True dual thru factory channel
Old Aug 28, 2005 | 04:41 PM
jimp2001's Avatar
Car: Red on Red 89 RS
Engine: LO3 305 TBI
Transmission: TH-700R4
Axle/Gears: 10-bolt / 2.73
I have head of, and seen a picture one of true dual 2.5" pipes run thru the factory location. Does anyone have this type of setup? Can anyone post pictures of this setup? I would like to go that route because I plan on lowering my car and I want true dual without scraping on speed bumps.
Old Aug 28, 2005 | 05:59 PM
blue_tacos's Avatar
Car: 82 Berlinetta 87 Iroc
Engine: 327
A few days too late. I had this on my Berlinetta but I just had it towed off to the yard. I don't believe I have any pics of it. If done properly there will be excellent ground clearance.
Old Aug 28, 2005 | 06:56 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: True dual thru factory channel
Willie
http://members.optushome.com.au/iroc...st/exhaust.htm
Old Aug 28, 2005 | 07:11 PM
crazy3rdgen's Avatar
Car: 2002 SS
Engine: Ls1
Axle/Gears: 3:42 posi
that exhaust is so perfect it should be an option for our 3rd gens, I DEMAND IT! not everyone has the time or money to play around with pipe to get it just right , ya know what I mean? Someone could make mad money off that set up. Thats real nice. How was it done?
Old Aug 28, 2005 | 08:06 PM
jimp2001's Avatar
Engine: LO3 305 TBI
Awesome! I'm bringin that whole page to the shop when I get my exhaust done
Old Aug 28, 2005 | 11:25 PM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
Thanks for the compliments!
How was it done?
I just had to find the right person who would attempt it. I was fortunate. It did take him three hours though. Here's one more not on the website.
Willie
Old Aug 28, 2005 | 11:26 PM
Willie's Avatar
And this one shows the cats in the stock location. Notice they're both flanged for easy removal... not that I ever would....
Willie
Old Aug 28, 2005 | 11:53 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
When I redo mine after the tranny swap I'll definitely try something like that.
Old Aug 29, 2005 | 04:13 PM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
Transmission: 700R4 + Shift Kit
Axle/Gears: Auburn Posi; Richmond 3:73 Gears
Mine similar to Willie's. But not as custom everything was purchesed nothing was made.
Old Aug 29, 2005 | 04:38 PM
Car: 2002 SS
Engine: Ls1
willie how much for your set up? i'm curious, I kno those chambered exhaust are an arm and probably 2 legs. What about yours zNucleaRz?
Old Aug 29, 2005 | 04:41 PM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
250 in parts. about the same for install.
Old Aug 29, 2005 | 07:29 PM
Willie's Avatar
I had this exhaust installed years ago, so let me rattle my brain first.... I spared no expense. Anyone can come up with a similar setup for far less $$$. Let me explain, starting with the mufflers. Mine are custom-length, chambered Stainless Works mufflers. I think the non-polished, standard length units are around $125 each. It was extra for the polishing and even more for the custom length. You can use any straight-through design that's far less $$$.
I bought mandrel bends from Summit. I think I bought six "U" bends but can't remember for sure. Not necessary.
I bought a pair of Flowmaster Y's because I wanted a clean "X" or crossover pipe. I think these were about $37 each. Again, not necessary.
I bought a pair of factory '94 Z28 tips. They are stainless. I had them chrome plated. Not necessary.
$300 for necessary straight pipe sections and labor to weld it all together.
Willie
Old Aug 29, 2005 | 08:11 PM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
I went the reverse route of Willie . I know I wanted something just like his but something I could afford.
2 Dynomax 2 1/2" Intermediate Pipes WLK-47638 165.38
1 Dynomax Universal Tailpipe 2 1/2" (for Drivers side) 35.39
1 Flowmaster Y-Collector Single 3" to dual 2 1/2" (temporary till money allows for a dual cat conversion) 389-Y250300A 39.99
2 Dynomax Race Bullets 2 1/2" 12" long WLK-24215 67.90
1 set of JEG'S Exhaust Turndowns 555-30641 29.99
Install about 5hrs and $250
Old Aug 29, 2005 | 08:25 PM
Car: 2002 SS
Engine: Ls1
thank you guys, i appreciate that greatly and i'm sure alot others will too
Old Mar 8, 2007 | 07:10 AM
Artic-Trans am's Avatar
Car: 87 TA
Engine: 350 modifyed Stelth Ram
Transmission: 350 rew lock up
Axle/Gears: 9"
Hi
Nice way to do it and thanks for telling "how to"!
Have some questions anyway.
Do you have some more pictures from the "over axle" section, and from the "trans section"?
Since you have got al parts from the dealer I would try this set up, but will put in a X-over. (can't see you have one)
If you don't have a picture from the "trans-section" can you explain how yoy did route the tubes from Y-pipe to the Intermediate Pipes.
I thank you for helping others!
Ingar
Old Mar 8, 2007 | 02:47 PM
AC's Avatar
AC
Car: Used to drive a camaro
What would be the cats **** would be combining your 2's engineering / inginuity into an option / parts list for a hooker 2210 LT exhaust (like mine ) I'm going to attempt this once the weather gets warmer and I can work longer than 15 minutes in my garage before my fingers and peepee goes numb......kidding on the fingers part.
Old Mar 8, 2007 | 08:35 PM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
Willie, Sweet ride, not just the exhuast... but through the years, all you've done to your car, it's inspiring
Here is another dual...
http://www.knightfoundation.net/foru...pic.php?t=6134
Rafael
Old Nov 2, 2007 | 07:45 AM
Car: 87 TA
Axle/Gears: 9"
hi zNucleaRz
I was wondering how is your sound with the Dynomax Race Bullets located there?
high or "OK"?
maybe it is more like "if it's to loud, your'e too old"
I am building this now, and I have to deside where to put the mufler...
Old Nov 2, 2007 | 09:00 AM
88transam400tpi's Avatar
Car: 88transam/ 86 iroc-z/ 64 corvette
Engine: ta 400ci tpi/ iroc 327 / vette 327
Transmission: ta 5 speed/ iroc 700r4/ vette m-22
Axle/Gears: ta 3:42/ iroc 3:73/ vette 4:11
wow these exhaust's are nice. can anyone tell me do they work good with a lowered car
Old Nov 2, 2007 | 09:14 AM
Stephen's Avatar
Car: 87 GTA
Any dual exhaust sound clips? I'm trying to figure out what the benefits are, of true duals. Just sound? A single 3", I think flows more cfm than dual 2.5"s. And there's no doubt, true dual WEIGH more, which could offset any hp/performance gain.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Camaro_383
Sep 11, 2015 11:28 PM
Djmathis123
Sep 8, 2015 08:42 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
