converting hard top to t-top
Axle/Gears: 9-bolt/3.45
It wasn't uncommon with the thirdgens either. Dealers sent many out to local shops to be converted to t-tops. But it was expensive, and it's probably a lot more today. And I'm not even sure you'd have an easy time finding a shop that will even do it anymore.
I wouldn't even know where to begin looking. I guess local body shops might be able to direct you. Maybe even a local dealer knows of someone, maybe even someone he's used for other custom conversions.
So it's possible. Good luck and happy hunting.
there was a thread about this a while back. this is the only shop that i know of that will do it (or at least do it right)
http://www.markscustomkits.com/T-top_Conversion.html
Car: IROC Z
Engine: 5.7
you need a t-top car roof and to feather the layers of sheetmetal on the posts and then lower and weld. someone on here has pics of him doing it in a large pop up garage with a big cherry picker
Car: GM & Jaguar
Engine: Various
Transmission: Various
Axle/Gears: Various
Fatal88 converted a hard top to a t-top, then from a t-top to a convertible! So it can be done! You could either use a kit or the gear from a donor car. Just don't forget the SFC's
Car: 92 Z28
Engine: Boosted LSX
Actually if your starting with a hardtop, using a vette targa would be easy...
I started as a T-Top and went Targa Top.
The T bar spot welds wre drilled out. and then 2 pieces had to be cut. I was in the doing the Top out of a Mold and 1 piece carbon fiber top. That was gonna be painted body color. Along with a Lexan smoked one.
Well a local buddy insisted on doing the same thing. So I decided to go vert. I had a Totaled 91 RS vert I took all the parts from. YES its fully functional as if the factory did it.
Ive done everything myself. So if your skilled YES it can be done. Done right and done cheap. if you pay a Shop to do it then its prob gonna cost alot.
Car: 92 Z28
Engine: Boosted LSX
Originally posted by ScrapMaker
it looks like you chopped off the a-pillars too in the picture
http://www.cecoatings.com/images/Car...s/DSC01188.JPG
Car: 2000 Trans Am WS6 (Black)
I guess I used the wrong word... I meant Side Pillars....
if you are converting it from t-top to targa... wouldn't the "pillar" where the 6x9's are still be there?
nm I that you are going vert... but I'm curious, where does the top lay when its dropped? does it fit in the trunk or sit like a jetta, or a vwbug?
Car: 92 Z28
Engine: Boosted LSX
I was about to say Re-read what I typed.. Went To Targa Then desided to just go all the way.
The top lays right behind the back seat rest like any other 3rdGen vert.
Car: 92 Z28
Engine: Boosted LSX
To be honesy not much was hard at all. The latch up top/front is only a Diff bracket. You unbolt the 2 t-top ones and bolt in the vert ones.
The complete inner structure of a vert got cut out and basically droped in and welded it up.
I already had SFC's and the Cage in as a Targa top so cutting it was no problem. Then I just redid the back roll bars for the top to still drop.
All in all the Vert part of it was done with in a weekend.
Car: 92 Z28
Engine: Boosted LSX
do you have any pics of the top actually attached?
btw nice dash swap! I bet that took you longer than the vert conversion
No the dash swap only took a day actually.
The 4thgen door panels are what will take a little longer then anything because Im remolding the door handles because of the cage side cars.
nice... did you have to modify the ducting at all for the 4thgen dash? also I would assume that the "gaps" you see in the dash are just missing panels?
Car: 92 Z28
Engine: Boosted LSX
Im taking the 4thGen a piller plastic and the 3rdGen ones and grafting em both together to make a mold. This way I can make a set to look factory and cover the side defor vents and pillars.
The middle vents will get my fp ,boost and ?? gauges
The radio and hvac are missing right now also. but all will be put back.
Car: 92 Z28
Engine: Boosted LSX
What gaps are you talking about? The top dash pad isnt on in the pictires. and the Gaps beside the pillers will be on ANY 4thGen swap unless you make something to cover then and fill the area.
I belive fatal88 has some good pic's of how He covered the area.
I got ya, the dashpad covers all that space... and the only space that it doesn't cover is on the sides along the door hinges?
ambainb
Apr 25, 2016 09:21 PM
