Ground Control Caster/Camber Plates
Old Jan 11, 2005 | 02:33 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
Does anyone out there have a picture of what these look like installed?
Old Jan 11, 2005 | 07:58 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
looks like this uninstalled
Attached Thumbnails Ground Control Caster/Camber Plates-gc1.jpg
Old Jan 11, 2005 | 08:00 PM
Lo-tec's Avatar
and clearancing on bottom of mount
Attached Thumbnails Ground Control Caster/Camber Plates-gc2.jpg
Old Jan 11, 2005 | 09:05 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Whoa, how much do them cost, and from where?
Old Jan 12, 2005 | 12:12 AM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
Thanks for the pictures. How do you like them? Worth the price?
Dale : www.ground-control.com they site suggests you would be able to order it direct through them.
Old Jan 12, 2005 | 08:25 AM
Lo-tec's Avatar
Haven't installed yet. Will be doing so in the next few weeks. They look like they will work fine. I can only get about 1 deg neg camber and 3 deg caster right now. I bought 2 used strut mounts to do this off the car. You have to split them open to take out the old mounts and then clearance the bottom half as seen in picture. You will also need a welder to put two halves back together. Also, you will have to clearance top of strut tower when I install them. Definitely should be able to get more adjustment out of alignment when finished. I will try and post results when I am done.
Old Jan 12, 2005 | 12:22 PM
Axoid's Avatar
Car: 92 Camaro RS
Transmission: T5 manual
I've run them for a year now. I had to have the spacer sleeve milled down to allow the strut nut to fully engage the threads on my Koni struts. Also the stock strut boot will not work with them.
Old Jan 12, 2005 | 02:14 PM
Lo-tec's Avatar
Thanks for the heads up. How much did you have to machine spacer, and do the dust covers interfere with something when using these?
Old Jan 13, 2005 | 11:47 AM
Axoid's Avatar
Car: 92 Camaro RS
The spacer has a about a 10mm lip around one end of it, I had that taken down by half.
If you look at the picture of the bottom view of the plate you can see that the bearing is very close to the side and dust cover is too big to fit, plus when you move the plate in to get camber the strut shaft comes very close to the edge of the strut hole in the tower. I used a flexible rubber dust cover for off-road trucks like: http://www.jegs.com/cgi-bin/ncommerc...2&prmenbr=361.
Old Jan 13, 2005 | 11:58 AM
Lo-tec's Avatar
Thanks again for the info!
Old Jan 15, 2005 | 12:37 PM
83 Crossfire TA's Avatar
I never understood the point. What do they buy you that slotting the top of the strut towers and the stock plates (or even better, using later OEM plates and bottom brackets which are already different and I believe the only ones available anymore)?
Either way, there is no way to run any kind of dust shield or boot with the GC stuff, where slotting will let you keep them if you go only a little ways with it, and if you want more you can either run dust boots like the 4x4 guys do or trim the lip on the opening in the top of the strut tower and run the stock dust shield.
Of course, If you’re seriously **** retentive (and I’ve actually tried this) you can pop the spot welds for the top of the strut tower and reweld it wherever you want it.
Old Jan 15, 2005 | 12:58 PM
bbunting's Avatar
Car: 1990 IROC Z
Engine: blown 390 CI
Transmission: TKO II
Re: Ground Control Caster/Camber Plates
http://community.webshots.com/photo/...33245013PMjQpA
See pics
Old Jan 15, 2005 | 01:16 PM
Lo-tec's Avatar
[i]
Of course, If you’re seriously **** retentive (and I’ve actually tried this) you can pop the spot welds for the top of the strut tower and reweld it wherever you want it. [/B]
You are **** and cheap, hence the hacking and cutting and re-welding. These look nice so we'll see how they work in a few weeks when the rest of my front end s@#t gets here.
Old Jan 15, 2005 | 08:17 PM
Dale's Avatar
Engine: 350 S-TPI
Please post and let me know.
Old Jan 15, 2005 | 08:25 PM
Lo-tec's Avatar
Will do...hopefully I'll take pix while putting it back together as far as clearances go, etc.
Old Jan 16, 2005 | 05:49 PM
oh, I’m so hurt… **** and cheap… 2 qualtities that I’m actually somewhat proud of.
Hey, do you care to take those things apart and take a picture of what’s inside them (mostly the bearing and spacer assembly), this whole thing just gave me an idea.
Huh, maybe I should just show up when the rest of your suspension stuff gets here and take those apart… ahum, sorry, help you put stuff on your car.
And FWIW, I still think that slotting the strut towers or similar changes are a better solution since it will let you keep some sort of dust cover over the shaft.
Old Jan 17, 2005 | 11:22 AM
Axoid's Avatar
Car: 92 Camaro RS
For me, it was because I race my car and camber plates are legal and cutting and modifying the strut tower is not.
Old Jan 21, 2005 | 01:14 AM
redimpss5's Avatar
Car: 85 z28
Engine: 94 lt1
Man, I will tell you. I have those same plates and have not figured how they mount? The guys at ground control did not give me much info either! Do the really work?
Old Feb 20, 2005 | 08:11 AM
Lo-tec's Avatar
Well I finally got these in. Ran into a few issues but nothing that couldn't be fixed with a welder and a few beers. I just installed these along with a PA k-member and Spohn LCA's, so with the springs out I went ahead and mocked everything up. The strut clears the hole in the strut tower, but since my car is lowered I wanted to check the strut body, and sure enough it hits the hole about 1" before the tire would buzz the inner plastic fender (which I did once going over some rough train tracks ).
Attached Thumbnails Ground Control Caster/Camber Plates-c-documents-settings-dillhole
Old Feb 20, 2005 | 08:13 AM
Lo-tec's Avatar
To clearance I set my modified strut mount bracket on and set it for max camber and caster (in and back). I just traced the outline where I had trimmed it and cut it out.
Old Feb 20, 2005 | 08:15 AM
Lo-tec's Avatar
You can see from pics how it cuts the lip out of the hole, which weakens the top of the strut tower. The fix was a 3/8" wide piece of 1/8" plate the was bent to form a new lip and welded into place.
Old Feb 20, 2005 | 08:19 AM
Lo-tec's Avatar
With new piece welded in strut clears fine and allows use of original dust boot. You can use the 4x4 rubber dust boots as long as you don't have to worry about the body of the strut hitting the hole in the strut tower. I will be getting the car aligned sometime this week and will post how much more it is adjustable when done.
Old Feb 20, 2005 | 09:26 AM
Lo-tec's Avatar
Pic of fixed strut tower before grinding welds and paint:
Old Mar 7, 2005 | 12:03 PM
Lo-tec's Avatar
Update:
Just got an FEA: I picked up an extra degree of caster (to 4 degrees). It's not as much as I wanted, but after changing k-member and lower arms, the front end dropped a little. Also, the rear is about an inch higher than the front, which will take away from the caster a little also.
eightsixseven
Dec 16, 2024 01:50 PM
customblackbird
Aug 15, 2021 10:16 PM
NORTz89
May 20, 2020 03:51 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
Armored91Camaro
Aug 25, 2015 12:01 PM
