Parts for Sale 2006 Keep it Third Gen related please!
NEW! 350 & tranny, fresh heads brackets wiring harness, etc.!! (HUGE LOT)
Old Oct 15, 2005 | 11:30 PM
NEEDforSPEED's Avatar
What you are getting,
Brand New Fresh 350 2-blot main short block from GM,
rebuilt by GM 700R4 tranny and stall (cant remember what size stall) less then 20k
Rebuilt 350 TPI heads (never ran), castings (087) w/3 angle valve job,
TPI lower intake with, 22lbs injectors, fuel presser regulator, rails, EGR, etc.
1994 LT1 intake with, MAP, EGR, throttle bracket, fittings, etc.
complete uncut 1987 l98 TPI wiring harness & stock ECM,
Stock disturber, 8mm wires, 1987 auto l98 camshaft,
Duel electric fans, light weight aluminum radiator,
L98 water pump, power streering pump, 105amp alternator, brackets, motor mounts, harmonic balancer, flywheel, drive shaft, hose's, belts, valve covers, oil pan, timing chain, timing cover, pair of K&N air filters etc, etc, etc....
"Selling everything together"
$3,000, OBO
Attached Thumbnails NEW! 350 & tranny, fresh heads brackets wiring harness, etc.!!  (HUGE LOT)-1.jpg
Attached Thumbnails NEW! 350 & tranny, fresh heads brackets wiring harness, etc.!!  (HUGE LOT)-2.jpg
Old Oct 16, 2005 | 03:59 PM
bump
Old Oct 16, 2005 | 04:00 PM
bump....
Old Oct 16, 2005 | 10:00 PM
Old Oct 17, 2005 | 05:40 PM
Old Oct 18, 2005 | 10:27 AM
$2,950 obo
Old Oct 18, 2005 | 10:30 PM
VERTIGO Z28's Avatar
Car: FBODYS
Engine: ALWAYS 8'S
Transmission: ALWAYS MENTAL
Axle/Gears: RUSTY AND BRAND NEW
OK I'll be the jackass. Why are you giving up on the engine project? If you finally scored a deal for an LS1 I will accept "I don't have time for it anymore". Good luck and BUMP!
Old Oct 19, 2005 | 06:23 PM
ZZ4 86 Z28's Avatar
Car: 1986 Z28 Camaro Gunmetal Gray with
Engine: GM Crate ZZZ HO 350, Edelbrock head
Transmission: Rebuilt 700r4 all TransGo and Beast
Axle/Gears: 10 bolt with 3.73 gears
how much would shipping on that tranny be?
Old Oct 31, 2005 | 07:04 PM
bigblockcamaro's Avatar
Car: 1983 Z28, 2001 Dodge 2500
Engine: 355 carb, V-10 8.0L
Transmission: TH-350, 47re
Axle/Gears: 10 bolt w/ 2.93's
Price on just the 350 short block and do you have a GM part number?
camaro11j
Sep 19, 2018 08:49 AM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
theshackle
Mar 5, 2017 06:37 PM
Reddeath210
Oct 6, 2015 08:20 AM
drathaar907
Aug 6, 2015 04:20 PM
