ZZ4 HO 350 Crate Engine?
Old Jun 25, 2004 | 11:48 AM
snipcod's Avatar
Car: 1984 z28 Camaro
I want to swap a GM Performance Parts ''ZZ4 HO'' 350 Crate Engine into my 84 Z28 HO. Just wondering a few things. You this be a drict swap? Or would I need new motor mounts. Would I need to change any thing on my wire harnnes. Or would I new any thing diff to do it.
http://www.jegs.com/cgi-bin/ncommerc...29&prmenbr=361
Old Jun 25, 2004 | 12:14 PM
PF Flyer's Avatar
Car: 87 T/A
Engine: TPI 350 ci
Transmission: 5 speed
... are you using the long block and your manifold or are you going to use it as a carb'd 350?
I had a 350 HO long block that the Vortec heads were removed and aluminum corvette heads installed and the TPI setup. 'course it also had a TPIS LT1 cam installed too.
Old Jun 25, 2004 | 12:22 PM
snipcod's Avatar
I was hoping I could us the quad jet carb thats on my 305 now
Old Jun 25, 2004 | 12:49 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Your EGR wouldn't work because the aluminum heads don't have the cross-over passages. Otherwise, it will bolt in and should operate with minimal hassles (tuning the carb secondaries, 350 knock sensor and module, for instance).
The HO 350 Conversion Kit had a different chip (and computer), but most likely that won't be a problem.
Old Jun 25, 2004 | 12:52 PM
five7kid's Avatar
About the EGR: If I were doing this, I'd bolt the EGR valve and solenoid on and just let them sit there. You shouldn't have any problems getting past Air Care Colorado.
Oh, upgrades to the exhaust highly recommended to let that baby breathe.
(FWIW, I have often considered putting that engine in my car.)
Old Jun 25, 2004 | 01:11 PM
snipcod's Avatar
Would there be any kinda prob if I keeped the Dual Snorkle?
Old Jun 25, 2004 | 02:23 PM
five7kid's Avatar
I wouldn't use anything else.
Old Jun 27, 2004 | 07:35 PM
mdricken's Avatar
Car: 92 Camaro
Engine: ZZ4 Crate Engine w/Hot Cam
Transmission: Rebuilt 700R4 with Transgo and MW 3
Axle/Gears: 3.73 Eaton Posi
I did this swap last fall on my 305 TBI and it went pretty smooth. The motor should swap right in. However you might want to see if you have the right flywheel on the engine if you run a manual tranny.
Here is my website where I noted some snags we ran into.
http://olsonpower.homelinux.com/%7Embdricken/ZZ4.htm
Here are some things you'll have to do:
Passenger side A/C, smog pump bracket: you will have to drill a hole in the head if you want to keep your smog or AC bracket.
Oil filter adapter - You will need an adapter so you can screw on your oil filter - GM was dumb enough not to supply this part that 99% of people use and nobody can find - I had to go to an engine shop. It costed me $5.
I feel sorry for you if you have to worry about emissions. I don't so I abandoned about everything except for the tach wire on the engine harness (it used to have TBI injection).
I don't know if your stock carb will work - I bought a 670cfm Holley street avenger and it works pretty good.
theshackle
Sep 17, 2020 08:26 AM
xkingcodex
Feb 12, 2020 07:43 PM
theshackle
Mar 5, 2017 06:37 PM
masonta
Aug 31, 2015 10:14 PM
ezobens
DIY PROM
Aug 19, 2015 10:29 PM
