RPO GU6 question
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
RPO GU6 question
G80
AXLE POSITRACTION, LIMITED SLIP
G92
AXLE REAR RATIO, PERFORMANCE
GU6
AXLE REAR, 3.42 RATIO
can anyone tell me if this is a 9 or 10 bolt rear end? i believe its off iether a 86 or 87 iroc. and if its a 10bolt, how well can it hold up to my car with whats listed in the sig?
G92
GU6
Car: '02 Z06
Engine: L33 5.7
will this disc brake ten bolt be a worthy swap to replace my 2.77 disc 9 bolt? can i retain my disc rotors and calipers if i swith to the 10bolt?
In my opinion, NO to the first question and No to the second one also: Reason the 9-bolt is a stronger rear with better brakes and don't belive everything about the 2:77 gears being a poor ratio..
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Axle/Gears: 3.54 Dana 44
Originally posted by Apeiron
Any 9 bolt has the same brakes that were available on a 10 bolt of the same year.
Car: '02 Z06
Engine: L33 5.7
ok then, i think im gonna get this 10bolt. where can i pick up backing plates. not familiar with this?
Engine: 383 Carb
The last I checked they were still available from GM, that was a while ago though. 10136853 for the left side, 10136854 for the right.
Engine: 383 Carb
You're thinking of 9 bolt backing plates. I just checked with GM Parts Direct, both of the 10 bolt backing plates are still available.
Engine: 383 Carb
The backing plates bolt onto the axle flange and the caliper brackets are mounted to them.
Car: '02 Z06
Engine: L33 5.7
hey i was thinking, can i take the backing plates off my current 9bolt and just bolt them to my new 10bolt axle?
Engine: 383 Carb
No, they're the only part that's different between the 10 bolt and 9 bolt brakes. GMPartsDirect has each plate for something like $11, so it's not like you'd go broke on them or anything.
Car: '02 Z06
Engine: L33 5.7
ok so i need these backing plates that bolt to my 10bolt, so my calipers from my 9bolt can bolt to them? my 9bolt backing plates wont bolt to my 10bolt?
sorry if the question sounds stupid, making sure we are on the right page.
Engine: 383 Carb
Right, the flanges on the ends of the axle tubes have different bolt patterns on the 9 bolt and the 10 bolt. The bolt pattern on the backing plates has to agree with the pattern on the axle flanges.
The reason the PBR 9 bolt backing plates are so rare is because they were only available for a short time before the 9 bolt was discontinued. 10 bolt backing plates were used much longer and are more common than dirt.
Car: '02 Z06
Engine: L33 5.7
thanks. Now I looked at my current 10bolt axle more closely, looks like I Have to pull the half shaft axle out in order to get the backing flange off? Is it hard to pop those out? or wait.. let me say it in a positive way.. how easy is it to remove these, and reinstall them once new backing plates are on?
hectre13
Dec 11, 2023 08:14 AM
Thornburg
Aug 25, 2015 01:46 AM
