Found the problem!! (carnage inside)
Old May 22, 2004 | 12:21 AM
oldblueZ's Avatar
Car: 85 Z28
Engine: 305 TPI (dead) -> building 355
Transmission: 27 spline 700R4 (another one died) -> T5 goin in next
The 305 decided to spit out a few connecting rod bottoms through the oil pan the other day. Here is the carnage.
If they don't show up try http://oldbluez.cz28.com for pics.
Now I just have to pull the 305 and see what else is destoyed, and make more trophies!!
FYI, a 350 is planned for replacing the 305, so not all is lost and old blue Z will be on the road again.....one day. I'm hopin to have the new engine and T5 in and runnin by October.
-Jesse
Old May 22, 2004 | 12:47 AM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Well, it'll make a good paperweight.........
Old May 22, 2004 | 06:54 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Found the problem!!
Doesn't seem like that would take much searching to locate....
Old May 23, 2004 | 08:39 AM
84 Restore's Avatar
Car: 1984 Z28 camaro HO Gun metal Gray
Engine: 305,L69 H.O. rebuilt
lmao
yOUR kILLING me
Old May 23, 2004 | 09:10 AM
THEGENERAL's Avatar
i bet that made one heck of a noise when it went ......
nothing but a boat anchor now..lol..
good luck on the 350 thou sounds like youve got your hands full now
Old May 23, 2004 | 09:13 AM
RebelTillDeath3's Avatar
Car: 92 Camaro
Put some duct tape over that hole.
Old May 23, 2004 | 09:34 AM
ksrammstein's Avatar
Car: 1984 Pontiac Trans Am WS6
Engine: H.O. 305 5.0L;L69
Transmission: T-5; Axle Ratio 3.73
I have never seen anything like that before!
Old May 23, 2004 | 09:41 AM
ede's Avatar
ede
so what exactily is the problem?
were you running factory rod bolts?
Old May 23, 2004 | 12:22 PM
oldblueZ's Avatar
Car: 85 Z28
The problem
That is a stock (internal) 305 TPI with 175,000 miles and bolt ons that ran close to 13 second 1/4 miles that I loved to play with. When we replaced the intake last time, it started to develop oil pressure problems. I'm guessing a small amount of coolant got into the oil and messed up a bearing or two and caused the rod knock..... despite changing the oil.
I parked the car when the knock developed. The sound was so loud that with the car started, you could hear the clanking from inside my apartment with the TV on. My exhaust wasn't nearly that loud.
My plan was not to move the car until the trailer came to move it to my parents house to start the swap/build. That didn't happen because the apts had construction and forced me to move or pay $150 tow fee + $1.50/mile charge. When I moved it back to the original spot, the bottom end decided to just let go.
Well, I'll have more pictures of the carnage in the future, including that piece of rod sitting on the crossmember.
The original plan was to build the 350 and blow it up with an NOS kit my buddy has on his shelf..... never did get to do that... sniff.
-Jesse
Old May 23, 2004 | 12:43 PM
2.73's Suck's Avatar
Car: 1985 Mustang GT
Engine: hamsters
Transmission: a hamster wheel
cool
Old May 23, 2004 | 02:19 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Ive got one just like that sitting behind the shop from a customers IROC, biggest pile of crap IROC I might add. Funny because he asked my how did this happen to his engine and was thier anyway to fix it cheap.
Sound like your 350 build might need some ARP bolts all around.
Old May 23, 2004 | 04:31 PM
84 Restore's Avatar
huuuummmm
I think he has a hole in his oil Pan. not sure
Old May 23, 2004 | 04:33 PM
84 Restore's Avatar
Sorry OldblueZ
I am sorry! I had to interject theses guys kill me
We all feel the pain
Old May 23, 2004 | 09:09 PM
oldblueZ's Avatar
Car: 85 Z28
Re: huuuummmm
I think he meant "so what exactily WAS the problem?
I'm just messin with ya 84 Restore.
Yeah, about that hole... I'm going to use duct tape and some JB weld with sheet metal conformed to the pan. Cuz I am drivin around in a V6 TPI right now!!
(yes, I'm kidding)
While it hurts, this is a good pain though.
I'll be using ARP bolts all around for the new engine.
-Jesse
Old May 23, 2004 | 11:20 PM
cormyr's Avatar
Car: 89 Formula 350 WS6
Engine: 383 miniram
ooh. that looks painfully familiar.
Old May 24, 2004 | 11:41 AM
Damon's Avatar
That's SWEEEEET. Sorry it let go, but at least you knew about it and were prepared for the inevitable.
What kinda RPM were you turning when she let go? Was it just tooling through the parking lot near idle or were you................ well, ............. "helping things along" with liberal throttle applications? Be honest.
Old May 24, 2004 | 11:58 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
i think its kinda obvious that he was going faster then idle. lol..
i might have pics up soon too... one of the cars im playing with has a horrible knock.
a friend of mine just fragged his 79 firebirds motor, so i might barrow his nitrous system and go frag a 305.
Old May 24, 2004 | 02:17 PM
pvt num 11's Avatar
Car: 1989 TTA
Engine: LC2
Transmission: Worn-out 200R4
Axle/Gears: BW 9-bolt, 3.27's
Nothing quite like 'helping' a dying motor put its last foot into the grave, huh? I wonder - how impossible would it to rebuild a grenaded motor like that? I mean, I realize it would need a total teardown, magnafluxed for cracks, prbably a lot of new reciprocating components, but... could it be done? (Not that I want it - I'm happy with my L98 thank you...)
Old May 29, 2004 | 09:55 PM
blacksheep-1's Avatar
Car: 83 Z28
Engine: vortec 305 for now
Transmission: 5 speed
I had a DZ302 once that spit a rod out of the side of the block, it left the piston up in the bore. Tha car started and ran good enough to pull it up on the rack. I was kind of proud of that.
Old May 30, 2004 | 12:15 AM
Confuzed1's Avatar
Car: 83Z28 HO
I've never seen one that threw a rod that was "saveable". Normally the piston ends up in pieces, rod hits the bottom of the cylinder, puts a nice crack up to the head, Crank journal gets banged up good.
Not too much left that can be saved or trusted....again, it's a paperweight.
Old Jun 1, 2004 | 06:55 AM
Car: 83 Z28
Once the rods are out, I've never seen a block salvageable after that. There are some aluminum blocks that have "windows" in them that were welded up though, I guess it just depends on where it was hit and the cost of a new block.
Old Jun 1, 2004 | 08:27 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
ive seen the heads survive several times.....even though the rod distroyed the bottom end.
Old Jun 1, 2004 | 11:12 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
That's because the piston is usually going down on the power stroke when the rod lets go & continues down into the crank.
Thirdgen89GTA
Aug 20, 2015 12:11 PM
92camaroJoe
Aug 13, 2015 06:07 AM
bjpotter
Aug 12, 2015 06:06 PM
Fronzizzle
Aug 9, 2015 01:15 PM
antares57
Aug 6, 2015 07:47 AM
