Boost ? anyone with FI
Old Jan 1, 2002 | 10:16 PM
No5.0's Avatar
Car: Buick
Engine: 231
Transmission: 200r4
What kind of boost numbers out there?
Stock engine/Modified
Vortech/ATI
It doesn't matter what you got just post some psi levels,if possible include your idea of off idle/intial boost and max boost at your given rpm levels. Dyno numbers welcomed.
Sam
Old Jan 2, 2002 | 05:50 PM
'91 Formula's Avatar
Car: 1991 Firebird Formula
Engine: 383 Supercharged and Intercooled
Transmission: 6-Speed
Axle/Gears: Stock 10 bolt 3.42
12lbs of hot air. Intercooler coming soon.
Old Jan 3, 2002 | 09:54 PM
No5.0's Avatar
Car: Buick
Engine: 231
Transmission: 200r4
Is that on pump gas?
How's your timing inital and overall?
Sounds good
Old Jan 4, 2002 | 06:51 AM
Sounds good
Sunoco 94
Base Timing 8 deg. overall 22 with boost retard
Thanks, soon it will be intercooled to allow full timing.
Old Jan 4, 2002 | 10:39 PM
No5.0's Avatar
Car: Buick
Engine: 231
Transmission: 200r4
I am able to run 22* total with 16 lbs on 92 octane with about 3* of knock at shifts.I due run less combustion compression at around 8 to 1.This is with my buick by the way.
Old Jan 4, 2002 | 11:00 PM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
D1SC
3-core intercooler
Water/Alcohol Injection
8.7:1 C.R.
38 degrees total advance
NO boost retard
See sig for more details.
Old Jan 5, 2002 | 04:42 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
hell even though not what you wanted I will chip in
running 12psi creeping to 15 on 9.0 compression. running 92 octane
hp G-tech ( yeah I kno wthey are not the best) at 295
Old Jan 5, 2002 | 06:26 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
Willie,
What have you done to lower your compression to 8.7:1??
Just wondering
Regards
Robert
Old Jan 5, 2002 | 07:25 PM
Willie's Avatar
TRW forged flat top pistons with valve reliefs,
0.051" compressed thickness GM composite head gaskets,
58cc Corvette aluminum heads but....
Most of this has all changed in the last month.
I'm now running 0.041" gaskets and
56cc AFR heads for a 9.22:1 C.R.
Willie
Old Jan 5, 2002 | 09:41 PM
No5.0's Avatar
Car: Buick
Engine: 231
Transmission: 200r4
Wille how much installation time/effort did the blower cost you?
38* is alot what kind of trigger does your alcohol system have and what is turn on point?
Old Jan 5, 2002 | 09:53 PM
Willie's Avatar
Installation Time:
Well, I took my time. The instructions suck. About three days. But if I had to do it all over having done it before, it would take about 1/2 day. The kit generally comes with an FMU and a secondary in-line fuel pump. I did not purchase the FMU (so no installation time here). I use Carroll's Superfueler instead. Also, I already had an in-line Vortech fuel pump so no installation time here either.
Cost:
The D1SC with three core intercooler costs anywhere from $3300 to $3800, depending on where you get it from and how many "options" you elect (like a polished blower, etc.).
38* is alot
Yes, it is. But keep in mind that you make more power (on any engine) with as advanced a timing you can run as long as you don't detonate (general rule of thumb). I can run mine at 38 degrees with zero knock retard throughout the rpm range at WOT, so why mess with a good thing?
I use a 30/70 mix of distilled water to denatured alcohol at 100-psig through a 0.015" nozzle. The water/alcohol is injected just in front of the throttle body. It is turned on by a Hobbs switch which presently is set at 3-psig boost.
Willie
Old Jan 6, 2002 | 12:25 PM
No5.0's Avatar
Car: Buick
Engine: 231
Transmission: 200r4
Wille you been tinkering for a while on your ride. Because you know your stuff.
I 've got 2 friends that use the alky kit,and set it around 14 psi with the ability to run 22/23 psi of boost on 93 octane.
I need new motor mounts because of the false knock I get.
Alright last question to wille how much do you have invested in the engine/go fast parts?
Old Jan 6, 2002 | 06:41 PM
maniacc's Avatar
D1sc @10#'s boost upping to 12#'s this spring
3-core intercooler
stock 9.3:1 comp
MSD boost retard set at 0
stock 6 degree timing
24# injectors
ATI FMU and in-pump
see sig for all mods
$750 L98
Feb 1, 2025 02:25 PM
seiplentz
Aug 19, 2019 06:02 PM
customblackbird
Oct 1, 2015 04:30 PM
Dragonsys
Sep 25, 2015 03:51 PM
Doobie52
Sep 11, 2015 06:19 PM
