TCC Retrofit question
Old Mar 31, 2005 | 02:52 PM
85cmroz28's Avatar
Car: 1985 Camaro Z/28
Engine: L69
Axle/Gears: One-Wheel-WOnder 3.08
I am in the process of retrofitting the TCC on my 700r4 to lockup without the computer. So far, I have installed a vaccum lockup switch and ran wire from the switch to a ground and the brown and black TCC wire on the ALDL. Everything is hooked up, but the convertor will not lockup. I know that the wiring is right because it worked when I put a manual switch in place of the vaccum switch.
I have 2 questions:
1. Which vaccum line should I have tapped for the switch(right now it's running off of my brake booster)? I wasn't sure whether to tap the brake booster or the hose going to the distributor.
2. Is there anywhere I could find a connector for the vaccum switch(I just soldered it the best I could)?
I appreciate the help!
Old Apr 1, 2005 | 08:41 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Axle/Gears: 3.54 Dana 44
Factory non-computer TCC setups used a ported vacuum source. If you don't have ported vacuum then it makes no difference to the TCC where you get it from, but connecting anything to the brake booster line probably isn't the best idea.
What vacuum switch are you using?
Old Apr 1, 2005 | 09:55 PM
HalfInchWrench's Avatar
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
The vac switch was off the EGR vac line on non CC Canadian cars as in this diagram. Not sure if this method was used on any US cars.
Old Apr 2, 2005 | 10:45 PM
85cmroz28's Avatar
Engine: L69
I should also mention that I do not have the stock q-jet and I got rid of the EGR. The switch came stock on 82 and 83 Camaros with the 200c tranny. This should work with the 700r4, right?
Old Apr 3, 2005 | 09:55 AM
Apeiron's Avatar
Engine: 383 Carb
That switch will work fine, and you don't need EGR you can use any source of ported vacuum.
Old Apr 4, 2005 | 01:49 PM
85cmroz28's Avatar
Engine: L69
Sorry if this sounds like a stupid question, but, what's the difference between ported and manifold vaccum and where exactly should I hook my switch.
Old Apr 4, 2005 | 02:33 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Ported vacuum recieves a vacuum signal off-idle.. Meaning you won't have vacuum at that hose when the engine is idling (if you do, it will be a very weak one). Manifold vacuum means you have full manifold vacuum all of the time... Anytime there is a change in manifold vacuum, that hose will see it.
Old Apr 4, 2005 | 10:44 PM
85cmroz28's Avatar
Engine: L69
Thanks for the reply, but the question I was really trying to ask was where on my car can I find a source of ported vaccum for my switch?
Old Apr 5, 2005 | 03:16 AM
Apeiron's Avatar
Engine: 383 Carb
Find a ported vacuum port on the carb. Try the one that used to be connected to your EGR.
Old Apr 5, 2005 | 07:05 AM
thirdgen88's Avatar
Car: 1995 Corvette
Look for a port on the carb that is higher then the level of the bottom butterflies, that will usually be ported vacuum... You could also find one pretty easily by running the engine and looking..
Old Apr 5, 2005 | 11:19 AM
85cmroz28's Avatar
Engine: L69
The only port I found above the butterflies on my carb is connected to the distributor. Would it hurt anything to just T it off?
Old Apr 5, 2005 | 11:34 PM
Engine: SBC, LS-x
Go ahead. That will work. Wouldn't hurt to size up your carb either to see what your EGR source was. When folks go in and tinker with stuff, sometimes they make a mess. Good to see what has been butchered or done right.
Old Apr 7, 2005 | 10:50 PM
85cmroz28's Avatar
Engine: L69
I've tried everything guys. I've hooked the switch up to ported vaccum, then I tried manifold again. Nothing will make my TC lockup? Am I missing something here????
Old Apr 9, 2005 | 09:10 PM
85cmroz28's Avatar
Engine: L69
Update: I got the problem solved...it appears that the connector on the transmission likes to work it's way off whenever I hit a bump...but I fixed it so it won't come off again.
All in all, not bad...saved alot of money when you compare it to the TC Lockup kit in Summit($127.95). I paid $27.00 for the vaccum switch, $3 for the connector(junkyard), and $3.97 for butt-splices.
Old Apr 21, 2005 | 07:17 PM
mdricken's Avatar
Car: 92 Camaro
Engine: ZZ4 Crate Engine w/Hot Cam
Transmission: Rebuilt 700R4 with Transgo and MW 3
Axle/Gears: 3.73 Eaton Posi
Where did you get your vaccum switch? Is it just called a "TCC vacuum switch"? Thanks.
Old Apr 21, 2005 | 07:23 PM
Apeiron's Avatar
Engine: 383 Carb
Ask for P/N 14014519 at your favorite GM dealer parts counter.
Old Apr 21, 2005 | 10:39 PM
85cmroz28's Avatar
Engine: L69
that's the P/N...very easy to install- if you have any questions just ask
Old Apr 25, 2005 | 09:57 AM
HorseflyDF's Avatar
Car: 86 Camaro Z28
Engine: 350 sbc goodwrench
Transmission: T-5 in the works
Axle/Gears: 10 bolt 3.42 open
700r4 tcc lockup
I dont have a cpu in my car
how can u make a switch from the adl connector I thought the cpu sends power to the circuit? Is this a bypass for the circuit ?
I didnt even know theres a vacuum line
involved, for locking up the converter.
I dont chit about auto trannys
I dont understand what the torque converter exactly
does and how it feels when the car is locked up.
Old Apr 25, 2005 | 10:09 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
thanks for the part# and the heads up on the swap guys!!
I might try this setup for my car.
Old Apr 25, 2005 | 03:03 PM
85cmroz28's Avatar
Engine: L69
The torque convertor connects the engine to the transmission. It's pretty much a fluid-filled cylinder with 2 propellers on each side. When the engine turns at the correct RPMs, the spinning of the engine side propeller will spin the transmission side propeller- which will turn the transmission. When this happens, since it is the fluid doing the spinning, there is naturally some slippage between the engine and the tranny. A torque convertor lockup switch will make the torque convertor directly connect the engine to the tranny.
HorseflyDF- there is always power being sent to the tc lockup, but when you connect the 2 wires on the ALDL, it ground the tc lockup, causing it to lock.
My GM Dealer wanted like $60 for the switch- I found it at Advance Auto for $25- just give them the GM P/N.
Old Apr 25, 2005 | 03:57 PM
HorseflyDF's Avatar
Car: 86 Camaro Z28
thanks
i will check the aldl terminals for power.
Why did u need to buy a special switch if all you have
to do is connect a and f to lock the tcc?
Is that because you have a vacuum to lock the tcc?
Old Apr 25, 2005 | 07:36 PM
Apeiron's Avatar
Engine: 383 Carb
The vacuum switch is to unlock the converter automatically near WOT.
Old Apr 25, 2005 | 08:12 PM
HorseflyDF's Avatar
Car: 86 Camaro Z28
tcc vacuum switch
So if your car came out of the factory
with a cpu the car would not have a vacuum switch
to unlock the converter at wot.. correct?
Old Apr 25, 2005 | 08:15 PM
Apeiron's Avatar
Engine: 383 Carb
Right
Old Apr 25, 2005 | 08:34 PM
HorseflyDF's Avatar
Car: 86 Camaro Z28
thanks
now I dont have to search for something that
doesnt exist.
Old Apr 30, 2005 | 10:56 PM
85cmroz28's Avatar
Engine: L69
As a side note, I have found(and TCI and PAINLESS have also confirmed) that these TC Lockup vaccum switches work best with manifold vaccum. On most Holley carbs, there is a manifold vaccum connection right under the primary fuel bowl on the throttle body.
Old May 1, 2005 | 01:35 AM
Apeiron's Avatar
Engine: 383 Carb
I'd still rather use ported.
Old Sep 1, 2005 | 08:55 AM
Andy89GTA's Avatar
Car: '85 Berlinetta Hardtop
Engine: 388
Guys, Can you tell me which 2 pins on the ALDL to connect to get the TCC to lock up? Thanks!
Old Sep 1, 2005 | 10:38 AM
Andy89GTA's Avatar
Engine: 388
Nevermind - found it in the Tech Articles section. Thanks anyway. https://www.thirdgen.org/newdesign/t...ueswitch.shtml
jklein337
Sep 19, 2018 06:23 PM
Fox118
Sep 1, 2015 04:07 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
DIY PROM
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
