I went with the R/A I hood........
Old Mar 14, 2004 | 04:20 PM
War_Eagle's Avatar
I ordered the R/A I hood from Rex about a week ago. I thought it went better with the lines on my 86 T/A than the more aggresive R/A II hood. He said I should have it this week. The free drawing every month is awsome. Question on the fiberglass hoods, Do you need to install insulation on the underside, like the original? Also do you use the original hood supports with fiberglass? They seem kind of stiff??? I hope to have pictures of the installed hood soon. Thanks.......
Old Mar 14, 2004 | 04:23 PM
nolanr0413's Avatar
Car: Trans am
ok i got the answers on this one. No you dont need the insulation , i didnt notice any difference with out it, but i also have a loud car so i dont mind. THe struts you either need ones that are week and wont hold a metal hood up . Or do what i did and go to gm and buy hood struts for a 82 camaro with a fiberglass hood.
Old Mar 15, 2004 | 08:07 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I am using the original shocks, but I am really carefull when I open and close the hood.
RA 1 is a good choice.
Old Mar 19, 2004 | 05:09 PM
War_Eagle's Avatar
I just got my free raffle hood from Rex, and I am very satisfied. Nice white gel finish, just a few small places to touch up, but it is an awsome hood. Going through the process of fitting it in place. Its not that far off, and I think some of that may be due to 18 year old hinges that have some play in them. I am also going to open the back of the hood up next to the wipers, as this area is closed and make the air inlets (nostrils) in front functional for a good air flow front to rear. If anyone else has done this please reply. Thanks again to everyone and once again Rex:hail:
Old Mar 19, 2004 | 08:53 PM
scott's85T/A's Avatar
I cut holes in mine befor I put it on for better air flow,,
Attached Thumbnails I went with the R/A I hood........-underhood1.jpg
Old Mar 19, 2004 | 10:28 PM
my84firebird's Avatar
Car: 1984 Pontiac Firebird
Engine: modded 5.0
Transmission: modded 700r4
Excellent choice on the RA1 hood. I prefer it over the RA2....
Old Mar 20, 2004 | 07:44 AM
War_Eagle's Avatar
Scott, is that insulation on the underside of your hood? what type is it? It looks like the heat shield/ sound proofing type used on interiors. Looks good and I like the way you opened the front for air flow. Thanks for the comments....
Old Mar 20, 2004 | 11:18 AM
here is some old info from about 2 years ago..
I'm not sure if summit still sells it or not.
HERE!!
Attached Thumbnails I went with the R/A I hood........-smallinsulation.jpg
Old Mar 21, 2004 | 02:57 PM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
good choice, the RAI looks like it belongs on third gen TA's.
the RAII on the other hand i think looks like pure ***, its so out of place, it doesn't flow with the car at all, just two out of place scoops.
either way, it should looks great
Derth Deboblo
Exterior Parts for Sale
Mar 22, 2010 03:05 PM
874ME
Aftermarket Product Review
40
Aug 22, 2009 12:00 AM
123jon321
Jun 6, 2004 11:00 PM
Adam89F
Sep 24, 2001 06:43 AM
