Spraying Water into PCV to Clean Cylinders
Old May 12, 2001 | 12:52 PM
GTA88's Avatar
The topic of misting water into the carb to clean out carbon deposits in the chambers has been beat to death before, but I noticed some people mentioning adding water to the *** pcv valve or pcv hose **** instead. I am thinking of doing this on my 88 GTA with TPI. I plan to just spray or dribble water into the actual pcv valve, while it is upside down and sucking air and water into the engine. I am assuming that this will get to all 8 cylinders, and that the same rule applies that you should be careful not to add too much at one time. Is it necessary to rev the engine, or can I just let it idle and slowly add the water ?
88 GTA Charcoal Grey Bone Stock except for loose muffler which makes it a bit louder than normal.
Old May 12, 2001 | 12:55 PM
Bort62's Avatar
It all goes to the Same place, So Yes.
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Reader's ride -> My Ride
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Old May 12, 2001 | 06:25 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
you should never put any water in an engine it could pop rings off their seats crack valves etc use gm carb cleaner it is not a spray but a pour in can pour pour 1/2 can in the tb let sit for 2 to 3 min crank engine do it again with the other half when started you'll see the carbon being pushed out the exhaust
Old May 12, 2001 | 06:41 PM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
I've heard that putting uncooked rice down your intake will clean everything out. I would be a little leary of that though! But wait, wouldnt you be a "***** burner" if you did that! Can anyone verify this technique?
Old May 13, 2001 | 09:51 AM
GTA88's Avatar
I've read about lots of people using the water trick in carbed cars, with good results. I've done it to my carbed daily driver, via the carb, not the pcv. Never heard anyone say it hurt his car. Just add the water slowly.
Has anyone used the pcv to add the water ? Spray into the pcv valve? Drip water into it ?
Old May 14, 2001 | 04:32 AM
dans82bird's Avatar
Car: 1988 Mustang GT
Engine: 302
Just get a spray bottle and mist it by the throttle body or over the carb, be careful not to do too much though!
Old May 14, 2001 | 08:08 AM
purpleworm's Avatar
I would do it the easy way if you are all worried. Just go to GM and buy a can of CLEENS and yes that is the spelling. It is combustion chamber cleaner. Sray it into the intake and it runs thought the engine.
I used this on my dodge winter bomb and I sprayed it in till it stalled the car and then I let it sit for anout 30mins so it loosened all the carbon. It takes a lttle persuasion to get it started but when it does, holly friggin smoke screen. You have never seen so much smoke come out of a car. After a couple of mins it clears up and the car works like a million bucks.
91 Z28 Camaro
305 TPI
Flowmaster 3" exhaust
700R4 with 2000 Stall and shift kit 3.42 rearend
One sweet sounding system
Old May 14, 2001 | 10:15 AM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
I did the water thingy. I misted. It stalled. Then I waited a couple mins, then misted again. Car never ran better.
89 IROC-Z 350 TPI
-Flowmaster Catback
-Performance Resource Chip
-700R4 (Rebuilt) Too much done to actually list
-K&N Airfilters
-Ported Plenum
-2.77 Gears (not much to brag about but eh, its there)
-MSD 8.5 mm plug wires
-Gutted cat
-!AIR
-Gutted Air Boxes
Old May 14, 2001 | 02:44 PM
NTChrist's Avatar
Aren't you guys worried about clogging a cat? How do you get around filling the cat with partially burnt carbon? That sounds like it'd be worse for performance, than carbon on the valves.
No guts, no glory.
Old May 14, 2001 | 05:44 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Um, not to sound like a nerd or anything...
In a honeycomb matrix type cat. the larger particles you loosen will not adhere to the matrix, the smaller particles from combustion stick more. A good example to compare, is a fan blade. The smaller particles do not get caught in the airflow drag.
"Question with boldness even the existence of a God; because, if there be one, he must more approve of the homage of reason, than that of blind-folded fear."
-Thomas Jefferson
Old May 16, 2001 | 03:46 PM
84TransAm's Avatar
I just did the misting thing, except the mister was too weak. I poured about 1/2 gallon in. Had my doubts, but I did have a little carbon buildup. Checked the plugs before and after, they appeared the same (a little sooty), but it is definently worth doing, since it clears all the carbon in the whole length of piston travel. Also it idles better, and has better throttle response.
--Steve S--
1984 Trans Am 305 LG4, 5 speed Daily Driver, Flowmaster 80 Series
Holley 600 cfm & vacuum advance
Soon: Edlebrock Intake & TES
[This message has been edited by 84TransAm (edited May 16, 2001).]
Old May 16, 2001 | 04:08 PM
formula90's Avatar
Car: 1990 Formula
Engine: 5.7 liter
nice tip.....
<font face="Verdana, Arial" size="2">I have experience......unfortunatly its a result of bad judgement......</font>
click below to check out....
www.formula350.com
or click below to email me
webmaster@formula350.com
Old May 17, 2001 | 12:06 AM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
<font face="Verdana, Arial" size="2">Originally posted by branz28:
</font>
so did u take the intake tubing off and spray it into the TB or into the PCV valve?
Originating member of the SJNEP Crew
Member of the Jersey Fbody Crew(JFA)
Check out MyGTA Nicknamed:The Big Red Machine
***AOL IM RiceEatinGTA***
Moderator at www.transamgta.com
"What does not kill us only makes us stronger"
Tony
Old May 17, 2001 | 11:46 AM
Brett H. - 89GTA's Avatar
Car: 1989 GTA
Engine: 5.7L
Axle/Gears: 3.27 BW 9-bolt
I've got a spray can of GM Top End Engine Cleaner that I'll just spray into the PCV hose. I believe that you're supposed to disconnect the AIR diverter valve first.
Old May 17, 2001 | 09:47 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Transmission: Weaker
Keep in mind that too much water or revving your engine with water in it can create steam which can increase pressure in the cylinders to a dangerous level. My dad sunk his dirtbike and started it. It would have worked, but he revved it and BOOM!
Old May 18, 2001 | 07:30 PM
lukerene's Avatar
Car: 1982 t top,,z/28,
Engine: 409ci vortec
Transmission: all steel t700r4,1300 stall yahooooooooooo
AMSOIL makes a great foam cleaner,,to spray into intakes ,,,its called power foam cleaner,,the ,directions on the can,,,everything these guys make works,,,,including there ,,,stnthetic oil,nothing beats pulling the heads off though,,if its got bad enough to keep chugging after the ignition is turned off!!!
1992 Trans Am
May 10, 2023 07:19 PM
Cornholio7979
Sep 20, 2018 02:31 AM
C409
Jan 21, 2016 08:29 PM
