tpi nitrous kits
Old Nov 3, 2001 | 07:14 PM
brian89transam's Avatar
tpi nitrous kits
My engine is an '87 tpi 350. It has cold air with a K&N and Random Tech exaust. I will make more mods in the future: intake, runners, AFPR, etc. I want a kit with an option to make less than 100hp(like 50 or 80). Would 80hp be well within my stock engines limits? NOS doesn't make one under 100 do they? Who does? Is there anything else that I should really consider getting when buying an Nitrous kit for a stock motor? Thanks for the advice guys.
Old Nov 3, 2001 | 07:38 PM
cobrakiller1989's Avatar
I think you can get a kit like the 5151 and just put smaller jets in it. Im not 100% sure tho, because im still new to Nitrous and my 5151 wont be on for atleast another month or so
*1989 RS
*Red, Daytona Turbo fiberglass hood, chrome 16x8 IROC wheels
*355 CID
*TPI ported plenum, SLP siamesed runners, Edelbrock high flow intake
*SLP 1 and 3/4 headers with 3 inch catback
*Richmond 3.73, Auburn Posi
*Modded 700-R4, 2800 stall converter
*eibach pro kit and hotchkis sturt tower brace
Old Nov 3, 2001 | 08:43 PM
IROCKZ4me's Avatar
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
Nitrous Express makes a single stage kit adjustable from 35-150 horsepower. You can get a second stage later to add on if you wish.
http://www.nitrousexpress.com/stage1_rs.htm
Tracy /AKA IROCKZ4me
'86 IROC-Z Camaro
"Cogito ergo zoom"
  • 355 cid
  • AFR heads
  • Arizona Speed & Marine hydraulic roller cam w/ AFR hydra-rev kit
  • modified SLP runners
  • TRW forged pistons/ceramic coated
  • fully balanced
  • Edelbrock headers/ceramic coated
  • SLP cat-back
  • Paxton supercharger
  • Nitrous Express nitrous oxide
EFI Performance Club on Yahoo
Old Nov 4, 2001 | 02:06 AM
Kandied91z's Avatar
the nos kit is fine, just order smaller jets to whatever size you want.
Old Nov 4, 2001 | 01:13 PM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
the nos kit is junk. find another brand
1991 Firebird
350 L98 (was a 305 TBI),T-5,Edelbrock TES and cat back,Accel manifold
NOS,subframes,jegster torque arm,MSD Digital 6
AFPR,Lakewood lcas
Hurst linelock,SLP cam (206 212 .480 .486),relocated battery,cold air,Hypertech chip,centerforce df,clutch
poly bushings and mounts
AFR 190s
Harland sharp 1.5 rockers
autopower rollbar
12.33 @ 114.83 juiced uncorrected
13.510 @ 102 non juiced uncorrected
Old Nov 4, 2001 | 04:33 PM
why is the NOS kit junk?
Old Nov 4, 2001 | 05:41 PM
CLEE's Avatar
The best kit to buy will spray both fuel and Nitrous. I don't care what company you buy from. They make the dry system that use the fuel regulator to control fuel. The wet system works the best and is safe beacuse you know the fuel is being added when the system is activated. You will want to go with more than 50hp too. A 50-75hp setup does not feel like much and will make you regret spending your hard earned money. This is one of the reason that NOS sells 100HP kit for the V8. 100hp will be fine on a stock motor and you can feel the kick. good luck
88 GTA TransAm 88 RX7 chevy powered
Old Nov 5, 2001 | 01:42 AM
Omar's Avatar
I wouldnt go as far as saying that NOS stuff is junk, but I do agree with Gofaster to invest in a better company if you are not already set on NOS. I personally run a NOS system, only because in 1994, NX, Nitrous Works, and the internet were not things I was aware of at that time. I have had ZERO problems with my wet kit. Their staff and customer service is horrible if you need advice or help.
1989 IROC-Z 5.7L
NOS 5151 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
Old Nov 5, 2001 | 10:53 PM
MouseCamaro305's Avatar
I agree with omar, the customer service is really bad, and I've heard nothing but people having problems with the customer service. As for the NOS 5151, I used it on my 305 IROC and I encountered no problems whatsoever, the instructions were great, and it was extremely easy to assemble, only took a few hours my first time. I've never used any other brand than NOS, so I don't know much about edelbrock, NXpress, Nitrous Works, or any of those.
I ran a 150 HP shot on a stock internal 305, and sprayed a whole bunch of bottles through it, it knocked off almost a full 2 seconds, and made my otherwise basically stock IROC run a 13.2 instead of a 15.1. I was really impressed with it, good luck.
Old Nov 5, 2001 | 11:27 PM
thanks a lot guys, i always know i'll get good replies when i'm at the thirdgen.com message board
Old Nov 6, 2001 | 12:10 AM
87CamaroZ28's Avatar
I have a Nitrous Works Kit #13070 plus purge. It is a LT-1 kit, but will work on a L98 with a 48mm throttle body. I had it on my 91 Formula. E-mail me if you're interested at bjh9579@tntech.edu or MXRacer3@aol.com
87 Camaro Z28
LB9 305 TPI, Accel cap, rotor, and 8mm wires, K&N filters
1/8 mile: 9.8@69mph
91 Formula ***Sold***
L98 350TPI, Accel 8.8mm wires, Siamese Runners, Edelbrock Headers, Edelbrock 3" Cat-Back, Airfoil, K&N Cone Air Filter, AFPR, Shift-kit, Mallory Promaster Coil, Nitrous Works Wet Kit 75hp
1/8 mile: 7.9@86mph
95 Camaro Z-28 M6
K&N filter
Removed CAT
Removed MAF screen
Almost as close to stock as it gets.
1/8th mile: 9.1sec
Old Nov 7, 2001 | 02:53 AM
Kandied91z's Avatar
i too would like to know why the NOS kit is bad?? at least give the guy an idea before you put thoughts into his head.
Old Nov 7, 2001 | 12:48 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Axle/Gears: 10 bolt 3.23
So a 100 hp would be safe on all stock internal motor with the proper retard timing?
Old Nov 7, 2001 | 03:55 PM
beleive it or not, but l was able to run 150 HP shot on my stock internals 305 at 6 degrees of advance, I ran several bottles through it and at the time it had about 72,000 on the clock.
stalkier
Dec 6, 2015 11:25 PM
toronto formula
Nov 10, 2015 06:17 AM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
