Headlight Covers
Old Aug 27, 2004 | 07:22 PM
cc 82Z-28's Avatar
Car: 82 Z-28
Engine: Built 406ci
Transmission: 700R4 w/3000 stall
Axle/Gears: 3.73 Torsen Posi, Moser Axles
Headlight Covers
I was wondering if anyone can tell me if GM ever made clear headlight covers for the 82-84 Z-28's? I've seen a couple 82 pace car editions that had clear covers on like nothing I'ver seen before. They had a really different mounting system for them, there were several holes drilled in the lower area of the headlight area and had mounting brackets that were fixed to the headlight buckets. The cover would then go into the holes at the bottom and then snap into the brackets at the top. You could not remove them without opening the hood.
They deffinately were not ones you find in the parts stores. If anyone has any info on these, it would be great to hear. I would like very much to find a set of these. Thanks.
Old Aug 28, 2004 | 06:04 AM
1991z281le's Avatar
Yes, GM did indeed. They were for the Z28Es exported overseas. I bought an NOS pair from PPI for an '82 that we used to have. You are correct about the mounting system that they used too.
Old Aug 28, 2004 | 06:07 AM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
GM made the covers you are referring to for the Pace Cars and for export cars. They screwed into the urethane with small thin screws. I don't remember which export country, but one country requires that the headlights be covered so they won't break when a stone kicks up. The covers are pretty much non existant today.
Veaceonee
Sep 29, 2016 08:15 PM
1Aauto
Sponsored Vendors
Oct 5, 2015 03:14 PM
Isaac McCormick
Sep 12, 2015 10:20 PM
sylentnite
Sep 9, 2015 02:55 PM
luvofjah
Sep 3, 2015 07:08 PM
