Can we sticky these?
Car: 84 Berlinetta
Engine: junk 350
Axle/Gears: Moser 4.56
Trickster, I see all kinds of questions asking about sensors, what they look like, what is this, etc... Can we sticky some of these pics for a reference? If it's not a good idea,, just delete the thread.
Number 1... Passenger head, btw cyl 6&8
Axle/Gears: 9-bolt/3.45
The fan switch you posted in pic #1 is broken. So that might not be a good one to use as a reference.
Car: 1989 Iroc-Z
Engine: 5.7L TPI
I have copied them to my computer and will label them accordingly. Eats5.0's, that is not a bad idea, maybe make a photo gallery of sensors so that board members can search there to see what they look like and get a general idea of there locations
Car: 84 Berlinetta
Engine: junk 350
Scott,, I would have labeled them, but I don't know what they all are..
Trickster, if I don't know what they are, I'm sure there are a bunch of newbies that don't either. Not saying I'm a master mech or anything near that,, don't take it that way. If you can, that'd be great..
LAFireboyd, I didn't know it was broken,, you're absolutely right, I wouldn't use that as a reference either..
Thanks fellas..
Thanks fellas..
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
If you cant stand teh suspense anymore, off the top of my head they are:
1. Fan switch (broken)
2. Knock sensor (also broken)
3. Cool temp sensor for the gauge in the dash
4. FP Pressure switch/oil pressure sender
5. The two in the what looks to be a TPI intake are, I think, the IAT and the CTS for the ECM. Didnt check up on this so I might be wrong...
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Dimented24x7,
You have identified them all correctly with the exception of the IAT. That is the cold start switch on cars so equipped. Sorry I didn't post the proper names of the sensors earlier. I was working on labeling the pictures to put in a gallery. Thank you dimented24x7 for posting them. The IAT would be under the plenum where the MAT is located on some TPI cars that are so equipped.
Car: 88 Camaro SC
Engine: SFI'd 350
Ahhh... guess I know where that is, now. Been a long time since I had a TPI car. No pun intended, but you know what would be trick? If you could compile a tech article that not only had the names of the sensors but did so for the most common f-bodies through the years and showed the location of the sensors for each line of cars. You seem to be quite knowledgable with that stuff... Id definatly like to see that, time permitting for you, of coarse. Most of the off the shelf manuals are crap when it comes to telling where the sensors and such are...
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
1 - fan switch
2 - knock sensor
3 - temp sensor (guage)
4 - ?
5 - ?
Should throw in a pic of the O2 sensor too, and the oil pressure sender for the guage.
2 - knock sensor
4 - ?
5 - ?
Car: 88 Camaro SC
Engine: SFI'd 350
From what Ive been told, some years/models have the pressure switch (or switch for the 'choke' light) and sender combined into one unit rather then the two like the carb/tbi cars have.
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Originally posted by Scottlb9
That one is number 4.
Car: 84 Berlinetta
Engine: junk 350
This is coming out of my 88 IROC, with a 5.7 TPI. I guess I could have been more specific. I have the oil pressure sender (bell) on the rear of the motor, behind the intake. There are two brass fittings that make a 90 degree bend, and then the bell goes in there.
Car: 84 Berlinetta
Engine: junk 350
The other half I <b>think</b> will turn off the fuel pump if the oil pressure goes to zero, like in a roll over. I think the sensor is called a oil pressure & fuel pump switch. P/N 25037045. On an 89, it's called a Oil pressure & fuel pump sensor P/N 10096207.
Car: 84 Berlinetta
Engine: junk 350
Two people have mentioned my broken sensors,, which makes me feel bad enough,, but here's the other ends of them.. Don't know how I"m gonna fix these ends yet,, or if I even need them with the new motor. Fan switch on left, knock sensor on right..
This makes me think,, when I was going to put in the Hypertech cool fan switch,, I was wondering why it wouldn't go in the hole,,, Stupid me was trying to put it in the knock sensor hole..
Car: 1984 Pontiac Trans Am WS6
Engine: H.O. 305 5.0L;L69
Transmission: T-5; Axle Ratio 3.73
i guess you could get some good conections from a junk yard car then solder them in.
Plus a book like that would be priceless..especially for us newbies and people whose cars have been tampered with by stupid previous owners.
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Car: 84 Berlinetta
Engine: junk 350
Trickster... I could probably manage that, depress the little thingy, and just pull the wire out and replace. I may even have a small enough screwdriver to get in there..
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hello Eats5.0's,
I do a lot of wiring on cars from time to time and have gotten a set of the pin insertion and removal tools to help in this process. You can find them at NAPA and some of the other parts stores for a rather reasonable price.
Car: 92Rs 25th ann
Transmission: auto
in pic #1 my engine is missing that(L69) is that also a fan sensor or something on my 305 carb,its gone and the sensor by the front by the alt what is that,cause its there but not connected to anything
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hello 408maro,
The item shown in the first picture is a coolant fan switch. The item you are talking about being near the alternator on your 305 carb engine is probably the coolant sensor
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Is the item you are talking about in one of these pictures and roughly where in relation to your alternator is this item located? As far as the coolant fan switch missing, according to the information I have on the L69 engine and it may be wrong. There was not a coolant fan switch in that area.
bubbaz28
Sep 18, 2015 02:09 PM
