TPS voltage fine-TPS% WRONG-Help
Old Feb 28, 2005 | 03:52 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Axle/Gears: 4.10
After installing the new ecm today(730) my car cranked and idled fine. I set my NEW tps voltage to .54v at idle. When i give it gas the voltage goes up but the TPS% wont go above .02-.05%. Im using Tunerpro RT. How can the TPS voltage go up but the TPS% wont go up.
There is 3 wires going to the TPS. Is there a specific wire(s) just for the TPS% reading?
Is there a specefic wire(s) for the TPS voltage reading? My car is still on the side of the road and i cant do anything.
When i give it gas the TPS voltage goes up but the TPS% wont. Because the TPS% wont go up the injector pulse width wont go up accordingly either. So with it being like that i can get enough gas to get it down the road.
Heres my other post pertaining to it.
https://www.thirdgen.org/techbb2/sho...60#post2207960
Old Feb 28, 2005 | 04:23 PM
Wayne's 383Iroc's Avatar
Car: 88 IROC
Engine: 383
?? ECM BAD even new parts can be defective
Old Feb 28, 2005 | 04:44 PM
3.8TransAM's Avatar
Engine: all 225+ RWHP
Transmission: all OD
See your other post too*sigh*
Anywho, check the grds on the back of the cyl. heads. Remove and clean them and secure them tightly.
Any possible water into the ecm?
Did u solder the memcal or running an adapter board?
3 ecm's in 3 years? U have something wrong. U have bad injectors the ohm too low possibley, cooking the inj drvr. Or a bad solenoid somewhere that is slowly cooking the ecm or you have a solid short somewhere letting it overheat. I've also seen a few ignition swithc scenarios really make the ecm do stupid things.
Bottom line is 3 ecm in 3 yrs, I'm willing to lay money on you have some other issue, if you dont have the knowledge to do wiring/electrical yourself, you may want to find someone near you who does.
later
Jeremy
Old Feb 28, 2005 | 04:51 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Axle/Gears: 4.10
the irony is that im a licensed electrican. Im fixing to get a carberator and solve it all.
Old Feb 28, 2005 | 05:09 PM
3.8TransAM's Avatar
The start pinning wires :-) Get a diagram and go.
Its just 12v and 5v stuff and normal resistance issues. Something is causing it to cook. Just finding it will be fun, or easy , just deoends on where it is lol
later
Jeremy
Old Mar 1, 2005 | 08:16 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Axle/Gears: 4.10
UPDATE!
Might have located the problem.
Im only getting 16-18psi. 42psi is what im supposed to be getting.
The fuel pump is not even 1 year old. But the funny thing is that Tunerpro is saying that im getting 14.8v +dc at my pump when my battery voltage is only 14.3v +dc. Bad relay?
Old Mar 1, 2005 | 08:44 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Have you checked your fuel filter? Allen
Old Mar 1, 2005 | 08:47 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Axle/Gears: 4.10
Im going to tomarrow. I filled my tank up about 15 minutes before all this started. Its was raining real bad and at some irani gas station. Maybe that might have something to do with it.
Could a clogged filter cause that much psi loss?
BumpaD82
Feb 26, 2016 02:57 PM
HoosierinWA
Oct 7, 2015 10:15 AM
racereese
Oct 3, 2015 03:46 PM
327IROC85
Sep 23, 2015 12:11 AM
