MAF relays?
Old Aug 21, 2004 | 11:36 AM
camarokid54270's Avatar
Car: 87 Iroc Z28
Transmission: 700R4 Automatic
MAF relays?
Hi everybody, just joined the forum. I am trying to find out where the MAF sensor relay and the burn off relay are located. I have an 87 Iroc Camaro. It's a TPI 305. I read other messages about MAF problems, my car was stalling when I started up and when it did run it wouldn't rev up. I unplugged the MAF and now it seems to run OK. I want to check the relays first but I don't know where they are. Thanks for the help.
Old Aug 21, 2004 | 02:06 PM
Car: 87 Iroc Z28
Also, will it hurt anything to run it with the MAF disconnected.
Thanks.
Old Aug 21, 2004 | 05:27 PM
josh1988's Avatar
Car: 1993 Trans Am
Engine: 5.7 LT1
Not sure of locations, but no, it won't hurt the car to run it disconnected, for testing purposes anyways. I have read on here that it is bad to disconnect/reconnect it while the car is running though.
Old Aug 21, 2004 | 05:35 PM
Car: 87 Iroc Z28
No, I mean is it alright to drive it like that? I didn't disconnect it when it was running. I need to know where the relay's are and how do I know if it is the relay's or the MAF.
Thanks.
Old Aug 21, 2004 | 05:38 PM
josh1988's Avatar
Car: 1993 Trans Am
Engine: 5.7 LT1
I think it may put the car in limp home mode to drive it disconnected. Even still, I don't think it would hurt anything... not something I would wanna do for the long run though. Im pretty sure you could find those locations pretty easily if you searched for them. Im sure trickster has given them before.
Old Aug 21, 2004 | 05:44 PM
Car: 87 Iroc Z28
I looked back in the threads and didn't find them. The hanes manual I have doesn't tell me where they are.
Old Aug 21, 2004 | 06:09 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Here is a picture of the three relays on the driver side firewall. They are the fuel pump relay (marked), the MAF sensor power relay, and the MAF burn-off relay. The two MAF relays are the same part number and are also used as coolant fan relays elsewhere on the car.
Old Aug 21, 2004 | 06:13 PM
Car: 87 Iroc Z28
Thanks for the picture Trickster.
Old Aug 22, 2004 | 06:51 PM
vortec77's Avatar
Car: 86 T/A
Engine: 2000 TPI 5.7L vortec L31
Arent some of the relays on a relay Board that is under the dash on the passenger side on some models?
Old Aug 22, 2004 | 07:05 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
You might be thinking about some of the relays that are mounted on the convenience center under the dash by the drivers right knee.
Old Aug 22, 2004 | 08:42 PM
vortec77's Avatar
Car: 86 T/A
I read about a relay board that holds the mass air flow power relay and the mass airflow burn off relay and other relays on their as well
Old Aug 24, 2004 | 02:09 PM
NYIROC's Avatar
Car: 87IROC
Transmission: MAD DOG 700R4 w/3:73 posirear
same issue
I've been running my MAF unplugged for a couple of weeks now.
My car seems to have no power with the MAF plugged in. When its plugged in no wheel spin and low power.
When I unplug it I get a tremendous amount of power. From no wheel spin to out of control burnouts.
I'm guessing the MAF is bad but I'm not sure. I just don't want to plunk down a couple of hundred dollars for a new for the same performance when its plugged in.
If anyone could shed some light on this it would be great.
Regards,
G
Old Aug 24, 2004 | 02:54 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
You might be thinking about the relay board that is used with the megasquirt system or one of the other aftrmarket systems.
Old Aug 24, 2004 | 05:24 PM
Car: 87 Iroc Z28
Replacing the MAF sensor
Hi, NYIROC, actually, I just replaced my MAF sensor because I got basically no power at the rear wheels and it ran like a charm unplugged. I guess it is alright to run it unplugged for a little while, it didn't hurt my car when I did. But for what it may save you later on down the road, I would replace the MAF sensor eventually. At Autozone they're about $163.00 with the core exchange. Three days ago I got a factory rebuilt MAF sensor from Autozone and now my Iroc Z runs better than it has in the last few months. So if you can spare the cash, I would because when you unplug the MAF sensor they call it Limp Home Mode, so that doesn't sound like a long term thing to do.
Old Aug 25, 2004 | 11:52 AM
NYIROC's Avatar
Car: 87IROC
Did replacing the MAF bring you the same power as when it was unplugged?
I'm trying to figure out the best route to take.Get a rebuilt unit, new unit, or one of those grantelli units.
Regards,
G
Old Aug 25, 2004 | 05:15 PM
DeWynter's Avatar
Do not get the granitteli they are a rip off. They can cause malfunctioning reading to the computer. I had one for two weeks and got rid of it. Made my car run like sh)t
Old Aug 25, 2004 | 05:38 PM
vortec77's Avatar
Car: 86 T/A
Regards,
G
i heard u can get one from Auto Zone for $150.00 with a core
Old Aug 25, 2004 | 05:47 PM
Car: 87 Iroc Z28
Reply to NYIROC
I would go with the rebuilt unit. Unless you can afford giving up the $330 for a new unit, the factory rebuilt unit is your best bet. It works like new and for the cheaper price of $160. You also get a warranty for it depending on where you go. For me, it was $163 at Autozone with the core exchange and the warranty.
Old Aug 25, 2004 | 07:05 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
I got a new one from Advanced Auto with a limited lifetime warranty for $179.00 + tax. It was made by Micro-Tec and I have had no problems with it.
Old Aug 26, 2004 | 09:17 AM
NYIROC's Avatar
Car: 87IROC
Thanks for the help guys. I'll have to put the MAF on the back burner right now as I blew my rear last night.
Regards,
G
Old Aug 26, 2004 | 11:23 AM
vortec77's Avatar
Car: 86 T/A
Regards,
G
That sucks, Never a dull moment right Guys!
Old Oct 2, 2004 | 10:58 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
1985 models.
Old Oct 2, 2004 | 04:03 PM
vortec77's Avatar
Car: 86 T/A
Originally posted by Red Devil
1985 models.
Who r u talking to?
Old Oct 2, 2004 | 08:23 PM
vortec77's Avatar
Car: 86 T/A
1985 models.
I dont know what rock an ignorant jerk off like yourself crawled out from, but last i read on these bulletin boards is that we can discuss problems and ask questions. I didnt tell anyone anything as a fact Moron, I asked several questions and got answers thanks to Good guys that dont mind helping or answering questions like Trickster. I dont know what ur problem is talking crap in here to me like ur **** dont stink but if u got a problem PM me. Im pretty sure u know more about these tech questions and have more experience than me, But that doesnt give you the right to try and put me down cause i ask questions that you Acting all high and mighty Know the answer to. Im always asking questions no matter how stupid you or any other Dick heads like yourself thinks. If u got a problem with that, then maybe u shouldnt be on here:nono:
Old Oct 2, 2004 | 11:02 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Damn boy, what the hell are you reading?!?
Don’t live under a rock. Too damp, can’t keep the flames hot enough, and…
Yep, you can ask a question and, surprise, I can answer. If you took your head out of your *** long enough to read the QUOTE at the beginning of my post, you may have come to that conclusion on your own with just a minute amount of brain power expended. Maybe it was too obvious for you?
Funny, but it's Trickster that missed that one. Very common miss unless you've played with the '85's. :shrug: Still doesn't give you the right to jump my ***. Wrong board for that boyo. At least I’m a Moron and not a moron. :shrug:
I may have to PM you about your atrocious massacre of the English language and grammar, however, I doubt I’ll take the time as I have to go make my bladder gladder from all this laughing.
Just from the apparent lack of education you show I would have to agree, even though I probably am by far not the most knowledgeable on these boards. How exactly does “1985 models” put you down?!? I ANSWERED YOUR QUESTION!
*Incidentally, if you read some of the other threads, I also did it to bump the thread for someone else, but never you mind, I’m not here to help right?*
If I have a problem, I know the course that I must travel in order to resolve it, unlike you. If you had a question with regard to my response, you should have PMed me instead of trying to publicly bash me. That is usually does not end well for the basher.
NOW to recap in order to clarify this for you beyond any doubt… I thought that the QUOTE that preceded the answer would have made it crystal clear that I was trying to help someone (that would be YOU) by giving an answer (to YOUR previously posted question) that was not forthcoming in any of the posts prior in this thread. -1985 is the model year you were looking for, for the MAF junk under the passenger side panel in the dash chuckles.- How anyone could become offended from “1985 models” is absolutely hilarious.
As far as the shot about not being on here, kiddo I’ve been here a tad longer than what it says under my name. YOU I believe have been around since 2004. Not a year in and you want to tell me how I should or should not act on this board?!? Not your job boyo, that belongs to Dirk, Iroc, and the mods of their respective boards. It's a thankless job and if they need help, I'm sure the'll ask.
Thanks for the chuckle boyo, it’s been a while.
edit:fixed the html screw-up.
Old Oct 2, 2004 | 11:13 PM
ljnowell's Avatar
You know, sometimes its hard to gauge someone's personality online, but you make it easy with posts like this. Where does this come from, an unhappy childhood? Perhaps some sort of counseling would be in order for you.
The good news is though, I am sure you will at least be on probation for this little outburst, if not outright banned. Next time, use a little more tact and maturity.
The least you could have done was used semi-clean words like ******, weenie, doody head, or something like that.
Mark_ZZ3
May 24, 2018 01:02 PM
thunder57
Nov 7, 2015 02:28 PM
racereese
Oct 3, 2015 03:46 PM
