replacing an 85 mph speedo with a 115
Old Mar 11, 2006 | 01:34 PM
hotrod87camaro's Avatar
Car: 1987 Camaro Sport Coupe LT
Engine: 357
Transmission: turbo 350
Axle/Gears: 10 bolt posi, 3.73 gears
would i have to change the speedometer gear in the transmission or anything else to make it work?
Old Mar 11, 2006 | 06:18 PM
jimp2001's Avatar
Car: Red on Red 89 RS
Engine: LO3 305 TBI
Transmission: TH-700R4
Axle/Gears: 10-bolt / 2.73
should be plug-n-play
Old Mar 11, 2006 | 06:26 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Yep. Check the following link for some helpful info:
https://www.thirdgen.org/techbb2/sho...hreadid=249244
JamesC
Old Mar 11, 2006 | 06:34 PM
White93z34's Avatar
Car: 1987 Camaro IROC-Z
Engine: LB9
yeah, its plug n play, i did that myself last summer. all i did was transfer the mileage over.
Old Mar 11, 2006 | 06:49 PM
Engine: 357
ok thanks, should i use the little yellow box that came with the 115 speedo or does it matter? i got just the speedometer and the yellow box and just wanted to make sure it was gonna work right and be somewhat close to accurate. thanks for the help
Old Mar 11, 2006 | 10:39 PM
DustyJL's Avatar
Car: 91 Camaro RS
Engine: 3.1L V6
Axle/Gears: Stock 3.23 open diff
Is a 110 to a 145 plug and play also??
Old Mar 12, 2006 | 01:08 AM
MikeDirntRulez's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI (L03)
Transmission: 700R4 (MD8)
Axle/Gears: 2.73 Open (GU2)
yes
Old Mar 12, 2006 | 05:35 AM
JamesC's Avatar
Yes, plug and play; however, remember that the mechanical speedo ended in 89, IIRC, so you'll have an electric.
JamesC
Old Mar 13, 2006 | 03:09 PM
Engine: 357
so today i was going to put the 115 in but after seein that other thread, i decided to try to fix the trip odometer. well, in an attempt to take it apart i broke the needle, actually the shaft that goes through the needle is what broke. i had a spare 85 mph speedometer so i decided to try to take it apart to fix the 115 one, so far i'm not having much luck. if they are plug and play, whats different inside them? what do i need to change? i had it together once and it seemed to be pretty accurate but then the needle spun all the way around and stuck on like 70 and it started making wierd noises. i just put the old one back in it for now and it still works, but i'm still trying to get this 115 one back together, i really wish i hadn't messed with it, i've never had a working trip odometer before and i would probably never even use it then i realized i probably could have just took it apart from the back anyways.
Old Mar 13, 2006 | 03:39 PM
Engine: 357
after looking at that thread again i now see that i didn't even have to take it apart at all
Jorlain
Aug 24, 2022 05:11 PM
ChevyZ71
Aug 13, 2015 07:30 AM
Irocohio
Aug 12, 2015 08:03 AM
beachrodder
Aug 7, 2015 04:27 PM
