surprise
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
surprise
Look what came in the mail today... Hmmm
This is my progress so far as of 6pm
The accessories on these cars are a PITA. Every hex bolt is stripped. I can't even get the alternator out. My plan is to have this swap done by the weekend. Probably won't happen... Why does everything always have to go WRONG when you are on a schedual?
So.. What do you all think of my VHSR?
Engine: all 225+ RWHP
Transmission: all OD
thats not a vortec stealthram is it?
Couldnt tell from the pics, just curious?
later
Jeremy
later
Jeremy
It sure is a vortec stealth ram.
Car: 88 GTA
Engine: 406ci
Transmission: Tremec 3550
They werent on my car anyway. They are Torx, and you need to use the Torx tools else you will strip them. You can sometimes use an allen kep to remove the bolts, but you'll strip it out about 50% of the time. Though sometimes, if you use the proper Torx tool, you can usually loosen the bolts after you strip them with the allen key, because the allen key usually doesn't strip out the outer points.There are 2 different size Torx, I forgot what size they are because I replaced all mine with normal bolts. I suggest you do the same.
Ohhhhh.
U officially suck :-)
Wonder if I can get a vortec stealthram unbackoredered now. tkae it yours cam from Summit form boxes on the ground.
later
JEremy
later
JEremy
Sure isn't. It's from Thunder Racing.
Interesting.
Did you purchase it recently or had u been on back ordered status?
I'm only asking because the date from summit moved from 8/12 to 8/22 :-(
thanks
Jeremy
thanks
Jeremy
I purchased it a while ago. Probably around June 4th. But it was well worth the wait.
Car: 90 Formula 350
Axle/Gears: Dana 44 3.54
BADNBLK
Convertibles
65
Feb 10, 2016 03:36 PM
buckeyecelt
Sep 24, 2015 05:50 AM
dbrochard
Sep 19, 2015 08:13 PM
