speedo calibration?
Old Feb 12, 2006 | 06:29 PM
crsr1's Avatar
speedo calibration?
First off, this is my first post and I would like to say that this is a great site! As in the subject, I have a speedo ? . I have a 91 RS and have searched and read all info about this on the site. I bought this car 2 years ago. It had the 305 tbi, a 700 R4, and ran 2.73 gears. After having the car for a little over 6 months, I had a new GM 350 Ramjet put in the car. I put about 10k miles on the motor and then put the car in the garage because the trans started slipping. That was 1 year ago. Over the past 2 months, I've had the trans rebuilt and 3.73 Richmonds installed. This leads to my question, how do I calibrate my speedo? I checked under the dash, and the car no longer has the factory ECM, just the harnesses. Am I overlooking something? I've looked for the DRAC unit and can't find it. I've got the car completely gutted and am in the process of pulling all the GFX off because the car is going to go into paint. Any help would be appreciated!
Old Feb 12, 2006 | 07:25 PM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
You'll need to swap out the speedo gears themselves
Here is the how to article along with some part numbers.
http://sethirdgen.org/vss.htm
Old Feb 12, 2006 | 07:43 PM
crsr1's Avatar
Thanks very much! I thought I would have to change those out, but someone told me that it would have to be done with a drac or a dip switch because it was an electric speedo. Again, thanks!
Old Feb 12, 2006 | 09:57 PM
midniteplowboyy's Avatar
Car: 91-Z28
Engine: SLOW ONE
The vss buffer box on your 91 tbi should be about a foot from the ecm. About half way from the ecm and the center of the dash, just remove the lower cover on the passenger side, its tucked up in there between the outer dash and heater ducting, has I think 7 wires going to it and one screw holding it in place.
I dont know if its tweekable or not, but thats where it is.
You might have to change gears like Jaysz28 said.
HTH
Old Feb 13, 2006 | 02:06 AM
Teeleton's Avatar
Car: 89 S10 Blazer
Engine: Built 4.3L V6 TBI
Transmission: Built 700R4
Axle/Gears: 7.65/Zexel/3.73
The box is called a DRAC, and yes, they are tweakable if you have some soldering skills.
http://www.614streets.com/drac.html
And a calculator I wrote to make the math easy.
http://www.philter.com/cgi-bin/drac.pl
Teeleton
Old Feb 13, 2006 | 03:31 AM
3.8TransAM's Avatar
Engine: all 225+ RWHP
Transmission: all OD
Ohhh
Priceless articles there.
Specially for the electronically challenged like myself
later
Jeremy
Old Feb 13, 2006 | 08:58 PM
Car: 91-Z28
Engine: SLOW ONE
Thanks Teeleton.
Great info, might come in handy on a future project.
Old Feb 16, 2006 | 05:35 PM
crsr1's Avatar
Ok, I still can't find the DRAC unit. I have located the ECM and a little yellow box marked "ac delco spark plugs". I can't find a little white box anywhere. Anymore ideas?
Old Feb 16, 2006 | 05:59 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Acually....you don't have a DRAC, it's a speed buffer and the location is right where it was discribed.
A DRAC uses a reluctor, we have a mag pulse generator.
So, changing the gears is the way to go.
Old Feb 16, 2006 | 06:15 PM
crsr1's Avatar
Thanks!
GTAman
Jul 3, 2024 07:29 PM
Elephantismo
Feb 13, 2019 12:51 AM
Nervous2
Oct 8, 2015 10:53 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
TrevinE
Sep 14, 2015 03:20 PM
