tilt front end
Old Mar 17, 2005 | 08:21 PM
djphonix's Avatar
Car: 92 camaro, 88 , camaro sc , 05 phantom black GTO
Engine: 383,313,364
Transmission: 700r4, t-5 , t-56
tilt front end
check this out tilt front end
http://mysite.verizon.net/vze889hq/c...yclub/id5.html
Old Mar 17, 2005 | 08:37 PM
BlackMagic's Avatar
Car: 1986 Firebird
i believe VFNfiberglass makes a full one piece front end and you could do a tilt with that.
Old Mar 17, 2005 | 10:56 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You'll also notice the front roll cage bars running down over the tires. That's a tube chassis car. The tilt front end wouldn't work very well with a factory chassis. You still wouldn't be able to get over the inner fenders which are part of the front suspension.
Old Mar 22, 2005 | 02:18 AM
NoItsNotForSale's Avatar
Car: 87 & 89 Iroc's
Engine: 5.0 - 5.7
Transmission: 700R's
Axle/Gears: 2.77 - 3.70
You can do this on a factory car without a tube chassis. You have to cut the fender horiz. at the body line, and leave the bottom half
mounted. The hardest part is constructing a solid hinge. You also have to remove the crash bar.
Old Mar 22, 2005 | 12:12 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Axle/Gears: 3.54 Dana 44
You still haven't dealt with the inner fenders, which are an integral part of the front suspension.
Old Mar 22, 2005 | 10:02 PM
OneBadZ4U's Avatar
Car: '86 Iroc, '87 Iroc Vert
Engine: 350 TPI, 305 TPI
Transmission: T5 in both
Axle/Gears: 3.73, 3.45 both LSD's
I've seen this car up close. Those aren't roll cage bars coming out. The bars are chromemoly. They tie through the cowl area. The car doesn't have a roll cage yet. He fabricated a realy cool mounting area for the strut mounts. I think it's all tig welded. I thought it was pretty cool. The guy doing this seems to be very good at what he's doing. Not for me but very cool.
Old Mar 23, 2005 | 07:12 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Are you able to get more pic's of have the guys name/e-mail addy?
Old Mar 23, 2005 | 07:43 AM
OneBadZ4U's Avatar
Click on the link and then go to member list. He's the one building the northstar twin turbo. Eddie is his name.
Old Mar 23, 2005 | 08:27 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Thank you Sir..
Old Mar 23, 2005 | 08:51 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Here are some great pic's.
This is on my list to do now. Im caling for chromolly this weekend.
http://www.cecoatings.com/vettebrackets
Old Mar 24, 2005 | 04:49 AM
Guss_B's Avatar
Car: '84 Z28 & '73 camaro LT
Engine: 1960 283, eaton m112 blower
Transmission: none at present, will be manual
Axle/Gears: 3.73:1 lsd
Thats just what I need to do to the front end of my car, thanks for the pics!
Old Jul 7, 2005 | 11:30 PM
IROC_5796's Avatar
Car: '91 vert RS, '82 Z28
Engine: TBI 305, TPI 350
Transmission: Auto, 5 speed
what would you do about a hood?
Old Jul 8, 2005 | 12:01 AM
Car: 87 & 89 Iroc's
Engine: 5.0 - 5.7
You don't do anything the inner fenders they stay in place, they have to. I did this on a P O S dirt track car I had in high school.
We trimmed the corners off the two battery boxes in the front.
It rotated on large pins I stole off dads tractor. That way the front would tilt or pull the pins and pull the whole thing off.
Old Jul 9, 2005 | 12:17 AM
Kory-88Iroc 350 tpi's Avatar
Car: 88 Iroc
Engine: 94 lt1 modded
Transmission: t 56
Thanks for the pics.
That is really cool.
Kory
Old Jul 9, 2005 | 01:51 AM
IROC_5796's Avatar
i was thinking about it and i dont think that front end would work very well if your car was lowered, the nose would just tilt into the ground. maybe im wrong but the nose on my camaro is 3 inches off the ground, unless the hinges moved the front end up as it opens.
Old Jul 9, 2005 | 09:58 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Thats exactally what they do. He has about 1/2 of clearance when its open.
Old Jul 9, 2005 | 01:12 PM
IROC_5796's Avatar
well then i definently approve well thought out
Old Jul 11, 2005 | 01:42 AM
Mathius's Avatar
I've seen that car before somewhere.... Actually mini-trucks sometimes add struts by putting a similar brace setup. AIM industries sells one. (although I'm not sure how credible they are).
If you could figure out a way to make the front hinges slide forward about 6 inches, you could do away with having to cut the front fender, but you'd have to do something custom with the ground effects.
Mathius
Old Jul 12, 2005 | 04:25 PM
Enigma_valar's Avatar
Car: 1991 camaro rs
Engine: v6 3.1
Transmission: auto
i always wanted a forward tilt style hood but jeez that looks like it took alot of work. i give who ever did that props :golf clap: any how does anyone think they could make a rendering of the hinge assembly that id like to see how it'd lift the hood. i'd love to do that with my car im just scared about cutting off the front end. ill try figuring something out but i once again must say absolutly awesome.
o yeah and what about the coolant bottles and such ?
Old Jul 14, 2005 | 08:43 AM
ontogenesis's Avatar
Car: 1985 Camaro, 2015 Audi A4
Engine: V8
http://www.cecoatings.com/images/oth...0Front%20Clip/
that's got four or five other shots of that particular car, including the hinge assembly and latch assembly
I've been searching for atleast a couple years for something like this and posted a while back about cutting away everything but the frame rails (and got many posts saying I had to go full tube). I've got no desire to have a tilt front end, but I desperately want to eliminate the inner fenders, it's just a much cleaner looking car.
How sturdy is the sheetmetal to the side of the cowl that the tubes are mounted to? If I go this route, I need to be fairly certain that it will hold up when the front wheels come back down.
If anyone else attempts this project before I get back to the US, I'd very much like measurements and angles for the tubes.
Old Jul 15, 2005 | 10:46 PM
smokefan's Avatar
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
that looks so sweet. i wish i can do that to my car
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
Amillionoh7
May 24, 2020 08:01 AM
bellez77
Sep 5, 2015 08:39 PM
