How do you identify a world class?
Old Dec 6, 2005 | 07:53 AM
ZZ4 86 Z28's Avatar
Car: 1986 Z28 Camaro Gunmetal Gray with
Engine: GM Crate ZZZ HO 350, Edelbrock head
Transmission: Rebuilt 700r4 all TransGo and Beast
Axle/Gears: 10 bolt with 3.73 gears
i know somebody selling an 87 bird 5 speed from a v8 and he doesnt even know what world class means. how can i/we figure this out. if i can easily search and figure it out let me know. i just gotta leave like right now for work but the auction ends soon. thanks a lot.
Old Dec 6, 2005 | 08:02 AM
3.8TransAM's Avatar
Engine: all 225+ RWHP
Transmission: all OD
Look at the front.
Is there a real bearing there or not?
I forget the exact ID but comparing a World to a reg T5 and the front bearings are different. Believe the input shaft isnt supported by a true roller type bearing on the non world class T5.
later
Jeremy
Old Dec 6, 2005 | 03:58 PM
ZZ4 86 Z28's Avatar
i doubt the guy would know that...plus he has it so i cant look at it. was wc an option in certain years or something?
Old Dec 7, 2005 | 02:54 AM
dr1's Avatar
dr1
Car: '89 Firebird Formula
88-up for f-bodys, and i think that was the transition year so maybe not all.. i got mine out of an 88 formula
Old Dec 7, 2005 | 06:17 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
You might consider a search. I recall seeing pics of the visual differences.
JamesC
Old Dec 7, 2005 | 08:18 AM
ZZ4 86 Z28's Avatar
again, i dont have the transmissions in front of me...im looking to buy one, most likely over the internet too.
Old Dec 7, 2005 | 08:56 AM
JamesC's Avatar
I "believe" there's a metal date tag indicating 88-92. Bolt, left side, Torx 50 (Non WC is a 21 mm 6-point). 26 spline for a V8. Seems that the 89-92 LB9 had the .73 5th gear--which is the same as the L69's--which would give a bit more grunt than the .63.
JamesC
Old Dec 7, 2005 | 09:10 AM
ZZ4 86 Z28's Avatar
so if its pre 88 then theres no way its a world class, right? thanks for the good info and ill let the sellers know.
Old Dec 7, 2005 | 11:18 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
World Class T-5 front
HTH
Attached Thumbnails How do you identify a world class?-1988_t5-front_view.jpg
Old Dec 7, 2005 | 01:45 PM
n8sz28's Avatar
Car: 85 camaro z28
Transmission: T56 6 speed
Axle/Gears: 3.27 borg warner 9 bolt
JamesC
can someone explain what the difference is between the 5th gear being a .63 rather than a .73. does it change anything else in the trans or is it just a gas mileage saver? what does a bit more grunt mean!!!
Old Dec 7, 2005 | 01:49 PM
dr1's Avatar
dr1
just a gas mileage thing, but .73 is nicer because 1 > .63 is kind of a steep jump
Old Dec 7, 2005 | 03:55 PM
ZZ4 86 Z28's Avatar
HTH?
PurelyPMD
May 5, 2016 04:57 PM
gt4373
Oct 8, 2015 10:37 AM
Damon
Sep 26, 2015 04:29 PM
scottmoyer
Sep 7, 2015 07:06 PM
jtwoods4
Sep 3, 2015 05:39 PM
