anyone who is afraid of EFI-to-carb swap
Old Aug 23, 2005 | 11:27 AM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
I would just like to let you all know that I get 17 miles per gallon with my built 350 in average city/highway combo driving. Yeah, I have 2.73 gears, which makes a difference, but I am getting nearly the same mileage as my old 305 TBI got. I have a higher stall converter, also. You can see all of my mods in the signature. Just wanted to let you all know.
About 13-15mpg strictly city, and about 20-22 mostly highway (no lockup switch)
Also, I noticed an increase of 1mpg when I switched from standard 10w40 to Mobil 1 10w30.
Old Aug 23, 2005 | 01:19 PM
EPAisGAY's Avatar
Car: 92 Camaro RS
Engine: ZZ4 Crate Engine
Transmission: 700R4 w/shiftkit and 3k stall
I actually used to get 25+ mpg highway w/ my 305 TBI and 3.23s. Now I get ~21mpg w/a 350. You might have had something wrong w/your old setup if you only managed 21mpg.
BTW I got about 21mpg w/3.23s and now 20.5 mpg with 3.73s on the highway. If I were you I'd get 3.73s
Old Aug 23, 2005 | 05:30 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
When I can afford it.
<--- college kid living on his own, working for $7/hr
Old Aug 24, 2005 | 09:45 PM
zoomzoom26's Avatar
Car: 91 RS
Engine: 305 TBI -> 350 TBI
Transmission: TH700R4
I have a 305 TBI right now with 3.23, stock th700r4. high flow exhaust and cold air intake, and i get like 22 average driving, and like 25+ highway, looking to do 350 tbi swap now.
Old Aug 25, 2005 | 11:40 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
my 310/700r4 w/ lockup/4.10 rear with the old holley 600cfm vaccuum secondary netted me consistant 22mpg on the highway. about 15 in town. WAY better than todays big SUV's!
Old Aug 25, 2005 | 05:20 PM
Fast355's Avatar
Car: 1983 G20 Chevy
My TBI 305 (well really 312) with a 700r4 w/2,000 stall, and 3.08 gears gets 17-19 city and 22-24 on the highway. This is in a 5,000+ lbs G20.
Old Aug 25, 2005 | 08:14 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Old Sep 4, 2005 | 01:51 AM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
LOL, my setup nets me 9/10 mpg.......and I love it!!!
Old Sep 4, 2005 | 05:40 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Token:
I really enjoyed your audio clips in your sig. "Exhaust clips: idling (130k) revving (100k) lopey! (160k)" Thought I'd share mine:
Idling and reving (4mb)... and yes, that is a quadrajet.
Specs for the engine are in my post on this page.
Haven't gotten around to checking the mileage yet (keep doing WOT blasts) but I think it isn't going to be too good...
Old Sep 10, 2005 | 05:02 PM
specvgini's Avatar
Car: 1991 Formula
Engine: 5.7
FUEL PUMP
What did you do about your higher pressure stock fuel pump when you switched to carb on your L98? i really don't wanna pull mine out and i'm looking for alternatives. i tryed turning it off and using a 4psi pump further down the line but that didn't work cause the new pump couldn't pull fuel past the old one. so can i leave my stock pump in and maybe get a fuel pressure regulator to turn it down a whole bunch?
Old Sep 10, 2005 | 05:13 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Re: FUEL PUMP
Old Sep 10, 2005 | 05:49 PM
specvgini's Avatar
Car: 1991 Formula
Engine: 5.7
nice. you have a part number? is that just a standard fuel pressure regulator? how much did it cost you?
Old Sep 11, 2005 | 03:58 PM
85z28guy's Avatar
Car: 85' Z28
Engine: 383 roller
Axle/Gears: Ford 9" 3.70
I'm guessing that is more expensive then this one from holley, it was $75 Cad http://www.holley.com/products.asp?product=12-803BP .They aren't a standard regulator, being that it has to have a return line. A lot of them out there are just one in, and two regulated outs. You need one in, one regulated out, and one just out.
Old Sep 11, 2005 | 04:13 PM
specvgini's Avatar
Car: 1991 Formula
Engine: 5.7
so i'll be using my return line in my car then? also how about the computer? will the stock pump work without it?
Old Sep 11, 2005 | 07:42 PM
85z28guy's Avatar
Car: 85' Z28
Engine: 383 roller
Yea you will have two fuel lines buy the drivers side fender well. One will be 1/2". the other 3/8" I beleive. It was awhile ago, but I think the larger one was the return The regulator is all marked, just don't overtighten the lines in. I just took the regulator and lines to Brafasco and Cummins hydraulics, and they made everything I needed with all the fittings for me for like $20. Things may be a little different for you, but I just took out ALL the wiring from the passenger side, including all the wires to the ecm. The fuel pump will not work, I just wired mine to a switch that I put in the ash tray (no one ever smokes in my car, ever). This is very easy since the wiring for the fuel pump is right behind the back seat if you lift the carpet. I beleive the pink wire was power, but use a test light to make sure . The best way would be to wire to a oil pressure switch, but this way if someone steals my car they won't get very far Also, depending on year you may need to grab a vss box from a wrecker to get your speedo working correctly.
Old Sep 15, 2005 | 02:17 PM
specvgini's Avatar
Car: 1991 Formula
Engine: 5.7
ok i just got back from my local car shop. they are prett reputable, and the guy there said that going that rout wouldn't be good because the fuel pump will burn out.. i've been trying to figure this out for a long time now and all signs keep pointing tords pulling the damn pump out. so i'm gonna just do it and get it done. now my question is whats the process of bypassing the old pump? just a straight hose?
Old Sep 15, 2005 | 07:57 PM
NastyL98_T/A's Avatar
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
It will work, but the right way is to get an external electric pump. Not to mention the stock pump flows enough for 240 hp..
Old Sep 16, 2005 | 08:37 AM
my3rdgen's Avatar
Car: 2013 Challenger RT
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
Is the intank pump on the q-jet equipped 3rdgens the same as the tbi pump? I am asking because I replaced my mechanical pump with a Carter OEM replacement fuel pump, and I chucked the CC q-jet in favor of a q-jet from a 78 Z28.
It was running OK till I hooked the power to the fuel pump back up. Now its rich enough to melt your eyes out.
I have checked the return line to make sure it wasn't plugged. It was OK.
Old Sep 16, 2005 | 10:04 AM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Axle/Gears: 9" with 4.11's
i got like 8 mpg in the city and about 10-12 on the highway with my old roller 355...
Old Sep 16, 2005 | 11:26 AM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
yea.. and when gas is 7 dollars a gallon... lol Anyway, go work for a parts store if you have an interest in cars. They need younger people with a will to learn rather then old dogs that cant learn new tricks. Check the vendor review board for details. OR! if you know computers, get a tech job that starts at 11+hr with no experience.
For the topic, my 305 got 20mpg when I did a carb swap. But yea, the 650 is to much for it, even with smaller jets. Its all I got and I'm replacing the engine before I replace the carb!
Old Sep 21, 2005 | 04:48 PM
specvgini's Avatar
Car: 1991 Formula
Engine: 5.7
Ok i'm still freakin lost about this whole switch over. i'm reading what u guys post and what ppl tell me around town and everything contradicts eachother. this is what i've gathered:
By removing the intank pump and ecu i won't have gauges that work properly.
If i geet a pressure regulator and keep the stock pump i was told that would burn the pump out.
And i can't leave the in tank one in and run another down the line and simply turn off the intank...
i would like to do this the way its supposed to be done. and everyone says thats to remove the intank pump. well then how do i get the gauges to work correctly without using the ecm? cause the whole point is to get rid of all that. my main question is do i need a completely different sending unit or something from a carbed car? i donb't under stand how the intank pump is bypassed...
Old Sep 21, 2005 | 05:02 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You're taking what has been stated that was wrong and corrected by others as the facts, in most cases.
- The gages don't feed through the computer. No effect.
- If you keep the in-tank pump operating, you need a regulator that includes a built-in return, i.e., that regulates pressure by returning excess flow to the tank. That type of reg will maintain a constant flow through the in-tank pump, keeping it cool and keeping it from burning out.
- At least you got one out of 3 right, which is acceptable in baseball. Although some have reported leaving the in-tank in and unpowered without problems, the wise course is to remove it if you aren't going to use it (use it or lose it, you know).
- To by-pass the in-tank, remove the sending unit, remove the electric pump from the sending unit, add line to extend the pick-up tube down to where the in-tank pickup was, put a pick-up strainer on it, reinstall the sending unit.
85z28guy's Avatar
Car: 85' Z28
Engine: 383 roller
Gas gauge is not ecm controlled, atleast my 85' wasn't. Fuel pressure is a sender, just keep the old one. Tach will work. Coolant will work if you keep the sender. Voltmeter will work. Only problem you may run into is needing the vss for your speedo, try it and find out. The thing about removing the pump or not is personal opinon. I have seen A LOT of people do it, and not seen one fail. In fact, a discussed it with a couple mechanics and they said it seemed like a good idea. Its up to you if you think its "right" or not. And no, I would never cut a hole in my trunk to get to the sender
Old Sep 21, 2005 | 05:05 PM
specvgini's Avatar
Car: 1991 Formula
Engine: 5.7
i'm in the process now of removing it its just a tremendous pain in the ***. now what your saying has been done a million times i would imagine so i'll take your word for it. thanks
Old Sep 21, 2005 | 10:54 PM
Engine: 450HP 355
mine still has the in tank pump, i've been running a mechanical on the engine sucking through it for 5K miles without any problems...
i just don't have the time to drop the tank.. it looks miserable on these cars
Old Sep 23, 2005 | 05:23 PM
specvgini's Avatar
Car: 1991 Formula
Engine: 5.7
its terrible
Old Sep 23, 2005 | 06:41 PM
Engine: 450HP 355
its terrible
well.. since it's not going anywhere untill next spring i might give it a try.. but i have a feeling that my dual exhaust is gonna get in the way
Old Oct 11, 2005 | 05:44 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Tank Removal
I just did mine - fuel pump replacement - trust me - any exhaust gets in the way. As well as the coil springs, shocks, panhard bars, etc.
BUT - it really wasn't that bad, considering. Took me 8 hours to do mine, out and back in.
Old Oct 12, 2005 | 09:48 PM
specvgini's Avatar
Car: 1991 Formula
Engine: 5.7
i bought that holley bypass style regulator and it fixed my problem. instantley started up and ran at 6-7 psi. perfect solution to this problem. pulling that tank is just rediculous on a gravel drivway in october in newyork lol thanks for the help cars running good. Only issue i have now is that it over heats easily, which i have no clue and i'm ironing out and i haven't connected my kickdown cable yet.
Old Oct 13, 2005 | 01:18 PM
five7kid's Avatar
Then don't drive the car. You're burning up your transmission.
It's not a "kickdown" cable, it a "throttle valve" cable. It varies pressures and such inside the transmission based on throttle position. If it isn't connected, the transmission is going to assume the throttle is at idle, pressures will be low, transmission is dieing a cruel death.
Old Oct 20, 2005 | 07:02 PM
Blkmaroman's Avatar
Car: 1998 zx9r
Engine: 899CC inline 4
Transmission: 6 speed manual
Axle/Gears: 15T front sprocket, 43T rear
i did mine a few weeks ago i just put a piece of hose in the spot where i took the pump out of, i wouldnt use the electric in line pump unless your cam dosent have the profile for the mech pump. The muffler will be in the way getting the tank down and so will the heat shield and a couple of bars. Took me a couple of days but i didnt work on it very long because other stuff to do. My filler neck kept getting in the way getting the tank down so i cut the filler neck in half and put a piece of radiator hose on it to put it back together.
Old Oct 21, 2005 | 03:12 AM
83 Crossfire TA's Avatar
[/B][/QUOTE]
That depends on the transmission… if the valve body is stock then no, it goes into a “limp home” where the line pressure gets jacked up to protect it.
If it’s a modified valve body then it depends on who did what to it. Transgo puts a spacer in the TV that does the same thing as stock, but more so, but some others allowthem to go soft (which for the life of me makes no sense, cables break sometimes and you need to still get the car home).
Most likely unless someone did something dumb no cable is OK, just unpleasant to drive
Old Oct 22, 2005 | 11:57 AM
88_Import_Slaye's Avatar
Car: 88 Camaro
Engine: 310 LG4
Transmission: 700R4 w/2200 stall
Re: Re: FUEL PUMP
exactly what I did! This is the ultimate regulator, you can put a fuel pressure gauge on it and still have a free port for race fuel injection!
BTW: Those who did the mallory regulator setup, can I see some pics? I had to run softline to my regulator from the hard line, want to know how you routed your lines and what you did to them. I'm thinking of some braided mesh or heat wrap.
Old Oct 24, 2005 | 06:54 PM
BigDreams92's Avatar
Car: 1992 RS
Engine: Vortec Headed 383 9.6:1
Transmission: TKO600
Axle/Gears: 10 Bolt Posi 3.73
Here's my set up, not sure if it's right but it seems to work
Old Nov 13, 2005 | 03:05 PM
wiseman9986's Avatar
Car: 82 z28
Axle/Gears: 10 bolt 3.73
i just took my fuel pump out made a pipe with a filter on it to put in the tank and put and edlebrock mech fuel pump on wirks great for 420hp
Old Nov 15, 2005 | 07:23 AM
mw66nova's Avatar
Engine: 7.0L
my father and i are both running stock mechanical pumps for a 1985 z28 and he is running 11.7's and i was running 13.0's with the 305, but plan to run deep into the 12's with the new setup.
Old Dec 14, 2006 | 01:57 PM
cam92rs's Avatar
Car: 25th anniv. camaro
Engine: 305 tbi
im confused on this whole deal to. to go from tbi to carb, i have a intake, carb, distributer. now, i can run the in-tank pump as long as i put a regulater with a return to get the correct amount of fuel to the carb and send the extra back to the tank? if so where do most people install that? on the driverside fender? lately i havnt been making sence of anything, so bear with me on this.
Old Dec 15, 2006 | 11:14 AM
Car: 88 Camaro
Engine: 310 LG4
My mallory 4 port w/return looks nice, but i used braided stainless steel lines for all my fuel stuff and it was getting cluttered under the hood. I moved it to the very back. I drilled a hole from behind the back seats and put a bolt through it, so now the regulator is mounted between the backseat and the back axel. It looks really nice and its easy to setup. I only had to run 1 long line from the back to my carb. The lines from the sending unit are right above my regulator. If I need to adjust the pressure, i pull the line from my carb, stick it on the gauge and have someone read it to me while i adjust the regulator.
that's just how I did it for a few reasons. It probably isnt the best and i'm sure someone will tell me so.
Old Dec 15, 2006 | 08:28 PM
dark_daku89's Avatar
Car: 1992 Camaro RS
Engine: 355 Carbed
Transmission: Th350
Not to hijack the thread or anything but i am going to be replacing my 305 tbi with a 350 carbed motor. I am going to keep my intank fuel pump and run a 3 port return style regulator. I was wondering, once the ecm is out, how can i wire up the fuel pump so it will run?
Old Dec 15, 2006 | 09:14 PM
Engine: 350 4BBL
Cut the Dark Green/white that goes to the fuel pump relay and connect the end of the wire that goes to the relay to an unused ignition wire such as one of the wires that provide power to the injectors. Pink is one and Pink/black is the other. Either one will work. The fuel pump will then run whenever the key is on, powered thru it's original circuit.
Get the right regulator. It's called a "bypass regulator".
Don't forget the ECM controls one fan and the TCC depending on model also.
They sell switches to control these at Jegs & Summit.
Old Dec 26, 2006 | 09:54 AM
shuzdblanc's Avatar
305 w/crossfire injection starts but won't run
If I spray starting fluid or gas down the TBI's, it fires right up but quits in a second or 2. I can hear the intank fuel pump click and buzz when I turn on the ignition key, and a relay clicking under the hood by the driver's side. I took off the fuel filter and cranked the motor but there is no gas in the line. There is at least 5 gals of fuel in the tank. The car sat in a field without a gas cap for about 4 months, is it possible the fuel pump froze up? Also, there is no power to the fuse under the dash. Is there another fuse or fusible link in the circuit? Does this sound like a bad diaphram in the fuel pump? If so, how can I bypass the intank pump? I don't want to drop the rear end to get the tank out.
Please help!
Old Feb 22, 2007 | 06:52 AM
Sir_Lorac's Avatar
Car: '89 Camaro RS
Please help!
Had a very similar problem with my 1989 305 TBI. It turned out to be caused by the piece of rubber hose connecting the pump to the steel fuel line. It was actually dissolved in gasoline. http://img301.imageshack.us/img301/3148/Photo_0144_.jpg
As my car is not very powerful, I wasn't afraid to cut a hole in my trunk (or should I say: install a fuel door ). I had no place and no tools to drop the tank.
Old Feb 23, 2007 | 02:17 AM
With our new gas formulas now, that’s not uncommon either. Recently we were having issues with a newer chevy Silverado which after a new pump install quit 4 days later, and the proper rated hose used in the same location came out looking just like that…
Old May 23, 2010 | 01:25 PM
Bmowild's Avatar
Re: anyone who is afraid of EFI-to-carb swap
OK guys, i'm new in here so bear with me.
I did a 305 tpi to 350 (carburated) swap. I am going from the Electronic Fuel Pump, to a regular mechanical fuel pump. First off the car starts and runs but loads up terribly. Do I need to install a fuel pressure regulator to solve this issue? The Electronic one is still in the tank..Unplugged
Thanks for any help..
Old May 23, 2010 | 02:42 PM
Engine: 450HP 355
I would drop the tank and do this:
Old May 24, 2010 | 12:16 PM
five7kid's Avatar
Documented in a sticky:
https://www.thirdgen.org/forums/carb...nk-pickup.html
A pick-up sock is a good idea to protect the pump.
Personally, I would hook up power to the in-tank pump and get a Mallory 4309 return-style fuel pressure regulator or equivalent.
Old May 24, 2010 | 06:44 PM
Engine: 450HP 355
aaah yes, didn't know there was a sticky about it.
I'm sure a strainer would be a good idea, whoever swapped mine didn't care though. They also clipped the pump power wire which made it suck to swap back to an in-tank pump.
Thirdgen ranch saves the day
Old May 25, 2010 | 08:01 AM
five7kid's Avatar
Actually, your photo wasn't showing up when I replied. Weird.
Old May 25, 2010 | 08:08 AM
irocwagon's Avatar
Car: camaro84.87iroc,91vert
Engine: Lt1, 383tpi,350tbi
Transmission: t56,T5,T5
Axle/Gears: 4thgenunknown,373,323?
i may do that just so i can mount my fuel pump externally..changing for the 3rd time..for some reason the rubber fuel line from pump in tank keeps dissolving
Old Sep 26, 2010 | 05:16 PM
Tommytransam91's Avatar
Car: 1991 firebird
Engine: 383 sbc
Axle/Gears: 3:40 posi
I have a stock 91 firebird 305 tbi with a 700r4. Now my prob is i have a beautiful 383 stroker (carb), i have built for a 77 trans am, but got rid of. now i have the 383 and my 91 firebird. Im shur you can put 2 and 2 together lol i understand what needs to be done fuel wise and everything els but the 700r4 is whats got me in a run around. what needs to be done im shur the ecu controls the lock up i believe? Any tips, steps, etc would be great thanks
Tommy
