Need a close up picture.. who has it?
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
i need a close picture of the LT1 intake, from the rear.. that has the modified cut out part of the EGR boss showing.. you know the part that would normally hit the distributer?
i looked on LT1intake.com but i cant see what i need to.. im trying to cut the boss for the clearance on the distributer but i dont want to cut too deep and i dont have a spare distributer to use at the moment..
anyone have a picture they can post?
also what are you guys using for the distributer hold down? it looks like some type of spring next to the bolt, what exactly is that?
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
i don't have a pic of how much you need to cut out to clearence the dist. but i do have a pic of what i am doing for the dist. hold down.i fabbed a aluminum block and welded it to the intake.
Engine: 4.3 Turbo
Hey John... um wow.. who the hell hacked that thing..
no i wanted a picture of the small chunk that has to be grinded out from the EGR boss so the distributer can sit down and not hit..
Engine: 4.3 Turbo
ahahahha no you're not.. sorry.. thanks for the pics but its not quite what i was looking for..
BUT.. the distributer hold down was awesome.. what is the height of the block you used? and what size thread did you tap it with?
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
You'll find lots of pictures on intakes at my site. Click on each "color" to see a variaty of angle shots. Not all colors have the exact same angles so you may have to lokm at all of them to see what you're looking for. Here's the link.
http://www.lt1intake.com/Painting.htm
Engine: 4.3 Turbo
yep.. those pics did help.. thats what i needed...
oh hey, i got the EGR adapter finally finished. i used 1/2 plumers brass 90* elbow's.. 1/2 coppers pipe.. 16 gauge 1/8 steel plate to be able to bolt the EGR and JB weld the brass fittings.. looks good.. needs paint though
as soon as i find our Digi cam i'll snap some pics.. only cost me 8$ for parts @ home depot
now i just have to run the other metal hose to the header, drill the primary and weld int he bung..
oh and John, you have a PM
Engine: 5.7 HSR
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Originally posted by John Millican
I "hacked that thing". It's the first step in total egr casting removal to run a large cap distributor which is what I thought you were looking for.
-- Joe
Engine: 4.0L
Originally posted by anesthes
Why run a large cap ?
-- Joe
-- Joe
Some also say the large cap is better then the small cap at high rpm's since there's less spark scatter because the spacing is wider inside the cap.
I prefer to stay with a small cap with a LT1 intake conversion becasue of the amount of work to convert the intake. It's easier to swap to a small cap distributor.
Engine: 4.0L
Engine: 4.3 Turbo
to get the exhaust over to the manifold.. you have to use the LT1 crossover tube.. BUT you have to modify it so it wont interfere with the hold down bolt.. i put a another 90* bend in it, upwards then it will go over the valve covers..
I also put the coolant fitings in the front.. just for more room
Engine: 4.3 Turbo
trust me.. i'll post them.. soon as i can find the damn digi cam.. last i saw it, it was in the wifes car.. now its not there.. its pissing me off..
the EGR cross over tube to the header is not completed because i would have to pull the header, drill and weld the fiting in.
Car: '86 Iroc, '87 Iroc Vert
Engine: 350 TPI, 305 TPI
Transmission: T5 in both
Axle/Gears: 3.73, 3.45 both LSD's
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally posted by OneBadZ4U.Ok, it's been a few weeks, you have to have the camera by now. Let's see those pictures ehh?
Engine: 4.3 Turbo
yes its done.. and our camera is MIA.. i'll go next door and get my neighbor to take a few.. still needs to be painted though.. pics will be of the manifold not installed.. BUT i will bolt everything on..
Engine: 4.3 Turbo
for pictures.. go to the thread.. "LT1 intake on an L98".. pics are at the bottom
Pac J
May 17, 2020 10:44 AM
