4 gauge pillars?
Old Feb 22, 2005 | 09:43 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Transmission: TH-700-R4
4 gauge pillars?
The biggest and longest pillar gauge pid I've seen is 3
is their a 4 gauge pillar available?
Old Feb 22, 2005 | 09:49 PM
pskel350's Avatar
custom....much like mine for the newer dash style. however 3 gauges is as many as i would like to fit in a 3rd gen. i've seen some trucks with 4 gauges, but they are much roomier inside then our cars
Old Feb 22, 2005 | 09:55 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Do they really take up alot of space?
Maybe I should go with a double gauge pillar?
Old Feb 22, 2005 | 10:13 PM
pskel350's Avatar
here is the only pic i have of mine, a lot of other people have 3 gauges. they dont take up to much room, but 4 would i think.
Attached Thumbnails 4 gauge pillars?-c-pat-s-files
Old Feb 22, 2005 | 10:15 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Thats looks pretty good...Are they in any way annoying? Vision or getting in/out?
What do your gauges measure?
I was thinking about
Differential Temp
Cyl Head Temp
Fuel Pressure
Old Feb 22, 2005 | 10:24 PM
pskel350's Avatar
well i use to have air/ fuel, vaccum, and trans temp. as we speak the air/fuel gauge is traveling across seas to a fellow thirdgenner.
my new one will either be nitrous pressure, or oil temp. not sure yet
ive never had a time where they have gotten in the way of seeing the road or other cars.
Old Feb 22, 2005 | 10:27 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Which fuel pressure gauge?
0-15 PSI or 0-100 PSI
Whats stock pressure setting for a 3.1?
Old Feb 22, 2005 | 10:53 PM
jovial86's Avatar
Car: 1986 Pontiac Firebird
Engine: 1991 305 TBI
Transmission: Th700-R4
The 3.1 is MPFI so I think its something like 32psi (at least, thats about what it is for TBI and TPI)... I dont recall exactly but thats ball park. If you can get one 0-50psi it'd be perfect.
Old Feb 22, 2005 | 10:59 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Ahh crap...The only ones available are the 0-15 and 0-100..I guess I'll go with the 0-100.
Old Feb 22, 2005 | 11:08 PM
MNformula350's Avatar
they are not in my way or vision at all, sometimes at night the orange light cna be a slight distraction but other wise i love em.
i don't see how there would be room for 4 though.
Old Feb 22, 2005 | 11:13 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Thanks for the pictures man
I've decided on a 3 gauge pillar with the Carbon Fiber Autometer 2 1/16 Air/Fuel Ratio,Trans Temp and Fuel Pressure.
Old Feb 22, 2005 | 11:14 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
why on earth do you need a diff. temp guage and a cyl. head temp guage? just to put guages in the car? that's ri_got_dern_diculous if you ask me! i guess you found a use for that $120 u saved on the useless underdrive pulleys and are putting in useless guages. the people that use those said guages would be someone making a sick amount of power, and using it at high speeds sustained for hundreds of miles, ie nascar or indy. stick in a trans temp and air/fuel ration guage and call it a day. at least you can use those to help tune the car. here is a pic of my car with a dual pod on top of a single pod (already had the single, would be silly to replace it with a more expensive triple)
Old Feb 22, 2005 | 11:18 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
lol,so what gauges would you recommend.?
mw66nova's Avatar
Engine: 7.0L
sorry, we posted about the same time, glad to see you reconsidered the guage type selection. can't go wrong with Autometer, all my father and i have been using since the mid 80's.
Old Feb 22, 2005 | 11:20 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Actully the Diff temp caught my eye simply because its completly useless and different...lol Kind of like the "Brake Pressure" gauge.
Old Feb 22, 2005 | 11:22 PM
mw66nova's Avatar
Engine: 7.0L
another one used by the afformentioned associations
Old Feb 23, 2005 | 01:54 AM
Kandied91z's Avatar
4 is insane, i'm 6'2 and 3 is too many.
Old Feb 23, 2005 | 06:29 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Oil pressure
Trans Temp (if you are an auto)
Fuel Pressure (if you are running a power adder)
Coolant Temp
EGT
A/F if you hook it to a WideBand O2.
and my 86 before I sold her,
Old Feb 23, 2005 | 06:47 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Both of those are rather nice gauges to have, when you are doing something like silverstate. you can use the brake pressure gauge when adjusting your front/rear braking bias, and the rear diff temp guage speaks for itself, when you are sustaning 160+ MPH.
Old Feb 23, 2005 | 10:56 AM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
I think the Carbon Fiber autometers will go good with the stock looking firebird gauge panel.
Old Feb 23, 2005 | 02:53 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
How hard is it to wire a Trans Temp gauge?
Old Feb 23, 2005 | 11:11 PM
Zepher's Avatar
Pretty easy. You can put the sender in the pan or inline with one of the tranny cooler lines using a T-Fitting. The latter would be the easiest. former requires you to drop the tranny pan, drill a hole for the sender in a location that doesn't hit the valve body, then run the single wire to the gauge.
Old Feb 23, 2005 | 11:28 PM
496ws6's Avatar
Car: 89 Formula
Engine: 305 is out and BBc is going in
Transmission: not sure
personaly it was easier for me to drop the pan and drill and use b&m drain plug kit other wise3 if you try to clap hose in line or make tubbing an get the right fittings it just takes longer droping the pan only took me 30minutes.
Old Feb 24, 2005 | 08:58 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
those air/fuel gauges are just a light show. i wouldnt depend on that!
wideband>*.*
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
Luigytico09
Oct 1, 2015 08:46 AM
Gordonr1973
Sep 29, 2015 11:59 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
