anyone made their own brake lines
Old Mar 11, 2005 | 08:00 PM
therover87's Avatar
Car: 89 camaro ss
Transmission: TKO600
i am building a 89 rs with wilwoods on all corners with a moroso line lock kit and wilwood master cylinder, so i know i am going to have to redo all the brake lines and wanted to see if anyone has made their own brakes lines and how they did it
Old Mar 11, 2005 | 09:23 PM
RTFC's Avatar
Car: Agood2.8,
Engine: V6rsr,
Transmission: Afrikingoodtime
Rears
Attached Thumbnails anyone made their own brake lines-c-documents-settings-office
Old Mar 11, 2005 | 09:26 PM
RTFC's Avatar
Car: Agood2.8,
Engine: V6rsr,
Disregard the yellow and red info boxes on the photo. Refer to the post above for those. This photo shows the proper hardline and brake line tab.
Old Mar 11, 2005 | 09:32 PM
RTFC's Avatar
Car: Agood2.8,
Engine: V6rsr,
Fronts use factory hardlines. Braided lines have same end fittings as the rears. Lines are 16.5" long
Old Mar 12, 2005 | 08:34 AM
ebmiller88's Avatar
Hey Dean...I was looking through Earl's online catalog yesterday for fittings like you have listed and only found round banjo fittings. Have you found or seen block style banjo fittings like the 1LE lines have? I'd prefer that style for C4 and C5 calipers and such but the round style would also work.
Ed
PS: Again, thanks for the info
Old Mar 12, 2005 | 08:36 AM
ebmiller88's Avatar
Rover, as for the hard axle lines, I use lines from Fine Lines. They're prebent and preflared, $25 a set for OEM steel lines, $35/set for SS lines.
Ed
Old Mar 12, 2005 | 08:59 AM
ebmiller88's Avatar
Never mind, Dean...I found it in some info I had hidden in a spreadsheet somewhere.
The "1LE" style block banjo fitting is P/N 9976031 and is $16 at Summit.
Ed
Reddeath210
Oct 6, 2015 08:20 AM
Nj1987
Aug 19, 2015 08:26 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Leggman1
Aug 6, 2015 04:15 AM
