When I shift out of park.....
Old Oct 7, 2004 | 11:13 PM
AlabamaThunder's Avatar
Car: 1986 IROC-Z, 1990 RS
Engine: 383 Stroker TPI, 350 About To Go In
Transmission: 700R4 W/ Shift Kit And Stall, 700R4 W/ Shift Kit
Alright guys I just got my new motor in my camaro, and it runs but when I shift from Park into any gear it stalls.
This is a 90 RS, that was TBI but is now Carb 350, and a 700R4.
I bought the car with no engine, and put this one in, what is it doing guys?
Old Oct 8, 2004 | 12:11 AM
blue86iroc's Avatar
Car: 1986 IROC-Z
Whenever you shift out of Park, the engine will reduce its RPMs slightly. It's possible that you're just at the threshold where the engine will cease to run because it can't sustain itself at such a low RPM.
What's the car idling at? Have you tried bumping up the idle speed a little bit and seeing if it'll still stall when shifted out of Park?
Old Oct 8, 2004 | 12:19 AM
sellmanb's Avatar
Car: '86 Berlinetta
I'd suggest going to the carb board, your carb just needs the drive idle adjusted....
Old Oct 8, 2004 | 04:42 AM
It's set pretty high, idles at a grand-1400
Old Oct 8, 2004 | 07:26 AM
ploegi's Avatar
Engine: 5.7 TPI
REcheck your timing.
What size cam do you have in this motor? I have seen problems where to large a cam mated to a stock torque converter can cause this....
Old Oct 8, 2004 | 09:44 AM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
also a "stuck on" TCC lockup solenoid will cause this.
Old Oct 9, 2004 | 12:49 AM
Where is that, and how do i fix it?
Old Oct 10, 2004 | 12:30 AM
anyone?
Old Oct 10, 2004 | 07:19 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
The TCC solenoid is located inside the transmission pan and would need to be replaced. Another thing to check would be to see if the wire harness is connected for it. This is located on top of the tranny pan back of the shifter lever, it is a 4 prong connector with three wires in it. The fourth pin in it is not used.
Old Nov 23, 2004 | 06:27 AM
Aight guys...The wiring harness is not connected there, where can I find this connecter? does it come down that hole in the tranny hump along with the shifter cable?
Old Nov 24, 2004 | 03:13 AM
anyone?
Old Nov 24, 2004 | 06:27 AM
safemode's Avatar
Car: camaro rs
Engine: 305 tbi and 350 on stand
Transmission: 4spd auto
I bet mine has the same problem. I have tbi and my car will jerk hard after shifting out of park unless i give it gas, then it shifts smooth. It will also stall when in gear and stopped suddenly, shifted out of park or parked idling for a long time.
The engine code thrown says egr is bad. Does your car throw any codes when it stalls relating to the transmission or something else? I know my transmission was changed by the previous owner.. Would this transmission solenoid problem still be a problem when cruising for a long time? I do get a code when cruising at high speed but i suspect it is egr related. Since that was also replaced by the previous owner. Seems like everything the previous owner touched has ended up going to hell.
Old Nov 24, 2004 | 12:13 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
maybe you need a high stall Torque Converter?? What does the 350 have in it??
Old Nov 24, 2004 | 12:27 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
yes the wire and 4pack connector should be coming out of the hump above the trans.
jeff
Old Nov 26, 2004 | 03:00 AM
What does it look like? I can't find it in my console.
Old Nov 26, 2004 | 08:37 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
This, if for no other reason, is why folks shouldn't mess with cars when they have no idea what they're doing.
Whats the point of hopping up to a 350 and putting a carb on, if you can't drive the car.
-- Joe
Old Nov 26, 2004 | 04:16 PM
84camz28's Avatar
Car: 1988 IROC-Z/1996 DODGE RAM 1500
Engine: 350 L98 TPI/360 v8
Transmission: 700r4/46RE 4x4
Axle/Gears: 4th gen 3.42 10 Bolt Posi/3.90 posi
al it wouldnt be in your console. it would be branching off of thw wiring harness at the back of the engine.then it runs down to the trans. hope this helps ya
Old Nov 27, 2004 | 11:05 AM
-- Joe
I built the 383 stroker in my Iroc-z and pretty much redone this one, excuse the hell out of me for not knowing where the connector was coming from smartass.. Oh yeah and thanks 84camz28
Old Nov 27, 2004 | 07:56 PM
84camz28's Avatar
no problem
Old Dec 9, 2004 | 01:00 PM
safemode's Avatar
Car: camaro rs
Did reconnecting that plug fix your stalling problem? Every thread i look at that describes this problem just ends right when someone looks to try something that might fix it. This type of problem has happened on TPI/TBI/CARB and nobody has yet to show what the problem is. Just ideas on idle speed adjustment. So, did reconnecting the plug work ...and if not did you try something else?
Old Dec 10, 2004 | 11:29 AM
mightymaro94's Avatar
yeah i wanna know if it worked or not al.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
racereese
Oct 3, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
AmpleUnicorn88
Sep 24, 2015 09:15 AM
