dash decal
Old Apr 25, 2005 | 09:52 AM
Gaccett32's Avatar
Car: 1992 Firebird
Transmission: 4l60
Axle/Gears: 10 Bolt 3.08 Posi
dash decal
Where can I find a replacement (besides a junkyard) for a passenger side dash decal that say 'performance suspension' or something like that, I cant remeber its been so long since it broke off.
Old Apr 25, 2005 | 10:09 AM
foney_email's Avatar
Car: 97 200sx se-r, 82 Trans/Am
Engine: 350 bored to 355
Axle/Gears: 9 bolt 3.45
http://cgi.ebay.com/ebaymotors/ws/eB...category=33705
$10 buy it now
Old Apr 25, 2005 | 10:12 AM
Re: dash decal
Originally posted by Gaccett32
Flowmaster 2-1/2 cat back exhaust
Edelbrock Intake
Chip From TBIchips
Posi Diff
6spd 700r4
Ram Air Hood, Fiberglass, 97 style
Cragar Aluminum Chrome Rims
I think you mean 4 speed 700r4, right?
Old Apr 25, 2005 | 10:22 AM
Gaccett32's Avatar
Car: 1992 Firebird
Transmission: 4l60
Thanks I forgot about ebay.
Its been worked to 6spd, trust me at 130mph and 2500rpm its a 6 spd
Old Apr 25, 2005 | 11:04 AM
Care to explain? Even if you had a split differential, you would have 8, and not 6. How can you work over another 2 gears?
I have never seen, read, or heard about this, and I am 99% sure it is impossible, but I don't claim to know everything.
Tell me what you did. On a side note, have you ever seen a 6 speed auto shifter, besides on newer tip-tronic transmissions.
Old Apr 25, 2005 | 03:00 PM
Gaccett32's Avatar
Car: 1992 Firebird
Transmission: 4l60
To be honest I dont know, the previuos owner had the work done at a local shop, but I know hes telling the truth because Ive counted the number of shifts. I have seen other auto trans worked out to a 6 spd, and you can order them new. There was one on an episode of Horse Power TV on spike. And I dont think the previuos owner knew what was doen either, becuase he wasnt very informative when he sold the car, everyhting he had done he had it done at a shop.
Old Apr 25, 2005 | 08:43 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
I heard something simlar years ago. I was told that the computer drops the RPM down to highway mode at a very high speed, usually not reached by normal driving. He said that with a custom programmed chip, you can drop the highway mode shift points to a lower, more reasonable level. The guy that told me about this also said he was getting about 27 mpg out of his 350 when highway driving!
Old Apr 25, 2005 | 09:48 PM
stiers's Avatar
If anyone other than you said this I would have called BS.
Old Apr 25, 2005 | 10:26 PM
Gaccett32's Avatar
Car: 1992 Firebird
Transmission: 4l60
The guy had a hypertech chip in it, I replaced it because it sucked, and put in another(see sig). Didnt change the transmission except firmer shifts better down shifting, the car will shift into 6th even at 50mph at like 1000rpm, I do get about 25mpg on the highway at 85mph and 2000rpm. But still horrible city,about 15mpg.
Old Apr 25, 2005 | 11:58 PM
86IROCTHD's Avatar
Car: 88 Trans Am
Engine: lt1 intaked 355 makin 277 on 25 psi of fuel pressure and stock timing :)
Transmission: A4 stock... that moved a mobile dyno a foot shifting into 2nd :)
i am sorry i think i am gonna call bs but hell i can feel my car "shift" 5 times.... but its not a 5 speed... i belive what he is thinking is a shift is actually the converter lock up..... i know i can tell when it locks up in 3rd.... drops about 400 rpm i belive... and hell i can hit 135 in 3rd .... but i honestly dont belive this is possiable unless the whole tranny was reconfigured with diff internals and a diff valve body... i can change a ie gear ratio of a tranny but not how many gears it has....
Old Apr 26, 2005 | 05:35 PM
scottmoyer's Avatar
I'll do it then!!
Old Apr 26, 2005 | 05:39 PM
scottmoyer's Avatar
I called fastchip.com today and asked them about this. They said that they are unaware of any programming that allows the RPMs to drop considerably more at high speeds. They said that I might get better gas milage out of my car by using a better program than factory by using more efficient settings, but it would only show about 14hp at the wheels and maybe increase mileage minimally.
Old Apr 26, 2005 | 07:20 PM
Gaccett32's Avatar
Car: 1992 Firebird
Transmission: 4l60
Im just relaying what the previous owner claimed and what ive seen with my own eyes, Im not talking about feeling it, I can see each shift on my tach. Maybe it was just the torqu converter and the previous owner is full of it. I do know that there are companies that take a transmission and add more gears, if you watch Horsepower TV you can see an example of this in one of their episodes, they put a 6spd automatic in a project car. There are also overdrive devices that you can add onto the back of the transmission to give it an overdrive gear, the only way to determine what the guy did to the transmission is to tear it apart, which will never happen unless I FUBAR it. If I see the guy again Ill ask him about it.
Old Apr 26, 2005 | 10:05 PM
86IROCTHD's Avatar
Car: 88 Trans Am
i would belive that they are adding "gears" to some trannys but not a 700r4... and when my converter locks up on 3rd it feels like a shift and i can see an rpm change on the tach as well.. so i really doubt u have a tranny with 6 speeds and the device that u install on the back of the tranny to "split" the gears or add an over drive to every gear is also like 2500 bucks
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
86IROC112
Nov 7, 2015 06:50 AM
Fanatic1074
Oct 2, 2015 03:47 PM
lewandom
Oct 1, 2015 08:15 AM
Eric-86sc
Sep 28, 2015 11:37 AM
