Hooker 2055 Install question
Old May 6, 2004 | 03:31 PM
fast86z's Avatar
Car: 1984 Pontiac Trans Am
I am going to install hooker 2055 headers and was wondering how hard it will be? I do have experience with putting headers on, but I want to know if i will have to worry about other mounts, etc. being in the way to install the headers? All input is greatly appreciated. The headers are going on a stock carbed 305.
Old May 6, 2004 | 07:54 PM
25THRSS's Avatar
Mine slid right in from the top, but i did have to slightly bend one of the brake lines with my hands.
Old May 6, 2004 | 08:31 PM
fast86z's Avatar
Did you still have the emissions (AIR) stuff on your car?
Old May 6, 2004 | 08:32 PM
25THRSS's Avatar
no, i cut the tubes off and welded them shut. Shouldn't be a problem though even with them on.
Old May 6, 2004 | 09:25 PM
fast86z's Avatar
Old May 7, 2004 | 12:49 AM
ksrammstein's Avatar
Car: 1984 Pontiac Trans Am WS6
Engine: H.O. 305 5.0L;L69
Transmission: T-5; Axle Ratio 3.73
Just finished mine about ten minutes ago...headers fit fine. I only had to take out the dip stick. Real easy! They pain in the u know what are the spark plugs...they were hell
Old May 7, 2004 | 01:09 AM
FruityOne's Avatar
Car: 1989 TransAm GTA
Engine: One sweet modified 355 TPI.
Transmission: The kind that shifts....
Yay, PITA spark plug change jobs.
Its a PITA with the stock manifolds and A.I.R. tubes. Is the plug change worth with the headers?
Oh yeah, I can't help myself. I just ordered my headers from ACS (one of our sponsors). Hooker 2055's, AIR tubes cut-off. Gun Metal Grey (satin) finish, coated shorties and Y-pipe for $495, thidgen discount, and gift certificate.
Lots of money, but I feel good. Cause now i have a completely coated setup.
Old May 7, 2004 | 02:28 AM
thecoolone's Avatar
Car: 89 GTA
How much of a pita was it working around the air conditioning stuff?
Old May 7, 2004 | 09:44 AM
FruityOne's Avatar
Ughh....don't mention A/C and Smog stuff. I swear, GM could have figured out a way to make it cleaner in the engine bay.
Old May 7, 2004 | 10:00 AM
Dewey316's Avatar
Car: 1990 Camaro RS
I just unbolted the whole acccessory bracket on that side of the engine, and moved it enough to slip the header in.
Old May 8, 2004 | 11:52 PM
How did you guys modify that bracket...i have a hack saw but its a PITA...is a plasma cutter the only way. If so do you think a shop will do it for like $5 or something?
Old May 9, 2004 | 12:29 AM
jgifford's Avatar
Car: 1986 Z28
Engine: 355TPI 380hp
Transmission: Rebuilt 700r w/ Transgo Shift Kit
I just used a cutting disc on an air compressor to cut the right leg off of the bracket. Used a bench grinder to smooth the cut, and then used one of the manifold studs to mount it. Everything worked out perfect. No clearance problems and it all lined up.
Old May 27, 2004 | 03:53 PM
ZROC86's Avatar
Car: 1999 Trans Am WS6
Transmission: A4
FruityOne: How did you get that discount stuff for the ACS Headers?
Old May 27, 2004 | 11:09 PM
ssxmac's Avatar
Car: 89 RS
Engine: lo3
Transmission: 700R4 w/ B&M shift improver
Axle/Gears: 3.27 9-bolt posi
The furthest back bolt on the passenger side right next to that heater/ac box was a b!tch to get out. make sure you soak em in blaster. Instructions said you had to jack up that side of the motor, i just slid mine in from the bottem w/o jacking the motor up. worked ok. I'm not running any of those brackets anymore either. They offer little to no actual support for the accessories, Someone told me they are only there to limit vibration. Mine are off, doesnt look like the engine vibrates more than it used to.
-chuck
Old Jun 12, 2004 | 01:35 PM
FruityOne's Avatar
I got a gift certificate because I did some signature work for ACS. Thirdgen.org owners also get a discount simply by contacting them through thirdgen.org I was told.
In any case, I know for a fact they have a set of stearling silver coated hooker 2055's w/o A.I.R tubes. I just talked with them on Friday.
Summit took its sweet time getting the headers to ACS for coating though. They are shipping to me this Monday though.
Old Oct 5, 2004 | 06:24 PM
Avenger007's Avatar
Car: 88 Firebird
Engine: 350 LO5 TBI
Transmission: 700R4 Vette Servo/Shift
Did you have your y-pipe coated too? I heard that after the third-gen discount a coated 2055 and coated y-pipe (with AIR tubes reversed??) cost around $600. Do they need to be reversed on an 88 bird with TBI? Also, is it cheaper to just have them remove the AIR tubes
Frozer!!!
Jan 19, 2024 04:55 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Vintageracer
Jan 10, 2020 05:33 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
