please approve on this posi
Old Jun 17, 2005 | 02:07 PM
demetri's Avatar
I was looking at this site and this is what I found.
http://emporium.markwilliams.com/pro...sp?prodid=3227
i want 3.42 gears. if this will not work tell me something that will please
Old Jun 17, 2005 | 02:22 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
it'll work from what i can tell, you do have a 10 bolt correct?
Old Jun 17, 2005 | 04:19 PM
demetri's Avatar
i Dont know how do i check??
Old Jun 17, 2005 | 04:23 PM
Jade Grey's Avatar
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
No, it will not work. You most likely have a 7.5" 10-bolt rear end. The 8.5" 10-bolts were used on 2nd Gen F-body's.
Old Jun 17, 2005 | 04:59 PM
demetri's Avatar
they dont have it on that site. where could i buy something like that from? plus how do i check because i want to get the right rearend
Old Jun 17, 2005 | 05:09 PM
Jade Grey's Avatar
Engine: 305TPI
www.gearsareus.com sells Eaton posi units for the 7.5" 10-bolts. Their prices are comptetive too.
Edit: Simple way to check is to count the cover bolts.
Old Jun 17, 2005 | 05:23 PM
demetri's Avatar
its a 10 bolt but how i check the inches or whatever?
Old Jun 17, 2005 | 05:41 PM
Jade Grey's Avatar
Engine: 305TPI
Well, you could remove the cover and physically measure the ring, but that would be a waste of time.
You have a 7.5" (sometimes seen as 7.625") 10-bolt rear end.
Old Jun 17, 2005 | 05:45 PM
demetri's Avatar
thx i also found this http://www.moserengineering.com/mose...s.asp?CatID=24
also what about spline?
Old Jun 17, 2005 | 05:59 PM
demetri's Avatar
what does my camaro have 26 or 28 spline?
Old Jun 17, 2005 | 06:42 PM
Benm109's Avatar
Car: 1991 Chevy Camaro
Your 91 has 28 spline axles.
Old Jun 18, 2005 | 10:55 AM
demetri's Avatar
Are you sure? Because i cant find any eaton posi's with a 28 spline
Old Jun 18, 2005 | 02:23 PM
Benm109's Avatar
Unless one of the previous owners swapped out the rear end. 82-88 F-Bodies got 26 spline 10-bolts, 89 was the changeover year, and 90-92 F-Bodies got 28 spline 10-bolts.
Eaton makes LSDs for 28 spline 10-bolts, look at the second application on their website: http://www.traction.eaton.com/prod5.htm
Old Jun 18, 2005 | 02:58 PM
demetri's Avatar
No I am the real owner, but that would mean that I have a 7.625" ????
19599-010 part number
Old Jun 18, 2005 | 05:21 PM
Jade Grey's Avatar
Engine: 305TPI
Yes that's the part you want, and reread my last post. I mentioned the 7.625" measure already.
The ring gears are the same size, the method used to measure them was changed. At least, that's what I have be told.
Old Jun 18, 2005 | 05:25 PM
demetri's Avatar
Ok thanks guys, I found one for 420 plus shipping.
Old Jun 19, 2005 | 02:48 AM
Pro Built Automatics's Avatar
Go to https://www.justdifferentials.com/st...cat=172&page=1 they are $359.00, plus shipping.
Old Jun 19, 2005 | 08:37 AM
Jade Grey's Avatar
Engine: 305TPI
Hey Probuilt, how are you affiliated with www.justdifferentials.com? I see on the footer of the website that it's sponsored by you. I'm just curious.
Old Jun 19, 2005 | 04:05 PM
I am the owner.
Old Jun 19, 2005 | 09:07 PM
demetri's Avatar
thats cool, guess you cant give me a 2% discount on that posi eh? lol
Old Jun 19, 2005 | 09:38 PM
wicked1's Avatar
Car: 89 Trans Am Gta
Engine: 305 now, Just bought my 355 today, ready to install~~~
Transmission: 5 speed
To PRO BUILT ....
I have an 89 Trans Am GTA 5 Speed ..... Was told it has a stock 3.45 gear in the rear end. Can u tell me if its a 7.5 " 10 bolt rear end? And if its 26 or 28 spline? I saw u said it was a "changeover" year ... I am looking to put a 373 gear in it, as I am swapping out the motor to a 355 300 horse this week... Any info would be helpful ... Also if the gears will just fit right in or if I have to change the carrier.... Thank you! Scott
Old Jun 20, 2005 | 12:04 AM
Jade Grey's Avatar
Engine: 305TPI
If yor car has 3.45 gears in it, then you have a Borg-Warner 9-bolt rear end. Quite a lot of '89 GTA's received that rear end from the factory.
Old Jun 20, 2005 | 03:16 PM
wicked1's Avatar
Rear end
So is the Borg Warner rear end better than the others or worse ? What else do u know about it?
Old Jun 20, 2005 | 08:10 PM
Jade Grey's Avatar
Engine: 305TPI
There's plenty of information about the BW 9-bolt on this site if you care to search.
The 9-bolt is considered stronger than the 10-bolt rear end. The 9-bolt does not use c-clips for axle retention. The 9-bolt uses 4, not 2, spider gears in the posi carrier. I believe 1989 was the last year they were used in the F-body.
The bad part about the 9-bolt is the scarcity of parts. It's essentially an Australian rear end. Check out http://www.9bolt.com. I believe a TGO member runs that site.
KO1
16
Oct 15, 2015 05:00 PM
92projectcamaro
Sep 29, 2015 07:07 PM
