Cheap ebay race seats in car.... Mounts, install info, and pics here!!!!
Old Mar 10, 2005 | 07:36 PM
Night rider327's Avatar
Car: 1988 Camaro
Ok guys.. I know there's a few of yall that wanted to know how to mount them, how they fit, etc. I got mine all done and installed.
I wrote up everything I had to do and buy to install them for others wanting to do this.. Too many pics to post on here. The mods might get made at me, so they are all one my webshots page.
The links to each pic is below
The fit........
The fit in the car IMO is better than stock seats as far as side to side fit. There's more room in between seat and seat belt at door still, more room between seat and consol glove box door. The only tight spot is at the front of the seat, because of the thigh support, it flares out a good bit, and comes very close to the consol around the E brake handle and shift patt. numbers next to shifter.
They do sit up a bit higher than stock seats. It feels kinda funny at 1st. It makes you feel like your sitting in a truck or van and looking down, but you do get use to it.
This may not apply to all people, but with me i'm glad I have tilt wheel. I'm a big guy. 275 lbs, 38" waist, bigger muscels in my thighs and legs.
Steering wheel at norm non tilt wheel height hits the top of my thighs. I have to go up one click above norm non. tilt height (1 click below all the way up)
Oh yeah.. With the little brackets to mount the stock sliders on, stock sliders, all bolts, and seats they weigh 31 lbs each. That's 5 lbs each less than stock non powered third gen seats with sliders
The pics... Here's the links.....
http://community.webshots.com/photo/...92230837SkxxXM
http://community.webshots.com/photo/...92231813YOIxsb
http://community.webshots.com/photo/...92232390gmHqLw
http://community.webshots.com/photo/...92232878pdOLMn
http://community.webshots.com/photo/...92233344iXljSF
http://community.webshots.com/photo/...92243540WBuluA
http://community.webshots.com/photo/...92244007OWjlXv
The install and mount making......
Here's what you need to install them, and why
The sliders and slider mounting holes in seats are about 15" apart
The studs in the floor of the third gen camaro/firebirds are 13-3/8" apart, so you need something to bolt to the seats, that moves the slider mounting holes inboard.
What I found to work best for me is whats call a mending brace. It's a pc. of flat bar steel, with holes pre drilled in it. They come in diff sizes. The ones I used are 12" long x 1-1/8" wide x about 1/8" thick, and has 6 pre drilled 5/16" holes.
You'll need 3 of these. I bought mine at Ace hardware for $2.99 each. Cut each one into 3 4" pc. You want to make your cuts in between 2 holes. So each pc. has a hole at each end. The 3 braces will make 9 pc., but you only need/use 8 of them.
Ok lets move onto the seats. The seats comes with flat sliders on them. At each coner theres an allen head bolt. In between the seat bottom and slider there's a spacer about 1/4" thick or so. The threads in the seats are metric.
You could use the bolts, but they are too long, and you would have to put the spacer under the bolt head when you put your custom brackets on. I didn't like that, so Back to ace hardware again. I bought 8 metric bolts. Size is M8 x 1.25" pitch, with a thread lenght of 9/16". These was .27 cents each. I used the lock washers that was on the bolts holding the sliders to the seats
Now take your stock seat tracks off.
To bolt the brackets you cut to the sport/race seat, use the new metric bolts you just bought.
With the 4" long brackets sungged on the seats, you can rotat them. Being one end is bolted up and other aint, you can turn them in a circle. You'll need to rotat the tops of the top brackets so they point toward the front center of seat.
The rear ones, need to angle toward the rear center of the seat.
Now your reay to bolt the stock camaro sliders on. To do this while your at Ace (or other hardware store) pick up 8 5/16" x 3/4" long bolts at .15 cents each, 8 5/16" taps at .08 cents each, and 8 5/16" lockwashers at .07 cents each
Aline the holes in the stock sliders with the holes in the brackets you cut. You may have to move them around to get em' lined up. Put those 5/16" bolts, taps, and lockwashers through holes in the stock camaro sliders and the holes in the little 4" brackets you cut.
Ok now the stock sliders are bolted on. snug up all the bolts. I wasted 2 hours trying to measure center to center of mounting holes to get sliders right. It's too big of a pain, move rear out, front moves in, etc,
so then I figured, just take the seat with sliders on it out to my car. Sit it in the car, and put the holes in stock sliders over studs in floor. You will have to wiggle the mounts around some, but it will fit right up. Now fully tighten all the bolts you can get too up. If you couldn't reach any of the bolts to tighten when in car, get the ones you can tight, now take seat back out and tighten the one you couldnt get too.
If you have a cutting tool such as a angle grinder with cut off wheel, cutting torch, body saw, etc this is very easy to do. Not even any drilling.
All in all takes about 2 hours, to cut, put on seats, take old stock tracks off, and bolt everything in your car.
The parts to make the stock tracks fit these seats, and bolt into your car will run you $15
Old Nov 27, 2006 | 12:01 PM
GMan 3MT's Avatar
Car: 1986 Z28
Transmission: T5 WC
Axle/Gears: 3.42 T2R
Anyway you can rehost the pics?
Old Nov 27, 2006 | 04:55 PM
Car: 1988 Camaro
Gman Here you go..
http://rides.webshots.com/photo/1292...41290424SkxxXM
http://rides.webshots.com/photo/1292...41290424YOIxsb
http://rides.webshots.com/photo/1292...41290424gmHqLw
http://rides.webshots.com/photo/1292...41290424pdOLMn
http://rides.webshots.com/photo/1292...41290424iXljSF
http://rides.webshots.com/photo/1292...41290424WBuluA
http://rides.webshots.com/photo/1292...41290424OWjlXv
http://rides.webshots.com/photo/2870...41290424XlulrX
http://rides.webshots.com/photo/2199...41290424CTtULs
Old Nov 28, 2006 | 11:35 AM
GMan 3MT's Avatar
Car: 1986 Z28
Transmission: T5 WC
Thanks! That makes much more sense now.
Old Nov 28, 2006 | 12:24 PM
Car: 1988 Camaro
Your welcome... Webshots changed thier hosting of car pictures to a "rides" site so all my old url's are out dated but all the pics are still on my webshots pages just diff url's now..
Old Nov 28, 2006 | 03:02 PM
92RS(real slow)'s Avatar
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
those look really nice how much did they cost you?
Old Nov 30, 2006 | 08:24 PM
Car: 1988 Camaro
92RS I got em' off ebay. Price was $83 buy it now + $155 shipping So $238 total for the pair
Old Dec 1, 2006 | 12:55 AM
Falx's Avatar
Keep us updated on how these seats work out! I like the style and the price is certainly right, but I've heard of a couple people who had issues with ebay racing seats. Namely, the padding going flat super-quick or the seat backs wobbling. I wish you luck though, because I would love for these to be an option on my car...
Old Dec 1, 2006 | 01:30 AM
Car: 1988 Camaro
Falx... Take a Look at the date of the 1st post bud. 3/10/2005
I have had them in the car for over a year and a half.. They still look and feel great. The driver's side, outter thigh support has "flattened" a tad but that was due to me sitting on the edege of it while working inside the car.
For china made, cheaper ebay seats I'm very happy with em'
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
TheExaminer
Aug 25, 2015 07:34 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
