Modified 10 bolt backing plate for 9 bolt
Old Feb 18, 2006 | 12:07 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
i bought a 9 bolt disk for $75 last summer.off course it's my luck that it's a 2.77 gear and out of a 88 Z so it doesn't have the PBR calipers it has the crappy iron calipers.so i started to do some research as to what i needed to do to put the PBR calpiers on this rear end.through my almost endless searhing it was mentioned that the 10 bolt backing "may be" modified to be used on a 9 bolt rear end but i never found anything else about using the 10 bolt backing plates.i called the local chevy dealerships parts department.the 10 bolt backing plates were only $15 apeice so i ordered the backing plates thinking if they didn't work i was only out around $30.i picked them up yesterday and took them home and marked them up as to where they needed to be modified.i took a trip to work to use one of our horizontal milling machines.i brought them home and mocked them up and this what it looks like.
Attached Thumbnails Modified 10 bolt backing plate for 9 bolt-9-bolt-pix-003.jpg
Old Feb 18, 2006 | 12:27 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
This link, which is on the FAQ board, might have proved usedful:
https://www.thirdgen.org/techbb2/sho...hreadid=246768
JamesC
Old Feb 18, 2006 | 12:50 PM
91banditt2's Avatar
Engine: 5.7 HSR
that page is refrenced on a few dozen different threads and it was helpful but it doesn't go into any detail on modifing the 10 bolt backing plates for use on a 9 bolt.
Old Feb 18, 2006 | 02:16 PM
JamesC's Avatar
True, but it does provide a "possible" source for the 9-bolt backing plate. Ed Miller is perhaps another. Personally, I would have preferred the correct (unmodified) plate if possible.
JamesC
Old Feb 18, 2006 | 03:26 PM
ebmiller88's Avatar
I don't know if I'd trust those elongated holes to keep the bracket in place.. just MHO.
Ed
Old Feb 18, 2006 | 04:09 PM
91banditt2's Avatar
Engine: 5.7 HSR
i agree and i'm not going to trust them.my plan is to make a template of the hole pattern then weld the holes up and redrill the new hole pattern.
Old Feb 18, 2006 | 04:11 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Axle/Gears: 3.54 Dana 44
Probably could have just swapped them left for right and drilled 4 new holes in each.
Old Feb 19, 2006 | 10:46 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Thats what I did
Old Feb 20, 2006 | 01:13 PM
jwscab's Avatar
Engine: Many
Transmission: Quite a few
if you have a welder and some copper round stock, you could stick a copper 3/8" bar in the 'good' part of the hole, and weld up the rest.
then again, they were only 30 bucks. like others said, just swap the left for the right, and the holes will fall in new material, with no problems 'ovaling' holes.
Old Feb 20, 2006 | 02:19 PM
91banditt2's Avatar
Engine: 5.7 HSR
why would you want to use copper?
Old Feb 20, 2006 | 02:55 PM
92MaroRS's Avatar
Car: 1992 Camaro RS 25th Aniversarry Edition
Transmission: TH-700-R4
Axle/Gears: 10 bolt with 3.23's and SLP Posi.
Because copper wont weld with steel, and when done filling in, you have your hole for you bolt. no drilling needed.
Old Feb 26, 2006 | 07:05 PM
91banditt2's Avatar
Engine: 5.7 HSR
i did what Apeiron had suggested and flipped them around and drilled new holes.i still welded in the old holes so it wouldn't look like swiss cheese.
Attached Thumbnails Modified 10 bolt backing plate for 9 bolt-backing-plates-001.5.jpg
Old Feb 28, 2006 | 01:26 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
also, i can't tell in your picture, but the mounting holes for the PBR calipers need to face the REAR of the car or the will interfear with most of your suspension, it almost looks like the yolk is peeking out from behind there so i just wanted to make sure you knew that.
Old Feb 28, 2006 | 02:45 PM
91banditt2's Avatar
Engine: 5.7 HSR
they are facing rearward at about 4 o'clock
Old Mar 2, 2006 | 11:13 AM
luke j's Avatar
Car: '87 GTA hardtop, '86 IROC hardtop
Engine: 385 DFI, 350 carb
Transmission: T-56, T-5
Axle/Gears: ls1 torsen 10-bolt, 9-bolt disc
You can still get the 9-bolt plates from GM, I just ordered a set this morning. they only list them for '90 model year, at least that is what my friend at the chevy dealership said when he tried to look up an '89 model year.
thanks
Luke
Old Mar 2, 2006 | 11:25 AM
JamesC's Avatar
I've been under the impression that GM had long ago discontinued the 9-bolt backing plates. Let us know if you actually receive them.
JamesC
Old Mar 2, 2006 | 11:59 AM
Apeiron's Avatar
Engine: 383 Carb
Sounds like you're getting 10 bolt backing plates. There was no 9 bolt in 1990.
Old Mar 2, 2006 | 12:04 PM
luke j's Avatar
That is what I thought also, but he said they where for a 7.75 ring gear rear end. I guess I will have to wait and see what I get. I may have spoken too soon I guess.
thanks
Luke
Apeiron's Avatar
Engine: 383 Carb
Have you got part numbers?
Old Mar 2, 2006 | 12:08 PM
JamesC's Avatar
The 10-bolt part numbers are as follows: 10136853 and 10136854.
JamesC
Old Mar 2, 2006 | 12:17 PM
luke j's Avatar
I just called him this morning and had him order them, I should have them tommorrow or monday morn. I will post the part numbers when I can. I really hope they are correct, but I now have my doubts.
thaks
Luke
Old Mar 10, 2006 | 01:48 PM
luke j's Avatar
yup they are 10 bolt brackets, same part numbers as above. The computer listed them for 7.75 ring gear diffs. I have brackets now anyway. I wil just swap side to side and redrill. are there any bigger brakes that will fit with these brackets?
thanks
Luke "spoke too soon" Johnson
Frozer!!!
Jan 19, 2024 04:55 PM
Eric-86sc
Apr 3, 2016 03:52 PM
sailtexas186548
Jan 19, 2016 12:21 PM
sailtexas186548
Brakes
Aug 13, 2015 11:47 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
