Brake Bleeder won't open! Help ASAP
Old Jul 13, 2004 | 08:59 AM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
I am trying to bleed my brakes, and I cannot open the damn bleeder valve. I was told it was a 10mm, but no it's not. It's smaller than 10mm but larger than 9mm. If I continue using my 10mm I will round the thing off. What do I do? I cannot drive my car until I bleed the brakes, and today is my anniversary with the gf so SHE has to drive everywhere and I feel like a loser. "It's always something with you and your car!"
Old Jul 13, 2004 | 09:03 AM
Dewey316's Avatar
Car: 1990 Camaro RS
is it 3/8?
Old Jul 13, 2004 | 09:15 AM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
I think it's smaller.
Old Jul 13, 2004 | 09:23 AM
taonindo's Avatar
Car: 82 firebird
Engine: 406
if you can't find the right size use a vise grip to get it out , then replace it with a new one .... hope that helps
Old Jul 13, 2004 | 09:26 AM
Dewey316's Avatar
Car: 1990 Camaro RS
3/8 is 9.525mm
Old Jul 13, 2004 | 09:33 AM
Z28guy83's Avatar
Car: 83 Z28
Engine: 400sb
its a 10mm i just had to do my rear brakes yesterday but if your saying a 10 dont fit you better start looking at standard sizes or try a line wrench
Old Jul 13, 2004 | 09:46 AM
Kenwood's Avatar
Car: 1987 GTA
Engine: PT88 Turbo DART 406
Transmission: th400
Axle/Gears: 9" ford
If its stock its 10 MM>>>>> BUT biggest problem is they round easily.... BEST advice I can give is FIND/BUY a 6 POINT socket or 6 point wrench to loosen it... Usually they round when people use a 12 point wrench to loosen them...
Old Jul 13, 2004 | 09:47 AM
taonindo's Avatar
Car: 82 firebird
Engine: 406
try 11/32 its a little bigger then a 9 and smaller then a 10
Old Jul 13, 2004 | 10:40 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If it's a front, a whole rebuilt caliper is like $12. Just change them both out and be done with it.
Old Jul 13, 2004 | 11:54 AM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
that's cheap! Are there any "upgrades" I can do, IE a two-piston caliper or something? Anything is better than our stock brakes.
Old Jul 13, 2004 | 12:35 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Yeah...but it won't be done in one day
Old Jul 13, 2004 | 12:38 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
nevermind then, haha
should I attempt to Vice Grip this bastard off, and put it back on until I get to the store for a new one? or do I just sit here and cry about it?
Old Jul 13, 2004 | 01:06 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If it was me, I'd walk to the store, or use one of my other cars, or borrow one, or call somebody and get a ride. Half-assing brakes and driving around on them isn't my idea of a good idea, if you know what I mean.
Old Jul 13, 2004 | 02:57 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
WELL THAT WAS GAY
I broke the bleeder valve off... I didn't round it off, it just friggin snapped!
So I "bled" them the ghetto way; I let the soft line hang until it began to drip (3 drips per second sound good?) with the cap off the resivoir. I manually filled the caliper (which I had used a C-clamp to push the piston in) with brake fluid from the can. I put the bolt through the soft line and let it drip in a little bit. I tightened the bolt and put the caliper back on. Brakes are ultra soft but 100x better than they were. This means there's still a little air in there, right?
Any suggestions? This sucks!
Old Jul 13, 2004 | 05:13 PM
Good guess!
Time for a trade-in. Wouldn't hurt to install new hoses at the same time, unless you know they've been done in the past couple years. Check the other side as well.
Put some anti-seize on the threads of the 'new' bleed screw.
Don't let the master cylinder run dry of fluid while working on it.
Don't pi<x>ss into the wind. Don't eat yellow snow.
Old Jul 13, 2004 | 05:40 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yeah, that's what they do. Pretty common.
Looks like it's time to replace the calipers.
Old Jul 14, 2004 | 03:21 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
So replacing the calipers isn't a big deal? I mean, not a big costly expense? I've replaced my pads and rotors before but I didn't mess with the fluid. I just compressed the pistons and that was that. Where can I get cheap replacements aside from the obvious two answers (ebay/junkyard)? My pads are still pretty newish with about 12k miles on them- is that normal wear?
How much more persay would some "performance" calipers cost me?
Old Jul 14, 2004 | 03:25 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
most likely, you pay more for the pads then for replacement calipers. autozone wants $11.99 with a $10 core.
just undo the same bolts to take it off, take off the line, walk to the store and swapem for $12.
Old Jul 14, 2004 | 03:26 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
btw, you DONT want "the performance package" brakes.
thoes are 1LE brakes
and you dont have a 1LE car
and theres more envolved in the 1LE swap then the calipers.
just go buy the $12 caliper, bleed it, and drive away...
Old Jul 14, 2004 | 03:29 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
I meant if there was a 2-piston non 1LE or something Anyway, $12-ish at any parts center with a core trade in?
Old Jul 14, 2004 | 03:38 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
thats about right.
Old May 22, 2017 | 07:26 PM
Brandon Justice's Avatar
Re: Brake Bleeder won't open! Help ASAP
I have a 95 Bronco and the 3/8 fit perfect.
Old May 22, 2017 | 07:55 PM
NoEmissions84TA's Avatar
While you are buying new calipers, get some Speed Bleeders.
They replace the standard bleeder screw, and they have a spring and check ball inside.
All you have to do to bleed is loosen them about 1/4 turn and pump the brakes. When all the air is removed, then tighten them.
Do 1 wheel at a time. Use a 6 point wrench or socket to prevent rounding. Do not let the master cylinder get empty.
Frozer!!!
Jan 19, 2024 04:55 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
