Siamesed stock runners inside...
Old Sep 30, 2001 | 07:30 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
http://rain.prohosting.com/imwhom/junk/inj/
I was pulling the plenum to swap injectors anyway, so i went ahead and siamesed the plenum and through the flange on the stock runners, so maybe an inch worth of siamesing vs. stock, plus i radiused everything up better than i had it already. (Yes i was really bored)
It still runs, feels really good, but it could be the cold air too.
Ed Maher - Moderator @ The TPI & Carb Boards
92 Z28 Convertible - Quasar blue / Tan top
305 TPI A4 2.73 - 14.8 @ 93.1
Stock except ported plenum and dual cats
-=ICON Motorsports=-
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
Old Sep 30, 2001 | 10:20 PM
u r sofa king we tah did's Avatar
haha, i thought i was the only one who used the dishwasher to clean off parts!
Old Sep 30, 2001 | 10:26 PM
Mark_ZZ3's Avatar
Car: 1989 Camaro-1LE
Engine: TPI(s)
Transmission: 5 speed (MM5, MK6)
Axle/Gears: 3.45, 3.73
Interesting ...
I can't imagine explaining to my wife when she found car parts in the dishwasher.
I had often thought about putting an old dishwasher in the garage!
I plan on getting some SLP runners. For now, I could do the plenum port like you did, and then be ready for the runners.
Mark.
PS. You DO have too much time!
Old Oct 1, 2001 | 07:47 AM
ZPI28's Avatar
Engine: 5.7L L98 TPI
Transmission: Automatic
I done the same to my runners and plenum. It knocked off a tenth on my ET and added about 2 mph in the 1.8th.
91 Z28 305 TPI
single 3"flowmaster
ported plenum,siemesed runners,
gutted airbox,
160 robertshaw thermo
273 gears,auto
9.47 1/8th mile
on goodyear eagles
Old Oct 1, 2001 | 10:19 AM
JucinGTA's Avatar
www.geocities.com/softtailduece01
Old Sep 15, 2003 | 12:01 AM
89Formula350WS6's Avatar
I have got to break down and do this stuff.
Old Sep 15, 2003 | 12:50 AM
FlamedROC's Avatar
Car: 1989 IROC-Z
If someone wants I will siamese port there Plenum for them! Best kick in the pants mod to do and keep the car still stock...Just PM me... I did my runners tha same way!! I didnt know others were doin it! I really want to Have true siamesed runners
Old Sep 15, 2003 | 02:29 AM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
wow back from the grave. the plenum mod is a good one.
Old Sep 16, 2003 | 10:12 PM
Yeah, but is the slight siamesing of the stock runners worth doing? (or) Should I just smooth out the step/mismatch in the runners?
Old Sep 17, 2003 | 12:19 AM
SLP IROC-Z's Avatar
Car: 1999 Z28
wont hurt to siamese em like ed did. every little bit counts.
Old Sep 17, 2003 | 01:53 AM
FlamedROC's Avatar
Car: 1989 IROC-Z
Just Siamese it!! seriously its less work then trying to individually grind down each little Box between each runner port. Plus make sure you grind down those boxes up front by the TB ports also. Then once u have siamese portsed the plpenum radius the runners also! IMO I dont think you would notice all that much if u just cleared those boxes out opposed to siamesing. I know that I noticed alot of gain in throttle responce and top end(not much but like said "every little bit helps"
Jason
tazs2000
Jul 15, 2017 08:44 AM
stalkier
Dec 6, 2015 11:25 PM
Genopsyde
Oct 7, 2015 08:35 PM
Hawkeye1980
Aug 31, 2015 07:09 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
