Are ported cast iron heads better than corvette aluminium heads?
Old May 13, 2002 | 08:18 AM
max_est's Avatar
Car: '89 RS
Engine: LS3
Transmission: TR6060
Axle/Gears: 3.42, 10-bolt
I've checked heads cast # (14101081) on my '88 350TPI engine and i've found, that they are 305 heads (small valves 1.8x/1.5) Have anybody same heads on 350 engine? Can I port them, so they flow better? Or must I better look for the Vette aluminium heads? I found also some chart for that cast iron heads:
Page:
http://www.afn.org/~afn14222/flow_14101081
Can somebody give me advice, should I port them? I dont have other mods at the time, but I plan port plenum, runners, intake ja use LT1 cam or smth like that. I have short headers & K&N filter. Tnx
Old May 13, 2002 | 04:36 PM
tpi_roc's Avatar
The vette heads offer some advantages that dont exist with the cast heads.
1.) weight savings
2.) smaller combustion chamber (higher compression)((not always good))
3.) D-port exhaust
and some other small things
You'll be better with vette aluminums if you can afford them
Old May 14, 2002 | 07:49 PM
ir0cz's Avatar
Car: '89 RS
Engine: 9C1 w/ TPI
Transmission: rebuilt 700R4
1.) weight savings
3.) D-port exhaust
If he's got 305 heads...they should have a 58cc combustion chamber...same as the vette heads.
But other than that, the vette heads do offer some advantages. Even if you can't afford the vette heads, I'd get some kind of used 350 heads and port them (preferably iron L98 heads)...you can find them cheap, and they will flow a hell of a lot better than the 305 heads.
Old May 14, 2002 | 11:55 PM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
You have to remember that Al disipates heat a lot quicker than iron. This effectively lowers the compression ratio (CR), if you want to regain the "lost" CR you can deck the heads.
Old May 15, 2002 | 10:45 AM
max_est's Avatar
Car: '89 RS
Engine: LS3
Tnx. What is cast # of 350 L98 heads?
Old May 15, 2002 | 10:47 AM
tpi_roc's Avatar
Aluminum or cast?
Old May 15, 2002 | 10:50 AM
max_est's Avatar
Car: '89 RS
Engine: LS3
Check quote. ir0cz mention iron heads. But cast # for vette aluminium heads is interesting too.
Old May 15, 2002 | 01:35 PM
914Mula's Avatar
Car: 91' Formula
Engine: 383CID
Transmission: t-56
Axle/Gears: 4.10
I have some l98 heads for sale if you are interested.
Old May 15, 2002 | 02:29 PM
rhuarc30's Avatar
Casting # for L98 Iron heads 14101083, though you'll also see 14096217 occasionally. They're almost exactly the same head, the and both were also used on the 285hp 350 crate motor that gm offered back then.
Old May 15, 2002 | 10:07 PM
914Mula's Avatar
Car: 91' Formula
Engine: 383CID
Transmission: t-56
Axle/Gears: 4.10
I believe the aluminum heads are casting # 10088113.
Old May 16, 2002 | 12:45 AM
Hodge's Avatar
Car: 1987 IROC-Z28
Engine: 383 Vortec - carb
Transmission: T56 - 6speed
Do the D-shaped exhaust ports make any difference as far as mating up to a pair of headers since the headers are not D-shaped?
Hodge
Old May 16, 2002 | 02:20 AM
max_est's Avatar
Car: '89 RS
Engine: LS3
Check my location If U ship them, then maybe we can make deal..
junkcltr
Aug 2, 2019 11:12 PM
anesthes
42
Oct 24, 2015 07:30 PM
gta90
Sep 15, 2015 04:00 PM
camaro71633
Sep 1, 2015 10:24 AM
