Simple Smog Pump Help!
Old Jul 12, 2005 | 08:53 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
Okay, it recently came to my attention that my serpentine belt is squeaking. I figured since I have to replace it anyway, I might as well get rid of the smog pump. I read the tech article and it helped in no way whatsoever. I tried a few searches, and still nothing. So I'm just gonna ask...
1) How do you actually remove the smug pump?
2) Are there any pipes/hoses that need to come out with it?
3) How do you reroute the belt?
4) (stupid question ) The smog pump is the one under the AC pump right?
I want to do this, and my car is my daily driver so I can't afford any surprises. Thanks for any hlep.
Old Jul 12, 2005 | 09:49 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
There are two torx bits that hold the smog pump to the accessory bracket. There is an AIR fitting that is held onto the back of the pump with a few bolts. Surely a search would have brought this up. Take a few minutes with a flashlight and take a look at the pump itself. It is pretty seld explanatory. As for the routing look at the tech article again.
Old Jul 12, 2005 | 09:52 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
This may help. The second diagram down is the one you need.
Old Jul 13, 2005 | 11:59 AM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
That's exactly what I needed.
Old Aug 21, 2012 | 09:19 PM
1slwz's Avatar
Re: Simple Smog Pump Help!
What length belt did you use.
Old Aug 21, 2012 | 09:28 PM
jrhaus76's Avatar
Car: 1989 IROC-Z28
Engine: L98 - 350 TPI
Transmission: MD8 - 700R4
Axle/Gears: GH3/G80 - 2.77 POSI
96.8 inches I believe. I just did this this week.
To remove the pump, you have to remove the 3 10mm bolts holding the pulley on first so you can access the torx bolts. Also, there is a small pipe bolted to the back of the pump, remove that too. Once the pulley and pump are out, put the new belt on.
Have you addressed the AIR tubes on the manifolds?
Old Jan 28, 2013 | 07:56 PM
mtg85's Avatar
Does anyone have a picture of this?
I'm a little unsure of what to do as far as plugging the manifold. What do you use to do this and I can't tell where I'll need to plug it. Also, where does the pipe on the back of the SP go and does it need to be plugged?
My smog pump has gone bad and I'd much prefer to just get rid of it than buy a new one. Thanks for any help!
Old Oct 17, 2014 | 11:07 PM
88gtadan's Avatar
Car: 1988 Pontiac gta
Engine: 5.7 tpi
Axle/Gears: Borg Warner 3.27
Nicely wrote up here thanks
Old Oct 18, 2014 | 10:33 AM
88gtadan's Avatar
Engine: 5.7 tpi
Well I started this little project today
Got the 3 10mm bolts out Went to torx and after I slipped 4 times I put the 3 10 mm bolts back in and went back inside lol
Maybe next time I'll try air tools
Old Oct 18, 2014 | 10:35 AM
88gtadan's Avatar
Engine: 5.7 tpi
bump
Old Oct 27, 2014 | 12:11 PM
88gtadan's Avatar
Engine: 5.7 tpi
Nvm got it BAM!
As usual they need to make a torx 43
I used a 45 and got it out
Old Oct 27, 2014 | 08:55 PM
88gtadan's Avatar
Engine: 5.7 tpi
I ended up using a longer belt the 96.8 belt wasn't gonna make it on,
plus my belt routing is exactly like the delete route with or without the smog pump
I ended up using a gates k060980 belt
Old Apr 23, 2018 | 06:17 PM
pfsteichen's Avatar
Car: 92 Z28 convertible
Engine: 305 tpi
Transmission: Auto matic
Okay I'm making a big move with my car this spring, and part of it is headers and a y pipe. So I was wondering about the air tubes going into the exhaust manifold. Main question is does removing the smog pump add any horse power? And is it better go with a delete pulley, or re route with a different belt?
Old Apr 25, 2018 | 01:38 PM
83 Gman's Avatar
Smog pump doesn't add horsepower when removed, other than some parasitic drag is taken off the engine which is minimal.
If you could run the pump all the time and pump air to the area of the header flange it would give a better performance gain, as it creates a afterburn effect to help scavenge the cylinders better.
You would have to richen the fuel mixture when doing so. Plug reading can be your friend.
The air pump, in normal operation, is only used when the engine is cold to reduce emissions. When warm, it shuts off.
Old Apr 26, 2018 | 07:46 AM
kfsullivan's Avatar
Car: 1988 Trans Am w/ WS6
Transmission: 5-Speed
Last summer I removed the air pump and tubes when I installed new Dyno Don's headers and y-pipe plus a Magnaflow Cat and 3" cat-back exhaust. Dyno Don has an option for header with the tubes but I didn't want the clutter; however, I did add the pulley delete to maintain the same look at the front end.
Old Mar 23, 2019 | 11:08 PM
91rs4life2's Avatar
Bump
italiano67
Dec 11, 2016 09:21 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
gta90
Sep 15, 2015 04:00 PM
camaro_rs350
Northern California
Aug 18, 2015 12:38 AM
mustangman65_79
Aug 7, 2015 09:55 PM
