TBI on TPI Long Block
Old Jan 27, 2006 | 04:48 PM
Zion's Avatar
Car: 1991 RS
Engine: 90' TPI 305
Axle/Gears: posi disc 3.23's
im not sure what to put in this thread, but everyone seems to be telling me to make another.
this is basically a spawn from my other thread 'is the rs a bad platform'
I have a TPI longblock with TBI injection in my car right now. I guess that means my cam and heads are different then a normal L03. (081 heads)
Tips so far on how to make me faster are:
Edelbrock performer carb intake and adaptor
timing
prom tuning
open element
posi +3.73 gears
fuel pressure regulator
apparently this is a low 14's combination with my setup.
now a couple questions:
what is a fuel pressure regulator, how much does it cost and how do i install it.
my timing is at 6* as of last night. Car feels pretty smooth, but for the past few months, every time i start, the car will rev erratically (low-high, low-high, low-high) then stabilize just under 1000rpm. It seems to have started since i first advanced my timing months ago. Also, the car will sometimes idle really high (around 2000rpm), then slowly come down to below 1000.
whats this about being able to just remove my prom from factory? is this a TBI thing? and can i just purchase a EEprom so i can keep pulling it out and editing it, rather then wiping every time?
Original thread:
https://www.thirdgen.org/techbb2/sho...hreadid=340405
Old Jan 27, 2006 | 05:06 PM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
Here's a guy that deleted smog and put in a drop base air cleaner (open element)
https://www.thirdgen.org/techbb2/sho...hreadid=317645
The Adjustable Fuel Pressure Regulator is free you just do it yourself
https://www.thirdgen.org/newdesign/tech/tbi-afpr.shtml
With Pics
http://www.fl-thirdgen.org/tbiafpr.html
Here's a good writeup on modding the L03
http://www.goingfaster.com/spo/modthel03.html
As for exhaust I would suggest headers and a nice 3in, I prefer to put the muffler where the cat goes and dump the exhaust right before the rear axle but you might not be able to do this with smog regulations.
As far as price goes, fuel regulator is free, timing's already adjusted, drop base is cheap, putting the car on a diet is free, exhaust will be a tad expensive.
Double check everything for a vaccum leak, sounds like something may have developed a small leak when you were adjusting the timing.
Take her to the track and give us a base line on this sucker!!! Good luck man.
Old Jan 27, 2006 | 05:24 PM
Zion's Avatar
Car: 1991 RS
Engine: 90' TPI 305
track doesnt open till march around here... id like to have this all done by then
Old Jan 27, 2006 | 07:40 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
Timing - IAC
Your timing may be related to your IAC. Take it out, clean it, oil it lightly, set it properly and make sure the connectors are good. If the connectors are loose or something you will get an idle up to 2000 rpm. Inproper setting of the IAC will get the engine reving to warm up.
Old Jan 27, 2006 | 10:06 PM
Zion's Avatar
Car: 1991 RS
Engine: 90' TPI 305
what is the IAC?
it started doing something weird two days ago. It revs REALLY low on startup, almost till its going to shut off, then it will stabilize. And sometimes when im idling and go to move again, it will shut off.
After finding out that my car is running lean, it makes sense. Almost like there isnt enough gas going in sometimes.
Old Jan 28, 2006 | 04:13 PM
Zion's Avatar
Car: 1991 RS
Engine: 90' TPI 305
What is an IAC?
Also, am i right to assume the edelbrock performer intake is a direct bolt on for my applcation? I found one for cheap here, new. what are the est horse power gains?
Old Jan 28, 2006 | 04:34 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
idle air control valve
MustangBeater20
Oct 29, 2022 09:20 PM
Infested
May 22, 2018 11:56 PM
lakeffect2
Aug 23, 2015 08:44 AM
InfinityShade
Aug 22, 2015 08:00 PM
Sanjay
Aug 12, 2015 03:41 PM
