Just installed my SLP Dual Cold Air Setup
Old Nov 22, 2001 | 12:49 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Just finished installing it, looks awesome,
anyone have any experience with his setup?
Here is the left aribox,
and the right airbox
Old Nov 22, 2001 | 01:28 AM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
Dude, that rocks! Looks bad a$$! I assume ya moved the battery to the trunk?
-Rob
92' White Trans Am Convertible, 305 TPI, 5 spd. 2:73's, Edelbrock TES, Accell 8.8's, Hypertech Stage II, TPIS Air Foil, Ported Plenum, K&N TB Cone Filter, AFPR, & A Little Bit Of Attitude!
-Best ET: 14.944 @ 93.11
88 Gunmetal GTA Hardtop... Project In The Works!
"GUYS, WE NEED TO FIND A MUSTANG TO RACE... THERES ONE! HOLY SH*T SHES HOT! SHES NOT GONNA GO... NAH... HOLY SH*T SHES GOIN!"
Old Nov 22, 2001 | 04:04 AM
Zepher's Avatar
Thanks,
It will be in the trunk, the battery is on the workbench for now. I need to run a cable to the back and either get a box for the battery or build a cage for it.
I have an Optima Red Top, so I can mount it any way I'd like.
WS6 Trans Am.
View My Ride @ thirdgen.org
Old Nov 22, 2001 | 09:40 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Hey,
IHRA rules allow a marine box for the battery. $8.00 at wallmart. Spare tire
cubby looks like a good place to me. Make sure you run high gauge wire tho. Fire = bad.
Btw, that setup loops pissah! I dunno if i'd spend the $299.00 for it just yet tho.
I take it your care is speed density?
-- Joe
1989 Formula 350 4-bolt mains, Forged .030 TRW pistons, SLP 51010 Roller Cam, Comp-cams roller lifters,
Summit 1.5 roller rockers, World Products Sportsman II 2.02/1.60 heads, Edelbrock TPI Intake,
Cloyes Double Roller, timing chain, Mellings oil pump: 13.5 @ 100.23 MPH
Since close of track : Ported SLP runners, Ported Plenum, AFPR, Autometer 100lbs gauge, A/F ratio gauge.
http://www.joesperformance.com
Old Nov 22, 2001 | 02:07 PM
Zepher's Avatar
How high a gauge wire, I was thinking 4 gauge from the battery to the front of the car.
I have an Optima Red Top battery and yes, I have a Speed Density system.
Oh, and I paid $185 shipped, since it was used for about 150 miles.
WS6 Trans Am.
[This message has been edited by Zepher (edited November 22, 2001).]
Old Nov 22, 2001 | 02:55 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Thats not a bad deal then.. Where did you get
it? was it a SLP demo or ?
4 gauge prolly be ok. Depends on what you do
battery wise.
I'm gonna run two 700CCA batteries in my trunk or a 1000 CCA top post, so I'm gonna go with a higher gauge wire. I find with my headers, once my starter heats up a single 550 or 600 won't cut it.
-- Joe
Old Nov 22, 2001 | 04:17 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Zepher, I would make that at least 2 gauge from the battery to the starter. I myself am running 2/0 to turn my high compression under any weather conditions. It needs more juice when it gets cold. I'm in the south now so the cold doesn't matter anymore.
Here's a list of wire sizes from smallest to biggest.
8 gauge
6 gauge
4 gauge
2 gauge
1 gauge
0 gauge
1/0 gauge
2/0 gauge
3/0 gauge
4/0 gauge
etc....
86 Camaro Sport
LT1 Induction
383 Speed-O-Motive Crate Engine, Raptor 700R4 Tranmission, Trick Flow Twisted Wedge G2's, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Hooker Cat-back, Serpentine Belt Setup, Dual IROC Fans, Jamex springs, 16" IROC Rims, 36mm/24mm Sway Bars, Global West Steering Brace. Hotchkis Rear LCA's,Panhard Bar and SFC's.
My Camaro Project
Moderator at SE ThirdGen
Engine: 4.0L
Oh, BTW nice air intake!
Old Nov 22, 2001 | 04:20 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
I have the same set-up. Bought it used off this board for like $150 from a guy in Hawaii. Now the fun begins routing that battery cable
I picked up a moroso battery box used from TBryne motor sports for $50. Don't forget that battery switch for the track. I mounted mine to the left in my convt trunk. I wanted to keep the spare, it's the wifes car.
p.s. It was suggested to stay away from standard battery cable and go to a welding supply shop. They have some really HEAVY gage wire for welders that is supposed to work excellent. I think it's like 0 gage or 00 gage.
Rob P
89RSconvtZZ4TPI Edelbrock Intake
SLP Dual Cold Air Intake 1 5/8" Headers Semi-Siamesed Runners, IROC
suspension, alum shaft. Numerous mods.
92Z28convt5spd (stock)
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
[This message has been edited by Rob P (edited November 22, 2001).]
Old Nov 22, 2001 | 04:32 PM
Engine: 4.0L
[This message has been edited by John Millican (edited November 22, 2001).]
Old Nov 22, 2001 | 05:12 PM
Engine: 4.0L
Here's mine:
86 Camaro Sport
LT1 Induction
My Camaro Project
Old Nov 22, 2001 | 06:10 PM
Momar's Avatar
Hey John, where did you get that Y piece for your air intake. I still think it looks cool with that lt1 intake on there too.
Ben
Old Nov 22, 2001 | 08:16 PM
Engine: 4.0L
<font face="Verdana, Arial" size="2">Originally posted by Momar:
Ben
</font>
I made it.
3" PVC long elbows cut and welded(epoxy) together and sanded smooth/painted.
86 Camaro Sport
LT1 Induction
My Camaro Project
Old Nov 22, 2001 | 08:52 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
Ive always liked that SLP setup. The price has always turned me off. If I could run across a good deal on a used one. Did you guys notice a power increase over the stock airbox? Do the filters come with it? I would like to see a before and after dyno run to see the difference.
I wonder how restrictive the stock box is? It chokes down alot after the radiator.
John... that is a really good idea with the 3" pipe.
90 IROC
SuperRamed 406
Trickflow 23* heads
Old Nov 23, 2001 | 02:05 AM
Hg's Avatar
Hg
Car: '87 Z
Engine: 355 in the works
Hey, looks great. How hard is it to move the battery, is it a big job? What would be involved in doing so, and do they make any kinds of kits you can buy to do it? I really wanted the dual inlet SLP CAI setup you've got but I don't wanna jump into anything before I know what I'm getting into.
Old Nov 23, 2001 | 02:55 AM
Zepher's Avatar
Hey John, I was going to attempt to make a dual setup like yours, but I am not too great at fabrication.
I bought the SLP intake used from someone from one of the message boards, can't remember which one.
How many feet and how much money am I looking at for the 2/0 gauge wire?
WS6 Trans Am.
Old Nov 23, 2001 | 05:57 AM
Engine: 4.0L
<font face="Verdana, Arial" size="2">Originally posted by Zepher:
Hey John, I was going to attempt to make a dual setup like yours, but I am not too great at fabrication.</font>
Thanks, I suppose I can make more. Sell them?
How many feet and how much money am I looking at for the 2/0 gauge wire?</font>
I would look at 20 feet. Also like I said before 2 gauge is the minumum, 2/0 is much bigger but would work very well. Check out this site for wiring and stuff. I got my battery cables there. http://www.delcity.net/wirecable.html
[/B][/QUOTE]
86 Camaro Sport
LT1 Induction
My Camaro Project
Old Nov 23, 2001 | 09:45 AM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
The SLP Dual Cold Air is a nice setup. However, for the 'big guys' out there keep one thing in mind ....
A 58mm TB has more area at the inlet than a 3" tube. The connection of the SLP D-CAI where the bellows connects to the dual air housing is 3". A 58mm TB should be able to outflow that section of the airbox.
Area of dual 58mm TB = 8.19 in^2
Area of dual 52mm TB = 6.58 in^2
Area of a 3 inch tube = 7.07 in^2
Area of a 3.25" tube = 8.30 in^2
Just some info to stir the senses
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.244 @ 112.51mph (1.778 60' / 7.819@88.32mph in the 1/8)
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels.
Gunning for NA 11's with bigger cam, bigger stall, and bigger exhaust.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
Old Nov 24, 2001 | 03:09 AM
poncho9789's Avatar
Can a setup like these be used with a maf type system?
I have a couple of people that I talk to that have descused it with me and we haven't tried it yet.
Old Nov 24, 2001 | 09:22 AM
88IROC_CVTFAN's Avatar
Outstanding! Although the ability to move air through the system will be restricted by the smallest element I can't help thinking about the "ram" effects at speed.
88 IROCZ28
ZZ4, Big Mouth, Lg. runners and BBK 58mm TB. 700R4 w/ corvette shift servos, 3.23 Borg Warner & posi.
B&M 2400 Hole Shot and MegaShifter. Random Tech Hi Flow Cat and 3" Catback system, Edlebrock headers - jet coated.
Old Apr 21, 2002 | 12:32 AM
maverick544's Avatar
I'm assuming you can't use that setup on a MAF included.
Old Apr 21, 2002 | 01:11 AM
Jza's Avatar
Jza
Nope. BTW I don't think he's even using the setup at all anymore due to going to an LT1 (w/ MAF).
Old Apr 21, 2002 | 01:16 AM
Jza's Avatar
Jza
from Zepher's classified
am doing an engine swap from my 305 TPI to a 350 LT1 and cannot use this Cold Air setup due to the MAF on the LT1.
I am looking to get $225 shipped to the lower 48 states.
What'd you do, drive it backwards for a few thousand miles?
Old May 15, 2002 | 09:48 PM
RC's Avatar
RC
nice set up !
but another question raised up..
where's the charcoal canister?!
usually it's next to the air cleaner housing on the firebirds
on the RF fender well>?!
Vintageracer
Jan 10, 2020 05:33 PM
onefreakz
May 14, 2018 12:15 PM
kyle5647
Aug 15, 2015 11:56 PM
drathaar907
Aug 6, 2015 04:20 PM
