MAF and engine mods
Old Aug 8, 2005 | 06:43 AM
rcwest32's Avatar
MAF and engine mods
Hi gang. New to the 3rd gen scene. I've been wanting one for a while but now the timing is right.
On the MAF equipped cars, do they adjust the fuel curve if you do mods? I plan on doing all the bolt ons, and already have a Vortech supercharger waiting to go on.
I've helped several guys build up their 5.0 MAF equipped Mustangs(yeah I know, YUK), and zero computer mods were needed. In fact, my best friend just came back from the strip with a 122 mph timeslip in his hand.
Does GM's MAF do the same good job of compensating for mods as the Furd setup? I hope so! I have my eyes on this real nice '90 Z/28 and would love to scarf it up! Thanks, my friends!
Old Aug 8, 2005 | 10:56 AM
cdartz's Avatar
The 90 Camaro you mentioned will not have a MAF. 89 was the last year for the MAF in a thirdgen. 90-92 used a barometric pressure sensor (MAP).
Old Aug 8, 2005 | 11:17 AM
rcwest32's Avatar
I was going to convert it to MAF. If that's not feasible, I'll pass on it and look at an '89 or earlier MAF car.
Old Aug 8, 2005 | 12:06 PM
Mcdamit's Avatar
Car: 89' Iroc-Z G92
Engine: TPI 305 G92
Axle/Gears: Limited 9 bolt, 3.45
If
You can convert it to maf if you want to, but it will be a pita. The Maf will generally stay with you as long as you dont do major mods(bolt ons are fine). The supercharger you are going to have to tune for. But since that requires a fuel injector change I see no problems. Just adjust your afr tables.
Old Aug 8, 2005 | 12:26 PM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Keep in mind the ferd guys don't do computer mods, because they can't. They are giving up power just like you'll be doing if you don't look into computer tuning. GM MAF equiped cars will acount for minor mods such as headers, and filter changes, but you'll quickly get out of wack with things like injectors, intakes (HSR), or blowers. The ferd stuff is more adaptable than the GM stuff no doubt. It seems that the ford code is more basic and because of this can stand changes to the motor better. The GM computers are more complex and therefore are more easily "upset" by mods.The map sensor equiped cars are the ones to get if you want to run boost. You can change the code the ECM runs on to the code that orignally came in the syclone and typhoons ($49). Which can see boost, stock can't. Then you can tune your car without the need for finicky FMU's.
Old Aug 8, 2005 | 12:45 PM
Guest
Guest
Posts: n/a
Thirdgens are a little different, people here switch from MAF to SD. In a nutshell, the reason is that there arent 15 million different size and brand replacement MAFs available, there is stock, stock, and stock. You'd be better off with MAF on a supercharger though IMO, unless you feel like making a bunch of other changes.
Old Aug 8, 2005 | 03:03 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
The MAF cars are more forgiving on making mods. However if you do big changes you will still need to have the computer reprogrammed. If you are set on a MAF car try to get an 1989 model. It will have all the latest features.
Old Aug 8, 2005 | 05:21 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Transmission: TH-700-R4
On the general map sensored car
How may bolt ons and what are they can you do before tuning is needed? I'm assuming headers and catbacks and intakes.
Old Aug 8, 2005 | 06:24 PM
Mcdamit's Avatar
Car: 89' Iroc-Z G92
Engine: TPI 305 G92
just about anything screws up a Map car.
Old Aug 8, 2005 | 11:48 PM
rcwest32's Avatar
Here are my plans:
Supercharger (8 psi)
Headers
Good exhaust throughout
Ported stock heads
Ported stock intake
Maybe underdrive pulleys
I don't plan on doing any cam changes....MAYBE a mild cam, no more than 215 @ .050, but I doubt it. I will probably rebuild the engine to stock specs, other than the ported 083's. They can be made to flow well enough with a port job.
That's about it that would mess with the calibration. I do plan a gear change and a torque converter change, but that's about it.
Guess I'll have to find a shop nearby that does dyno tuning and chip burning! Thanks guys!
Old Aug 12, 2005 | 09:09 PM
DON 88T/A's Avatar
Madmax-why do you feel MAF is better with a supercharger?
have you delt much with MAF and Supercharging before?...just curious.
Old Aug 13, 2005 | 01:04 AM
Guest
Guest
Posts: n/a
I have one setup like that now.
I think if you go with SD, you really need to run the Sy/Ty and a 2 or 3 bar MAP and program it all. Utimately, thats the best setup. As it is with the thirdgen MAP, once the reading pegs it has no clue what is going on. At least with the MAF, it is still able to read the airflow until the MAF maxes out. I've only had that happen at WOT in the upper RPMs and the stock tune with out of the box Vortech patches (FMU, boost retard) work just fine with it. Partial throttle in boost it seemingly knows what to do, the AFR is always in line even with the FMU disconnected.
Old Aug 13, 2005 | 11:01 AM
DON 88T/A's Avatar
How much boost are you running with you set-up?
Any other mods like heads/cam?
Old Aug 13, 2005 | 11:05 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Although that may be true, my car is MAP and has longtube headers, dual exhaust, and CAI and runs better than before.
Frozer!!!
Jan 19, 2024 04:55 PM
89GTAOz
May 16, 2020 09:31 AM
perZ
Aug 15, 2015 01:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
matthew911
Aug 12, 2015 09:38 AM
