air intake idea
Old Feb 8, 2005 | 11:34 AM
costill91Z's Avatar
Car: '02 Rodeo
Engine: 3.2 V6 DOHC
Transmission: 5spd
Axle/Gears: 4.30 Dana 44 Rear 10 bolt front
air intake idea
this is what i'm doing with mine, the piece over the tbi unit is from a 4.5 tbi cadilac.
Attached Thumbnails air intake idea-c-documents-settings-compaq_owner
Old Feb 8, 2005 | 05:48 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Looks pretty good. This mod is starting to become more an more popular. I believe the biggest downfall is the lack of plenum size in that type of bonnet.
Old Feb 8, 2005 | 06:16 PM
costill91Z's Avatar
Car: '02 Rodeo
Engine: 3.2 V6 DOHC
Transmission: 5spd
there is an aftermarket piece, but its to expensive, i got this piece for about $6 at the local pick n pull and i already had the tpi duct from the z
i dont think that this will pose too much of a restriction being that the engine is mostly stock for now
can't wait to get this thing driving again
Old Feb 8, 2005 | 11:07 PM
r90camarors's Avatar
Engine: LO3;383tpi
That is indeed the case. The open element "feels" much stronger at lower speeds compared to the caddy tbi/tpi air cleaner with ram air ducts.
Old Feb 9, 2005 | 08:53 AM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
i`ve done the same thing myself a while back check it out.
Attached Thumbnails air intake idea-c-documents-settings-owner
Old Feb 12, 2005 | 06:12 AM
icarus402001's Avatar
Costill--- I did the same thing. Did you need to gut the TBI hat so it would sit down and seal on the TB: I also had to shave the bottom of the hat to get it to sit flat on the TB so the hood would close.
Old Feb 12, 2005 | 06:14 AM
What year and model were your hat and duct from? I am OK with The TPI plenum up to the rad support but what did you use between the plenum and the hat?
Old Feb 12, 2005 | 10:34 AM
costill91Z's Avatar
Car: '02 Rodeo
Engine: 3.2 V6 DOHC
Transmission: 5spd
it was from an early to mid 90's 4.5 tbi cadillac the front wheel drive ones, i don't remember the exact model. there is a metal piece that i did have to yank out to get it to fit, other than that, ive had no clearance issues , but my hood doesn't latch yet since im still putting the front end back together it seems to close as normal and i don't hear any rubbing or hitting of the bonnet
im am still toying with mine during the down time to see if i can get a better fit. you have to work with it just a bit to get it to fit with the tpi duct (btw-its best to find a non-MAF tpi duct) due to it being offset just a bit
Old Feb 13, 2005 | 06:37 AM
That was what I found. Only paid 5 bucks.
1992 Trans Am
May 10, 2023 07:19 PM
kyle5647
Aug 15, 2015 11:56 PM
Jake_92RS
Aug 11, 2015 10:39 AM
bryan623
Aug 10, 2015 11:33 AM
