97 thirdgen rims!!!
Old Dec 3, 2001 | 12:37 AM
Tas's Avatar
Tas
97 thirdgen rims!!!
I've never seen such a huge selection for thirdgens before. http://www.superbuytires.com/wheels_by_car.html
You have to search for '82-'92 Camaros. They don't have a choice for firebirds but we know its the same shiet. A lot of these are more truck style meant for the S trucks since they can have almost the same rims as us. check em out.
-Tas
'89 Formula WS-6
305, TBI, 700R4, P.A.W. 14x3 open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips, Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248)
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
Old Dec 3, 2001 | 11:44 AM
ws6formula89's Avatar
I like these rims personally.
-Todd-
Old Dec 3, 2001 | 12:26 PM
jobryan26's Avatar
They do have a nice selection. These are PHAT!
See my Ride:
https://www.thirdgen.org/rides/index...ew&rideid=1324
Old Dec 3, 2001 | 05:29 PM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Thoes are Bling Bling
Peace, Love, and Carbon Monoxide...
Kj
Old Dec 3, 2001 | 06:28 PM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
<font face="Verdana, Arial" size="2">Originally posted by jobryan26:
</font>
I like those too. I bet if you got 18x10's on the rear and some 17x10's on the front, it would look freakin bad!
Old Dec 3, 2001 | 06:51 PM
Tas's Avatar
Tas
<font face="Verdana, Arial" size="2">Originally posted by Scott_92RS:
</font>
I don't think 17x10s would fit in front.
-Tas
'89 Formula WS-6
Super GRK_Taz World
F-Body Dual Exaust
Old Dec 3, 2001 | 11:47 PM
Scott_92RS's Avatar
Car: 1992 RS
<font face="Verdana, Arial" size="2">Originally posted by Tas:
</font>
What would be the main interference? Anything is possible with a little work, and my car will be tied up for a while anyway. What steps would I need to take to see if I could stuff em in there?
Old Dec 4, 2001 | 09:51 AM
FiReBReTHa's Avatar
uh oh...
then how are my C5 rims supposed to fit?
rear
18x9.5
front
17x9.5
hmf...
91 FireBird 305 V-8
Edelbrock Catback, Custom Alarm. Fourth Gen Console. i have six cupholders. all for starbucks!
Go|)Created The Earth, And Then Turned Up The Bass.
Here's My Audio Install!
"Honda's FOR ME TO POOP ON!" -Triumph...
[This message has been edited by FiReBReTHa (edited December 04, 2001).]
Old Dec 4, 2001 | 01:42 PM
Tas's Avatar
Tas
17x9.5" barely fit, Maybe if you roll the fender lip.
-Tas
'89 Formula WS-6
Super GRK_Taz World
F-Body Dual Exaust
Old Dec 4, 2001 | 02:30 PM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
OH MY *** I'M GOING TO GET THESE!!!!
Just kidding ........
89 Formula Firebird
Red with T-tops
5.0 305 FI
Soon to be a 400small block
Old Dec 4, 2001 | 10:39 PM
Basett_Racing's Avatar
<font face="Verdana, Arial" size="2">17x9.5" barely fit, Maybe if you roll the fender lip.</font>
I have 17 X 9.5's on the front, and they have never scrubbed, and fit as if they came on the car, and my car is lowered 2". Now, the 17 X 12's I have on the rear is what was gave me a helluva time!!
82 Z28 383, Ported 215cc Dart Iron Eagle Heads 72 cc Comb. Chambers, Comp custom grind Hyd roller cam, Speed Pro .250" domes, Wheeler Motorsports 4340 I beam rods, Eagle 5140 steel crank, Weiand Team G intake, Holley 830 DP, hedman headers
Trans: Turbo 350 w/ 4000 stall -- Rearend 7.5 w/ Richmond 4.10's, Auburn Minispool
Best ET:11.60@ 114.56, w/ a 7.28 1/8 @ 94.20, and a 1.598 60'
89 RS, L03 305, Hypertech Chip,cat delete, Dynomax exhaust,K&N open element Filter,160 stat, MSD coil --Trans:700R4 Corvette Servo -- Rearend: 7.5 GM 3.42 w/ posi-lock
Bassett Racing
Old Dec 5, 2001 | 01:42 AM
Tas's Avatar
Tas
<font face="Verdana, Arial" size="2">Originally posted by Basett_Racing:
</font>
can you give some specs on the rims, backspacing, tire sizes, method of lowering? Thanks . I talked to the guy that had the '91 black z28 in Car Craft. he had torque thrust 2s. he said they rubed the shocks when he bottomed out on the freeway.
-Tas
'89 Formula WS-6
Super GRK_Taz World
F-Body Dual Exaust
Old Dec 5, 2001 | 11:59 AM
Doski's Avatar
The zenetti vega rims are cool i just got them for my car chromed 18x8.5. All of those 97 rims wont fit, thats what they told me at superbuytires.
5,7l GTA -90
Old Dec 6, 2001 | 07:21 PM
Tas,
My fronts have 4.5" BS and the rears have a 7" , which I really wouldn't recommend to anyone unless you don't mind doing quite a bit of clearancing. I actually had to heat the inner fenderwells and actually stretch the sheel metal to fully clearance them. I had to notch the factory LCA's a little more than 1/2". I have since made a set tubular ones for it, and I had to offset them to make them clear. But as I sit here, I can't make them scrub now. A thirdgen with that much B/S, by all practical means needs to have mini-tubs. But the effort was worth it, because the pictures don't really do the car justice, because the rear tires's section width is a little over 13", and they are just BARELY under the lip of the quarter panel. The front section of both of my wheels are the same offest which looks cool. When its time for new tires, I'm thinking of going with 315's instead the 335's because even with the 12" rims the 335's seem just a little too wide for the rim. I took a big set of 18" Vernier calipers @ work and measured the section width, and was 13.48 inches.
SEC actually went bust, so I guess one good thing is I'll probably be one of only a few with these wheels on a thirdgen. I am going to take the wheels apart (they are a 3 peice design, and they are actually bolted together with 12-point ARP stainless steel bolts, which is cool), soon, and sand the paint off and polish the top "ridge" of the crosslace pattern, and leave the "inside" black. The crosslace pattern looks surprisingly close to the Boyd Cottington Tuned wheel, and I think it will do wonders for the look of the car. I just bought a ASCD SS hood for the car (pics soon) and, I also have a set of '91 Z28 GFX and rear aero wing that I am going to put on the car. Then, hopefully in the spring, I am going to have the car painted Sebring Silver. I photoshopped my wheels on a pic of someone's silver 91 Z, and I think looks great. What do you think??
**Notice that the side marker light and the rocker emblems are deleted?? That's not a mistake, I plan to do that. I may remove the side molding, and put 4th Gen "SS" emblems on the front fenders, but I haven't decided yet. Also I flipped the original pic, and forgot to remove the antenna, DOHH!!
Bassett Racing
[This message has been edited by Basett_Racing (edited December 06, 2001).]
Old Dec 6, 2001 | 08:41 PM
86BIRD-MY FIRST CAR's Avatar
Firebretha, HAHAHAHAHA, nice cut and paste job on those wheels for picture with that purple camaro. almost thought those wheels were real.
86 firebird 2.8
K&N replacement filter
modified air box
MSD ignitor
Hooker cat back
GNX style wheels
Old Dec 7, 2001 | 06:17 PM
RSFreak's Avatar
Transmission: TH700R4
I guess I'm just old fashioned, but I think these in 17" inch are 'Da Bomb'!
'91 Camaro RS
Bin Laden can have my Camaro when he prys it from my cold, lifeless hands!
Old Dec 8, 2001 | 09:41 AM
Bawls's Avatar
Car: 1985 IROC-Z
Engine: LB9
RSFreak, Im with you all the way.
No License, No Hope.
FILTERCHARGED BABY
http://www.crushed.org
Old Dec 8, 2001 | 02:53 PM
Mac's Avatar
Mac
Car: 91 RS
Engine: 350 H.O.
Chrome Irocs are still the best!
1991 teal camaro RS rebuilt 96 350 marine motor, comp cam, accel ignition,8mm accel plugs and wires, hedman headers and y-pipe, and rear end with 4.10 gears. Stock 700r4, best 1/4 time 14.6
Old Mar 13, 2002 | 10:24 AM
camaro6spd's Avatar
these remind me of the New SS rims, I wonder what they would look like on a white convertible.....
Old Mar 13, 2002 | 10:50 AM
85maroz28's Avatar
Car: 1985 Camaro Z28/1989 Pontiac Trans Am GTA
Engine: 305 tpi/350tpi
Camaro6spd what kinda rims are those. I like the look!!
Old Mar 13, 2002 | 06:56 PM
camaro6spd's Avatar
hey i found them first .....not sure, is there anyway someone could photoshop those an any white 3rd gen? PLEASE? I think i found a winner.
PRIMEX
the biggest tire seze they come in is 215 WTF.....
Frozer!!!
Jan 19, 2024 04:55 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
Exxon Limited
Aug 9, 2015 08:13 PM
antares57
Aug 6, 2015 07:47 AM
