New rear end girdle
Old Mar 1, 2006 | 03:30 PM
mantiz85ws6's Avatar
Car: 85 Trans Am
Engine: 350 T.P.I.
Transmission: WC T-5
New rear end girdle
Just wanted to post somne pictures of the new girdle from T/A performance.
Old Mar 1, 2006 | 03:34 PM
Car: 85 Trans Am
Engine: 350 T.P.I.
1 more
Old Mar 1, 2006 | 07:10 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Yep, got one on my car. Very nice and worth the money.
Old Mar 1, 2006 | 09:42 PM
brutalform's Avatar
What does this have to do with TPI?
Old Mar 1, 2006 | 09:57 PM
Car: 85 Trans Am
Engine: 350 T.P.I.
I don't know maybe I thought some people may find it interesting to see some pictures of the 9 bolt cover. Does this bother you?
Old Mar 1, 2006 | 10:03 PM
brutalform's Avatar
No it does not bother me...I simply asked a question.
Old Mar 3, 2006 | 06:27 AM
RPOL98's Avatar
Car: 90 IROC
Engine: 5.7L TPI
Axle/Gears: 9-bolt BW
I myself was wondering what this looked like, installed on a car, and whether it was already in production and being shipped. now I know.
I think the 9-bolt australian rear-end is predominantly a 5.7L TPI thing, therefore it does indeed have relevance.
Old Mar 3, 2006 | 07:36 AM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
When you bought the cover did the bolts come with it?
Did you pay extra for the bolts?
Can you just get them at the hardware store?
I am thinking of getting a rear end girdle, too.
Old Mar 3, 2006 | 11:56 AM
Car: 85 Trans Am
Engine: 350 T.P.I.
I don't think the bolts came with it you have to use your existing bolts, but I ordered the optional stud kit for an extra $20.
Old Mar 3, 2006 | 01:00 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Sorry, I didn't clarify.
It is the stud bolts I was talking about.
Do you think that you could have went to the hardware store and got the same bolts for cheaper?
Old Mar 3, 2006 | 02:18 PM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
Transmission: modified 700R4
Have the 10 bolt on my IROC
Old Mar 4, 2006 | 10:01 AM
Car: 85 Trans Am
Engine: 350 T.P.I.
I think you could probably find the studs cheaper at a hardware store.
Old Mar 4, 2006 | 10:28 AM
Car: 1989 GTA
Engine: 369 TPI
The kit comes with studs and allen bolts for the cover. Well worth it in my opinion. Also it comes with a new gasket.
Old Mar 4, 2006 | 10:38 AM
3.8TransAM's Avatar
Engine: all 225+ RWHP
Transmission: all OD
This post has nothing to do with TPI.
Should be in Transmissions and Drivetrain.
I'm sure it will get moved.
later
Jeremy
Old Mar 4, 2006 | 12:02 PM
Car: 85 Trans Am
Engine: 350 T.P.I.
Could the moderator please move this thread to tranny and drivetrain I can't take much more of the whining
Old Mar 4, 2006 | 12:23 PM
brutalform's Avatar
WHINING, you should read the little title, on top of each board, before you post. There is a reason they are there.
Old Mar 4, 2006 | 11:54 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
How much was it. I was unaware T/A actually produced a 9-bolt cover. This is sweet
Old Mar 5, 2006 | 03:44 AM
RPOL98's Avatar
Car: 90 IROC
Engine: 5.7L TPI
I don't think you could get the studs for the differential bearing caps from a hardware store. I'm sure they're better than Gr.8, and then try to get the right length.
unless you happen to have access to some aerospace or MILSPEC stuff.
Old Mar 5, 2006 | 08:09 AM
Car: 85 Trans Am
Engine: 350 T.P.I.
info on 9 bolt cover www.taperformance.com
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
