New 6E .ecu file for Winbin....
Old Jun 23, 2001 | 08:43 AM
ZaphodB's Avatar
Car: Camaro IROC-Z '89
Engine: 350 TPI /w Procharger P1SC
Transmission: TH700R4 with Transgo shiftkit
Axle/Gears: 2.77 Borg Warner
I had nothing better to do today, so I decided to sit down and analyze a few eprom images that I have gathered over time, and the result of this is a new .ecu file for Winbin that I will share with the rest of you.... I think you'll find a few things that both you and I missed in the past in there!
I've added all the parameters for highway fuel mode & highway spark mode....
http://www.area51.org.il/~zaphodb/gmecm/6Ev005.zip
ZaphodB a.k.a Carl Andersson - zaphodb@faxancruisers.org
'89 Camaro IROC-Z 5.7L TPI - Mods under construction :-)
Custom ARAP Chip Under Development/180 t-stat, Edelbrock TES Headers,
SLP Airfoil, K&N Filters, Accel 8mm wires, Relocated MAT, AFPR @ 45 PSI
[This message has been edited by ZaphodB (edited June 23, 2001).]
[This message has been edited by ZaphodB (edited June 24, 2001).]
Old Jun 23, 2001 | 11:23 AM
ZaphodB's Avatar
Everyone else sleeping??
I want some feedback on this one?!?
Old Jun 23, 2001 | 11:44 AM
Aaron's 87's Avatar
I'm going to try it out. If it works, let me be the first to say (in my best Jazzy Jeff voice) I LOVE YOU.
Old Jun 23, 2001 | 01:36 PM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
woah, just as i was thinking of wandering blindedly into makeing my own ecu file, someone else does it for me.. Thanks alot man....you just saved me a headache or two...now to see how it works..
89 IROC-Z 350 TPI
-Flowmaster Catback
-Performance Resource Chip
-700R4 (Rebuilt) Too much done to actually list
-K&N Airfilters
-Ported Plenum
-2.77 Gears (not much to brag about but eh, its there)
-MSD 8.5 mm plug wires
-Gutted cat
-!AIR
-Gutted Air Boxes
Old Jun 23, 2001 | 03:38 PM
Craig Moates's Avatar
Car: 87 T/A
Good work! You mind if I toss this update onto my site for availability? I was hoping someone would pick up the ball on the ECU work, thanks!
-Craig
Old Jun 23, 2001 | 10:05 PM
ZaphodB's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Craig Moates:
-Craig
</font>
Of cource I don't mind, things like this should be shared.... I'll see if I can figure out the maths for the rev-limiters as well toda, then we're nearly 100% complete...
Old Jun 24, 2001 | 12:25 AM
Car: 87 T/A
When we were putting together the 6Ev004 version, the rev limiters were working OK, but thee was a problem with WinBin and the 2-byte values. Has this been fixed? It used to be that anytime you had a 1/x calculation where x=16-bit 2-byte value, an error would occur if the value of x was out of a certain bound.
Old Jun 24, 2001 | 12:30 AM
ZaphodB's Avatar
When we were putting together the 6Ev004 version, the rev limiters were working OK, but thee was a problem with WinBin and the 2-byte values. Has this been fixed? It used to be that anytime you had a 1/x calculation where x=16-bit 2-byte value, an error would occur if the value of x was out of a certain bound.</font>
Ah, so thats why.... It's a bug in Winbin.... Kind of explains why nothing made sense even when I could do the calcs on hand....
Old Jun 26, 2001 | 07:39 AM
Aaron's 87's Avatar
Are the enable temps C or F?
Old Jun 26, 2001 | 07:45 AM
ZaphodB's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Aaron's 87:
Are the enable temps C or F?</font>
They are in F.....
Old Jun 26, 2001 | 08:24 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
ZaphodB, you've got mail.
Greg Westphal
'87 IROC 355TPI/A4
Old Jun 26, 2001 | 01:14 PM
ZaphodB's Avatar
<font face="Verdana, Arial" size="2">Originally posted by GregWestphal:
</font>
Thanks Greg, I will update the ecu file and post the new one!
Old Jun 27, 2001 | 04:14 AM
ZaphodB's Avatar
</font>
I've incorporated your additions/corrections into a new version of the ecu file now. Have alook at it and see if there is anything wrong, consider it beta for now.
http://www.area51.org.il/~zaphodb/gmecm/6Ev006-BETA.zip
InfernalVortex
Apr 20, 2021 11:31 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
Jonas Earl
Sep 27, 2015 07:39 AM
MitcherNeaf
DIY PROM
Sep 24, 2015 09:23 PM
80smetalfan
Sep 22, 2015 02:55 PM
