.
But, the passenger side has the flat flange for the EFE valve. I didn't think TBI used that, but I don't know for sure about that.
There should also be a heat "stove" around the driver's side for LG4.
So, I'm not sure what those may have come off of.
Old Feb 26, 2004 | 01:18 PM
430T/A's Avatar
Car: 71 Skylark
Engine: BBB-430
Transmission: M20
could ther possibly be a crappier design for an exhaust manifold???? no wonder LG4s are gutless wonders, 145 horse!!!!! WOOOHOOOOOOO!!!!
Old Feb 26, 2004 | 01:31 PM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
my '82 driver side AIR tube pointed to the rear. but mine also had the THERMAC crap on it
Old Feb 26, 2004 | 02:31 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Those in the pic used to have the Thermac heat stove on them; it's just been stripped off. All carbed cars (which those obviously are for, since they have the heat riser provision) have had the Thermac since the late 60s. In fact I think you can still see the ghost of it, in the pattern of clean vs dirty rust on the central part of the driver's side one.
Old Feb 28, 2004 | 11:14 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
I remember those stupid AIR tubes on my 84 Z28... I cut them, then pulled them out and tossed them... only to find that bolts to fit those holes are:
Hard to find
Expensive
and like to fall out a lot lol
Old Mar 10, 2004 | 12:33 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
remember tat 80-up car 305 manifolds are two stud outlet design and 80-up truck 305 manifolds are three stud outlet design, but otherwise identical manifodls
Old Mar 10, 2004 | 05:47 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
Hard to find
Expensive
LOL I did the same thing on a 67 chevy P/U with a 307, 3 on the tree. But I just crimped off ht hoses after cutting them.....(dualing banjo's plays)
Old Mar 10, 2004 | 11:09 AM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
When I took the tubes out of my 88's exhaust manifolds I went to a hardware store and found plugs no problem. I can't remember the size but they were cheap and worked great. I have since thrown the manifold in the trash or I'd see what size the bolts were. Oh well....
Now I have problems with my edelbrock TES headers because I have the tubes cut and plugged with screws and JB weld lol. Next time the headers are off they are getting welded.
Street Lethal
Apr 30, 2019 12:14 PM
italiano67
Dec 11, 2016 09:21 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
hectre13
Sep 8, 2015 03:38 PM
sreZ28
Aug 14, 2015 07:48 PM
