finished my headliner
Old Jan 23, 2002 | 08:17 PM
rocky383's Avatar
Car: 88 IROC-Z
Engine: 383 Stroker
here's the front
Old Jan 23, 2002 | 08:20 PM
rocky383's Avatar
Car: 88 IROC-Z
Engine: 383 Stroker
here's the back. the hardest part is right around the curves. i almost cut it too narrow to cover. if you do that it is a wasted 6 hours or so... I put 2 layers of fiberglass cloth on the backside and put 2 thick coats of water resistant glue over it. Then secured the edges of the headliner material with the same glue so it would stay put. It ws a lot of work but it saved a lot of money.
Old Jan 23, 2002 | 11:48 PM
Tonyrodz's Avatar
Transmission: auto
Looks good buddy!!
Why did you glass it? Was the cloth coming down and did the board itself bend? While taking headliners down I've come across 2 different types of t-top headliners--one is more delicate then the other--seems to me the best one GM used(more forgiving)is like a fiberglass material(cloth)--looks like(a little-kind of)the glass that you put around a hot water heater--sorry, but that's the only way that I can describe it. Looks like the same kind of fiberous material.
I hope someone knows what I'm talking about.
Old Jan 24, 2002 | 02:41 AM
loomdog32's Avatar
Car: 82 Camaro Z28
Engine: LU5 - Crossfire 305
Transmission: 200c - 3 Speed Automatic
fiberglass insulation blanket.. R8 is whats usually used in cali. ive never thought of using something like that in a headliner before..
mike (loomdog)
Old Jan 24, 2002 | 07:42 AM
rocky383's Avatar
Car: 88 IROC-Z
Engine: 383 Stroker
Thanks!
The old headliner material had separated from the t top board and when I took out the headliner, it broke in two pieces right by the dome light. I wanted to be sure that it would not break again is why I glassed it. It is VERY stout now and with the water resistant glue, it isn't likely to be weakened by moisture. I have only seen on type of headliner board myself, but i know what the water heater stuff is.
Old Jan 24, 2002 | 08:23 AM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
Looks nice, wanna do mine?
Old Jan 24, 2002 | 11:16 AM
Tonyrodz's Avatar
Transmission: auto
Originally posted by rocky383
Thanks!
Man--I'm glad someone knew what I was talking about!!
The t-top board I have in my car now is that same type(water heater type)it's very forgiving w/o snapping.
Old Jan 26, 2002 | 03:58 AM
IROC212's Avatar
Car: 1986 IROC
Engine: 355 Tpi
Axle/Gears: 9 Bolt 3.27
Thats cool, I never thought of reinforcing the board with fiberglass. I scored a different one from a boneyard out of a 91. I keep hesitating to put it in until I solve the leaky T-tops first.
Old Jan 26, 2002 | 04:38 AM
Blue502's Avatar
Looks nice. Where did you end up getting your material?
Old Jan 26, 2002 | 09:06 AM
rocky383's Avatar
Car: 88 IROC-Z
Engine: 383 Stroker
I got it at Auto Zone for $30. The brand name is Headsup. I used Permatex professional grade headliner and carpet adhesive, it was $8.
Old Jan 26, 2002 | 10:25 PM
stuart69427's Avatar
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
i went for a long term investment and bought the ABS plastic headliner. to me it was worth it. my headliner was in three peices when i bought the car and i hadn't had the car for two hours before the headliner was siting on the curb
Old Jan 26, 2002 | 11:16 PM
Jza's Avatar
Jza
Looks good. Hope it lasts.
Old Jan 27, 2002 | 01:09 AM
rocky383's Avatar
Car: 88 IROC-Z
Engine: 383 Stroker
Me too. It's a lot of work. BTW, nice avatar!:hail:
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
91 SrS
Oct 7, 2015 04:32 PM
loud91rs
Oct 5, 2015 10:05 PM
formula00ra
Interior Parts Wanted
Sep 28, 2015 11:50 AM
