Going to change my tranny this weekend
Old Jan 30, 2001 | 03:59 PM
91dave's Avatar
You guys know of any tips you can give to kinda shave some time off, or any good short cuts
91 Camaro RS/SS
3.1LTR
Flowmaster Exaust
Hyperchip
K&N Airfilter
Ram Air,Cold Air Induction
Accel Wires,Cap,Rotor,Coil,
Plugs
Low Temp Thermostat
16" 91Z28 Rims, BFGoodrich CompT/A
Pioneer Speakers,Deck
Shift Kit
Power Pullys
Old Jan 31, 2001 | 03:43 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Cool, good luck, Dave! Make sure you have the right tools- that's the best shortcut I know of. See my message at:
https://www.thirdgen.org/messgboard/...ML/004874.html
Buy a breaker bar, a 1/2-inch-drive extension that's long enough to reach from the front of the trans to the back, and a 1/2-inch-drive 18mm socket. That'll take care of the trans-to-engine bolts. Avoid the thin 3/8-inch-drive (socket set) tools. Also buy a torque wrench if you don't have one.
I followed the directions in the Haynes 82-92 Camaro (or Firebird) manual. They're the same as in the GM Service Manual, and they don't leave anything out.
The most important tip of all: Make sure you seat the new torque convertor in the new transmission FULLY! Some guys mess that up- and then they need a new torque convertor and new trans-input-shaft.
Here's how to tell the TC is seated fully. When the new trans is back up and mated to the engine, thread two "trans-to-engine" bellhousing bolts in. Next, check the distance between the flywheel and the torque convertor. The two should NOT be mashed against each other! If the TC is seated fully, you should be able to slide it back and forth, along the trans input shaft, a few inches.
If the torque convertor is TIGHT against the flywheel, it's not seated all the way!! Drop the trans down, and spin the TC until it seats. This is a pain, here's why- our lockup torque convertors have two sets of splines to engage. If you only engage the first (easiest) set, the TC won't be able to slide all the way into the trans. You should actually be able to ram the TC all the way back into the trans's fluid pump so the TC hits the tranny bellhousing. If you start the car and the TC isn't fully seated, everything gets ripped up.
Oh- before you seat the TC onto the trans, lay it down on the ground with the opening up. Pour two quarts s-l-o-w-l-y into the center opening of the new torque convertor.
Old Jan 31, 2001 | 11:45 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
TomP when are you gonna move to cali we really need u here to help us in person lol.
Old Feb 1, 2001 | 09:50 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Heh, not as long as there's strict emissons and earthquakes! Altho one of my "life plans" is to see a California sunset.
I might be vacationing in Maryland this summer, if anyone's down that way.
Old Feb 1, 2001 | 11:47 AM
87CamaroLT's Avatar
Well, I'm in Va. Right smack in the middle between Richmond and Washington, D.C. I could check with my cousin to see when his annual car show's gonna be this year (it was up to 175 cars last year ), if you'd like a suggestion on when to take your vacation.
--'87 Camaro LT --
Contemplating a 2.8->3.4 swap.....
camaro11j
Sep 19, 2018 08:49 AM
Thornburg
Aug 25, 2015 01:46 AM
crazynights
Aug 21, 2015 06:53 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
