KILLER RAM AIR SETUP for TBI
Old Mar 18, 2002 | 04:09 PM
exdog's Avatar
Car: 91 RS
Engine: TBI 350
I finally finished my ram air setup on my car. It is a hybrid of TBI and TPI ram air posted in the tech articles. I changed out the upper air dam to the TPI one and followed the directions for making that part of the ram air. I used 7" rigid flexible aluminum ducting to go from the 2 scoops in the front to the opening of the tpi snorkel. I finished off the inside with that aluminum tape to smoothe it out and make it stronger. from there I bought a 6" air cleaner (toss out the filter it comes with), 7" Metal duct, 3" metal duct, and 3" rigid flexible duct. (not dryer hose)
I cut a 3 1/2 strip out of the 7" piece and riveted it to fit inside the lip of the air cleaner.
I used a 3" hole saw to cut the opening for the 3" metal duct.
I then took the 3 " metal duct and cut it to about 6" long, stuck it through the hole and cut flaps to fold it in place. I riveted it in place there.
After that I had to cut the riser off of the bottom of the air cleaner. If you dont it will be too tall. Take it and put it over the stock air cleaner spacer ring and RTV the hell out of it. This serves 2 purposes. 1, it helps keep it in place, and 2, it keeps the massive amount of air coming into the newly confined changer from blowing gas from the injectors all over the place.
Once the bottom is dry your ready to do the finishing touches.
(Before you RTV the rest make sure it all fits good and make the nessecary adjustments. )
First put the air cleaner base on, Then run a bead of RTV around the inside of the filter lip. (this can be done outside the car but be sure to align the spacer ring first).
Place the metal ring you made inside this lip with the 3" tube facing the front ot the car.
Run a bead of RTV around the inside lip of the top of the air cleaner and put it on.
Once this is done put in the TBI and screw it down.
At this point you want to take the flexible aluminum ducting and run it from the back of the TPI to the tube on the front on the new air cleaner.
Make sure you secure the tubing, I used duct tape and covered it with the aluminum tape for appearance, and put TPI filters into the intake.
Your ready, let the RTV dry for an hour and adjust you fuel pressure regulator for more air. Have a nice ride.
Contact me with any questions and picture requests. If someone can give me an email address of the site administratoe I will get it posted in the tech articles.
Pics can be seen here http://91rsramair.tripod.com/
Old Mar 18, 2002 | 04:19 PM
1MEAN92RS's Avatar
Car: '92 Rally Sport
Engine: LO3
Um, this is all fine and dandy, but can we see some pics??? Sounds like a kicka$$ setup!
Old Mar 18, 2002 | 05:03 PM
exdog's Avatar
Car: 91 RS
Engine: TBI 350
Ram Air Pics
Pics will be posted ASAP, My smart reader crapped out and I have to get a new one.
Old Mar 18, 2002 | 08:14 PM
exdog's Avatar
Car: 91 RS
Engine: TBI 350
Go Here for Pics
Old Mar 18, 2002 | 08:29 PM
BahamutRS's Avatar
On my RS I had this trick ram air setup going...I had dryer tube run to the high beams (use a L69 dual snorkel cleaner) and I removed the high beams and placed screen there...if you're good, it can look cosmetically decent. Big power gain too.
Old Mar 18, 2002 | 11:17 PM
HrdRockA4305's Avatar
I'd been thinking about doing something like that for a long time, I just never came up with a good way to adapt it to the TBI! Did it seem to help much?
Old Mar 19, 2002 | 03:29 AM
exdog's Avatar
Car: 91 RS
Engine: TBI 350
I think it made a good bit of differnce. nothing phenominal but every little bit helps. I'm sure this setup on a TPI would be much better.
Old Mar 19, 2002 | 11:28 PM
exdog's Avatar
Car: 91 RS
Engine: TBI 350
top
Old Mar 21, 2002 | 11:49 AM
exdog's Avatar
Car: 91 RS
Engine: TBI 350
Ive noticed that I've been exceeding bandwith on the site. Sorry about that, keep trying to get into it or email me and I'll send you the pics direct
Old Mar 26, 2002 | 07:27 PM
RSFreak's Avatar
Transmission: TH700R4
I had a similar ram air setup on my '85 Z28 TPI 305. I did notice a small power gain at speed. I think it is a worth while mod regardless of which induction you have.
Old Apr 1, 2002 | 09:21 PM
demonkey36's Avatar
Car: 1991 Camaro RS
Engine: Was 305 LO3 TBI, now carbed 355
So was your RS originally TPI?
Old Apr 1, 2002 | 09:54 PM
exdog's Avatar
Car: 91 RS
Engine: TBI 350
No, it was always TBI. I just changed out the front plastics to TPI setup.
Old Apr 2, 2002 | 04:54 AM
demonkey36's Avatar
Car: 1991 Camaro RS
oh okay......where did you get that black dual intake piece, and for how much?
Old Apr 2, 2002 | 09:57 AM
exdog's Avatar
Car: 91 RS
Engine: TBI 350
I found both peices in a junkyard for 20.00. You can use one from a 6 cyl too.
Old Apr 2, 2002 | 10:01 AM
mattRS's Avatar
i have got that same mod. instead of the dryer hose, i used a gutted MAF and the plastic tubing that originally went from the intake housing to the single snorkel. i used a dremel to cut off the housing right between the housing and the thermac. i am at a computer right now that i dont have pics on, but i will post some later today. i shaved off .3 in the 1/8 with just this set up, new coil, cap and rotor, and a 3"high flow cat. did all at the same time so dont know which one helped the most
evilstuie
Jan 9, 2020 08:29 PM
stalkier
Dec 6, 2015 11:25 PM
L98GTA87
Aug 11, 2015 06:55 PM
92purpz28
Aug 11, 2015 02:30 PM
bryan623
Aug 10, 2015 11:33 AM
